What size drill bit for lug stud.
/ What size drill bit for lug stud. #1
brokeasajoke
320dtc
I want to replace the lug studs on my trailer to fit a different wheel backspacing and requires longer studs. My current stud is approximately .542 at the knurl and the longer stud I want to use is about .555. What size should I open the hub hole to? I tried pulling one in and it defiantly won't go. I'm going to have to have a slightly bigger hole. Dorman don't make a long stud with the knurl I need. Thanks.
/ What size drill bit for lug stud. #2
Do you have a part number and/or proper application that the stud is supposed to be used for? Maybe it can be looked up that way?
What side are your current holes? Do they match the .542 at the knurl of the old studs?
It seems 35/64 is gonna be as close as you can get without some kind of special tool. 17/32 is smaller than you have now, and 9/16 is too big.
Yes I can get application but don't have that info right now. My current studs work and I use work lightly cause that lack about 2 threads from the stud coming through.
/ What size drill bit for lug stud. #4
I doesn't know but did u heat the hub and freeze the stud?
There's a thought but it'd be a bear to ever change I would think.
/ What size drill bit for lug stud. #6
/ What size drill bit for lug stud. #7
Do you know anyone with a lathe that will turn down the new studs for you?
/ What size drill bit for lug stud. #8
I was gonna suggest that but am afraid it would take too much of the knurling off and the stud will just spin when trying to tighten a lug nut
/ What size drill bit for lug stud. #9
A 14mm drill gives you .551
I would think that you could make that work by freezing the studs before pressing them in, just not sure how much of a press fit you want or need.
/ What size drill bit for lug stud. #10
Drill bits do not leave exact sized holes and results will vary according to the particular situation. Slightly enlarging a short hole, having an internal swaged knurl topography, freehand is a particular that is hard to predict accurately. A 0.550 inch reamer would give a virtually exact and predictable result.
/ What size drill bit for lug stud. #11
I would find out what press fit you need and go to Grainger or MSCdirect and get the decimal sized reamer you want. It will cost the least and probably the easiest way to finish the job. Just make sure you use some oil when cutting with the reamer and I would run it a lot slower than drill speed. For this size, I would want to run it 150 rpms or so if possible.
2005-2014 mustang.
/ What size drill bit for lug stud. #13
What size are current holes.
It looks like they must be front wheel studs for those mustangs.
Looking up various other studs.....quite a few actually list knurl size as well as a acceptable hole range.
For example, I saw a .615 knurl stud and said for hole size .606-.613
So it looks like .002-.009 under knurl is a good target.
But you said these new studs were closer to .555???
Everything I saw online for the application said .549"
And I'm pushing hard. Shank that knurl is on is about 530.
/ What size drill bit for lug stud. #15
I wouldnt be afraid to try a 35/64 bit and see what it does.
/ What size drill bit for lug stud. #16
@Root Cause post #11 says what is needed. A professional result matching that of the original studs is not a job easily accomplished freehand and in place on the vehicle. You need a rigidly controlled aligned setup to assure the hole goes through round accurate and square. What is easy on a machine takes some real planning to do in situ. If only they made the exact size you need in a carbide ball burr. You could pull it through the hole using a variable speed hand drill.
/ What size drill bit for lug stud. #17
A reamer is what all machine shops use to make holes a specific size.
Dull reamers cut oversized because pressure = wobble.
You can find a chart that will show you what size pilot hole to drill for a given reamer for a reason.
A reamer will cut oversize if the pilot hole is too small. (more pressure= wobble)
From what the Op states, the current hole size sounds about right.
Freehand reaming with a hand drill will give you a tapered hole until you get some penetration where the reamer finally follows the existing hole. This job requires a good drill press or milling machine.
FWIW, drill bits drill oversize when one flute is wider than the other. Quality drills with a good setup will give you the exact size hole if you drill a pilot hole close to the same size and the drill bit is sharp. Higher rpms and slow travel can give you a decent finish.
/ What size drill bit for lug stud. #18
Why not try shaving a few microns (at a time) off the knurls ?
/ What size drill bit for lug stud. #19
Buy an extra stud or two and get a scrap hub. Use a drill press. Drill or enlarge a hole and and try the stud.
Bruce
Plenty of good thoughts and ideas to chew on here. Thanks for all the replies.
1998 JD #8300 MFWD (A68191)
1998 JD #8300 MFWD...
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
INDUSTRIAL HOSES (A68842)
INDUSTRIAL HOSES...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2021 CHEVROLET TAHOE (A66091)
2021 CHEVROLET...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
