deezler
Elite Member
- Joined
- Jan 30, 2012
- Messages
- 3,990
- Location
- Southeast MI
- Tractor
- Cub Cadet 7305, Kioti CK3510seh TLB
Well regardless, I'm still gonna cringe.
Never let them load without giving them direction.
What's a 40k lbs loader only doing with a 4 cubic foot bucket? Loading uranium or black holes?A Deere 644 payloader with a 4cf bucket will weigh about 40,000 pounds. AND they are fun to operate!
What's a 40k lbs loader only doing with a 4 cubic foot bucket? Loading uranium or black holes?![]()
woops...I fixed the typo.What's a 40k lbs loader only doing with a 4 cubic foot bucket? Loading uranium or black holes?![]()
I guess I should have explained better but this is how the loader operator knocks the top off, he does not press it flat. my trailer is 14 feet so his bucket does fit inside and he just racks the top to the sides.A word about loaders and “flattening” the load. Some inexperienced loaders will attempt to use the bottom of the loader bucket to press down the load to level it up or spread it. Lots of problems can occur from such practice. Tipping the bucket and raking it across the top of the pile to spread it out is much safer and effective.
I agree with those that say you need to direct the loader operator a little better.
Its funny how you should spend tens of thousands of dollars and upgrade trucks too. I think according to some, a half ton should haul nothing more than groceries or a few bags of mulch and should never tow anything...
Too many variables in half tons anymore. And depends on how modern it is.Nothing wrong with a good half ton pickup. It's just that.... they are so easy to overload, or be tempted to pull way over your maximum legal tow rating with. And we all have to share the road with you (whoever it may be). Sure, your f150 or 1500 can take the abuse ok, and you've been lucky for the last dozen years without necessarily realizing it. But then one day something suddenly breaks on the highway, or some idiot pulls out right in front of you, and it all goes wrong. And legally, you are to blame.
My generous neighbor with the 10k 6x10 dump trailer I borrow used to haul it behind his 2002 Ford Ranger. With a 2" ball in the 2 5/16 trailer coupler. And no brake controller. Until he finally bent the frame. And then bought... a v6 f150. Still way over his capacity, still no brake controller, hopefully using the correct sized ball now (I should check). Thankfully he really only uses it to haul manure from the horse farm up the road.
Well I generally agree with you in full, but to be fair, it sounds like you are making some of the same over-generalizations in the other direction.No one would be giving him a hard time if he was pulling said trailer with a 3/4 ton truck. But everyone is giving him crap for doing it with a "half ton".
Compare the payload and tow ratings of a 1999 3/4 ton vs a modern half ton. Aint much differences. And depending on how trucks are equipped, axle ratios and transmission etc....many times a modern half ton is rated for more than a 20 year old 3/4 ton.
Its the blanket statements that "you sould get a 3/4 ton truck cause it is better" that is the issue.
A modern half ton with 9000 pounds behind it is not excessive or exceeding ratings if properly equipped. And Id much rather do that than the same load behind a 25 year old 3/4 ton
