What size drill bit for lug stud.
/ What size drill bit for lug stud. #21
Drill bits are not reamers. DB needs a pilot hole to be only as wide as the bit's web. (AKA 'chisel' in the trade) The margin has no relief so doesn't actually cut when wobbled to enlarge a hole. Reamer also has no relief on the margin, removes up to .015"/side when hole is sized correctly.
Using a drill bit sized to slightly enlarge a hole is like reaming and puts all the load on the corners. (10+ yrs J-man toolmaker/tool grinder for GM engine & transmission plants, once 22k member UAW Local 599 is now just a retiree chapter)
Agree that a DP or better a mill is best to maintain hole size and location. Ream don't drill if hole is nearly to size. Carbide tooling (drills, reamers, burrs) can chip/break easily when used in hand drill & some (less rigid) DPs.
Anyway, back to what'll work this time.
/ What size drill bit for lug stud. #22
[[Anyway, back to what'll work this time.]]
Rat tail file and Loctite. :D
/ What size drill bit for lug stud. #23
Buzzing the hole out with a die grinder would also work. You don't need to remove much.
/ What size drill bit for lug stud. #24
Trying to explain that on this forum seems a lost cause. Everyone thinks The proper way to drill a 1" hole is to start at 1/4, then 3/8, then 1/2 then 5/8, the 3/4 etc etc. I feel bad for the poor drill bits.
But split point bits up to 1/2"....no pilot. Over 1/2"...pilot only the size to clear the chisel. It cannot be repeated enough.
/ What size drill bit for lug stud. #25
Yes, but extremely hard to control. You cant win the accuracy fight. Deflection forces from cutting on only one side of the burr cause it to want to orbit inside the hole. -- Very sensitive to the slightest loss of operator control, especially when the burr is not quite small compared to the hole. But then a small tool causes a need for more fine blending; a light touch situation that hampers tight positional control. And a burr nearly as big as the hole is out of the question. Such can generate orbital frequencies well up in the audio range [KHz] from a bit spinning just a hundred RPM !
/ What size drill bit for lug stud. #26
Actually from a technical point of view the only logical reason not to step up in bits is about precision (not the wear on the bits)..because the lack of guidance of the point you can end up with a three sided or oversized hole...
...Yes, it does wear more on the outside of the lip face but no more than if the entire lip was cutting...it also takes less energy from the drill...it's a compromise but hardly a big deal...These days field machinists and millwrights use unibits in place of twist drills for enlarging etc...
/ What size drill bit for lug stud. #27
Grabbing and chipping of the cutting edge. The spiral angle causes it to pull in/'screw' in. Even a drill press can suffer this as there is downward play in the spindle rack&pinion. Bits used for stepping should be brassed to a less aggressive angle.
/ What size drill bit for lug stud. #28
Stepping actually takes more energy from both the drill and the operator trying to fight said drill.
The attack angle of the cutting edge gets more aggressive out towards the edge of the bit. And only trying to enlatge a hole 1/8" (1/16" each cutting edge) causes the drill to want to bite way too aggressive and you end ur chipping drill bits, bending them, or breaking them (or the operators arm if in a good drillmotor).
A pilot only as large as the web of the bit is all that is needed and prevents the bit from wanting to grab too aggressively.
A sure way to tell a novice machinist/millwright apart from an experienced one is how they decide to hand drill a 1" hole. IF someone grabs two bits, ~1/4" and a 1".....you know they know what they are doing. Someone that grabs 8 bits in 1/8" increments is a novice and I'll stand back and watch the show as they proceed to destroy half a dozen bits in the process of trying to hang on for the ride.
/ What size drill bit for lug stud. #29
LoL...Depending on the thickness of the material being drilled...(room permitting) a professional machinist or millwright is most likely going to bore a 1" hole with a mag drill and an annular cutter....otherwise a drill motor, pilot bit and a unibit...
...it would only be in a unique situation where a regular twist drill would be employed...
Again, it's a compromise mostly based on precision...someone that only has battery powered drill motors and a set of twist drills.would usually give up the pointy head professional practice for the ease of getting a hole bored that will work for them...and they'll do it every time..(cutting less metal requires less energy)...
