M vs. L series in 45-60 HP range
/ M vs. L series in 45-60 HP range #21
I want something a little more powerful to run my flail mower without bogging down.
Transmission choice will have no effect on power transmission to PTO powered implements.
I stand by this post. The proposal that HST transmission will negatively affect pulling a flail mower is silly.
HST might limit pulling a heavy Disc Harrow or other ground contact implement sunk in the ground, but not a flail mower which rides on rollers.
/ M vs. L series in 45-60 HP range #22
The shuttle shift on the M4 is basically a HST in your hand. But he's on a manual tractor now so a clutch wont be mystery...unlike most kids these days.
"basically" is not the same thing
I went from an 8n, to a geared L now to a MX with HST and wouldnt have it any other option for what I do other than HST.
Maybe HST is important to him and he overlooked the fact that the M dont have it, or maybe it isnt important. Hence why I posed it as an "IF" statement so he could offer feedback
/ M vs. L series in 45-60 HP range #23
For what it is worth, I have had several BX and B series tractors and now a L 3560 and I could not be happier . The extra weight and wider track makes all the difference. I only gained about 12 hp but the weight difference larger hydraulic package is a significant upgrade while still having a tractor I can maneuver in tight places . I run a 72 in. Finish mower as well as a front bucket and I’m satisfied
/ M vs. L series in 45-60 HP range #24
Having had an L4630GST before I got the M and used it for the same operations, I can unequivocally state, that an M is far away a more "able" tractor for all actions compared to a comparable L series.
They are just bigger, heavier and stronger.
I don't do any ground engaging work so I can't comment on that but commercial scale logging does not faze it a bit.
/ M vs. L series in 45-60 HP range #25
When I upgraded I looked at several brands/models. I choose the Kubota M6040. Mind you - it's not the IDEAL tractor. It's the best compromise I could find. Sometime I wish for bigger - occasionally I wish for smaller.
The way I have it set up now - weight is 10,100 pounds.
/ M vs. L series in 45-60 HP range #26
A HST has slightly less rated PTO HP than the same model with a geared tranny. The HST charge pump is constantly running & tapping a bit of HP. Not enough to notice I'm sure, but ratings are different by up to a HP or so from Kubota & elsewhere.
Under way a HST is about 15% less efficient than a geared machine. However the flexibility of a HST can overcome that in many cases. In a geared machine, you pick a gear that won't stall or bog the machine & that's what you have unless you stop & shift. On a HST you press the go pedal until the RPMs drop a bit. You can vary the go pedal constantly to keep the machine tapped to the limit despite varying ground or brush conditions. Makes precision work with a loader or implement trivial too. You can do it with a geared machine, but precision work & lots of direction changes are faster with a HST.
/ M vs. L series in 45-60 HP range #27
It’s been posted many times but I guess once more won’t hurt.
/ M vs. L series in 45-60 HP range #28
The ONLY think that that video proves is that a HST in High range isnt made to pull very much. But in NO WAY is it an accurate comparison that would make some think a gear tractor can somehow pull more or heavier stuff, let alone almost 3x as much. Because I pull a 3-14 plow with my MX5100 HST. So by that math I sould be able to easily pull a 8 or 9 bottom plow had I gone gear :ROFLMAO:
/ M vs. L series in 45-60 HP range #29
I think it would have been a better comparison if they did the most effective pull with each. At a cruise speed doing work (brush hogging hills or baling) I think there would be a marked difference in speed and efficiency. I’ve got an MX HST right now and I love it, I’ve got the M4 Shutle and love it. There are things geared tractors do better and things HST tractors do better. If the focus is with what you’re doing on the working end of the tractor I think it’s gear for the win, if your focus is the Swiss Army knife side then it’s HST.
Fwiw, I've been avoiding hst for the same reasons I'm not wanting a fel--I've got a skidsteer and much prefer that tool for material moving. I don't plan to do a lot of dirt work with a fel on the tractor. I do however want decent 3pt lift capacity, since my Bobcat 743 only lifts about 1500lbs before I put the prowler tracks on it.
I'm hearing a lot of folks that switched from L to M and are very happy with the change. I think I'll continue to lean in the M direction but will no longer snub my nose at the L or MX that come up.
Thanks for all the input everyone!
/ M vs. L series in 45-60 HP range #31
Pretty much because your use of the phrase 'comparable L series' is a poor choice. The two series are not comparable. They have both existed for decades because of their substantial differences.