/ What size drill bit for lug stud. #30
There are plenty of times when professional machinists/millwrights cannot use an annular cutter and mag drill. And unibits suck for anything over 1/8". So to say it requires a unique situation to use a twist drill is far from accurate.
While opening up a hole 1/8" at a time sounds good in theory to a novice.....those who make a living making holes in metal know that is the worst possible thing you could do
/ What size drill bit for lug stud. #31
LMAO....those that make a living boring holes in metal don't usually use hand drills and twist bits...go back and read what I said a little slower...!
And I hate to point it out but this thread was about enlarging an existing hole....likely a common occurrence in the millwright business...!
Quality unibits are commonly used on metals up to 3/8"...and they are fast...
/ What size drill bit for lug stud. #32
Millwrights (that I still hang with & talk shop) use(d) reamers to tweak holes working in our GM plant. Rotary broaches not in their kit & not always a place to attach a mag drill to a machine when setting it. May be different in other shops.
/ What size drill bit for lug stud. #33
Yup, the thread was about enlarging an existing hole. And I gave my advise. But then somewhere on page 2 or 3 the conversation turned to stepping up drill bits vs a pilot and drill to size.
Unibits are different than stepping up drill sizes. Their cutting angles are not the same and they dont try to grab and twist the drill out of your hand like stepping bits.
But Id say most on here dont have a unibit.
And most that make their living making holes try to avoid using a hand drill. A drill press, mill, mag drill, etc are all much preferred. But there are times when a hand drill is the only option.
And yes, slightly enlarging an existing hole with no way to mount a mag drill is a very common occurrence in the millwright profession. And its dreaded by anyone that has any experience. It is much preferred to just drill a pilot then a bit to size. Unibits have too many limitations.
I am someone who has made a career making holes in metal. I have held many titles, some of which include industrial maintenance, machinist, and millwright. So when you reference "professional machinist or millwright", or "those that make their living boring holes"......you sir are talking about ME. I AM one of those you reference. And I stand by what I have said, and could hook you up with a dozen other "professional machinists and millwrights" that will say the exact same thing
/ What size drill bit for lug stud. #35
I’m with spyderlk and LD. You’ll never get a usable hole with a drill bit. Never.
Custom sized reamers are available and are the best solution, especially since you need to do several holes. Don’t wreck the hub, break the bit, or break your arm with a drill bit.
If it were just one thin hole, you could try a carbide burr and a high speed die grinder, but you should have some experience doing this.
What ‘“might” work is a tool called a “tapered bridge reamer.” You would need a 5/8”. This size reamer starts at about 7/16 (guessing here) and final diameter is 5/8. Your final, correct size will be somewhere along the length of the taper. Mark the shank or make a stop collar to limit the final depth that you need, to achieve the hole size you want.
Ream from the backside, so the hole gets smaller as it gets nearer to the hub face. Turn it as slow as you can, using a big OLD, slow speed 1/2” drill.
Someone above suggested practice. I HIGHLY recommend that too. Get a flat plate of scrap, about the thickness you are working with. Drill a 1/2” rough hole (or several) in the plate, then ream with the bridge reamer until the stud fits. When you get it right, head over to the hub. And as mentioned, freeze the stud and warm up the hub.
/ What size drill bit for lug stud. #36
I had considered the bridge reamer route as well, but thought, perhaps wrongly, that the taper hole would be a deal breaker. :unsure:
/ What size drill bit for lug stud. #37
Bridge reamer has a slow taper, not like the T-handle reamers many of us used for elec panels/boxes before unibits and cordless drills went into our kits. We're removing the hubs to open holes and install the studs, no? Once a hole is sized right for the interference fit I've used manifold nuts & deep-well impact sockets to draw wheel studs in, with anti-seize I'd use on threads anyway. Grease is kinda old hat for that but still works. btw, love hearing from other tradespeople, esp those with more OTJ experience than mine. (y)
/ What size drill bit for lug stud. #38
Never stated, but Iv always thought this was to be handled in place. Otherwise the job is an essentially trivial drill press reamer task.
/ What size drill bit for lug stud. #39
I'm just a yay hoo with a shop at the house, but I have a 30 ton press. I'm sure somebody you know has a press. Probably a die grinder also. And can make your dreams come true.
90in. Work Bench (A65640)
90in. Work Bench...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
Patterson water pump (A59230)
Patterson water...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