/ M vs. L series in 45-60 HP range #32
No a
No argument that there are things a gear can do better. Any tillage type work or plowing. But that said, a HST is still quite capable in that department. Just not as efficient at transmitting power to the ground. I plow and disc 2 acres of corn plot with a HST MX. 3-14 plows and a Deere 210 (~11') transport disc. Gotta keep it in low because trying medium it just lacks power to be able to go any faster than Low range speed. So Im limited to ~3-3.5MPH. I would certainly rather be plowing and discing at 5-6 MPH, but it just cannot sustain that in Medium range.
But I also do a fair amount of loader work, rear blade work, and bushhogging. And the HST more than makes up for itself in those departments.
But as that video is concerned....the MOST tractive effort is the exact moment right before the wheels break loose and spin. The spun the wheels on the gear but failed to on the HST. So they never got a true representation of what the HST can actually pull. But in theory....the HST "should" actually be able to pull a little harder....since HST equipped tractors are usualy a tad heavier.
MY MX with loaded tires and wheel weights will only spin the tires in Low range. Which is nice at times doing loader work. Because I can keep it in medium range, and not have to worry about tire slip and tearing up someones yard....yet it sitll has ample power to be able to do what I need.
/ M vs. L series in 45-60 HP range #33
I probably should have said "similar sized HP wise" instead.
/ M vs. L series in 45-60 HP range #34
That can even be off a fair bit between an economy L & a Grand L. A L3901 has 39hp. A L3560 has 35-36hp & my L4060 has 40hp. Every one of the Grand Ls will out work the economy Ls in most measures but PTO HP even with less HP. They weigh 50% more with gives way more traction & pulling power not to mention lift capacity on either end. They are generally wider which means more stable. Both are good machines, but it's like comparing a Grand L to a M almost.
/ M vs. L series in 45-60 HP range #35
Why do you have to stop to shift?? My tractor has a synchronized trans, I don't have to stop to shift.
Just push the clutch in and shift...on the go, and doing field work, I don't have to shift very often, so it's no big deal.
SR
/ M vs. L series in 45-60 HP range #36
I've been looking for a used Kubota to upgrade from my old Ferguson to35 that is accumulating too many problems.
<snip>
My actual question then is this:
Am I correct in avoiding the L series or should I open my mind a little to considering them? I see a lot more L series out there so I have more options to choose from, but I also wonder if that's because everyone has just traded theirs in for a M series.
Thanks for any help!
May have missed it but I did not see mention of either how much the OP wants to spend or a list of what he plans to do with it, much less how old is "used".
My M4700 meets his criteria - M series with about 50HP, 4Wd. Cost me about $11.5K back in 2013. A quick look on Tractorhouse shows one for sale now for $15.5K with only 1,069 hours in Wylie Tx.
I'd highly recommend one.
But as others have mentioned - in this day and age you might be extremely limited in availability.
/ M vs. L series in 45-60 HP range #37
I own both an L6060HSTC and an MX5800HST. I looked at an M but decided the slightly smaller MX would suit my needs. So far, it has.
FWIW, here are a few thoughts:
- Both tractors have plenty of power compared to my old L3430HSTC
- The front wheels are larger on the MX and do provide a bit more traction. I use the MX mostly for earthwork with a BH92 hoe. For some reason, the hoe is more stable on the MX than on the L6060 even though it is slightly heavier.
- I use a 72" flail with the L6060 and so far, it has never bogged down while mowing heavy vegetation.
- I mow 7 acres & plow snow with the L6060 and recently traded up from an L6060HST to the L6060HSTC cabbed model. I'm getting older and needed the creature comforts. The heat is great when plowing at 10 degrees and the A/C is nice when mowing when it's 95. You say you don't want a cab but consider the future.
I'm wanting something a little more powerful to run my flail mower without bogging down, possibility of haying in the future, and strong 3pt to lift those occasional loads that my Bobcat 743 skidsteer (1300lb roc) can't do.
4wd is a must since I'm dealing with hilly terrain. Wide base/low center of gravity is also ideal for the same reason. I do not want a FEL since I have the skidsteer which is a much better tool for material moving, though if I find the right tractor that has one and still a decent price, I'd be okay with it, or possibly sell it to help with the purchase price. Actively do NOT want a cab.
I've been avoiding looking at L series tractors almost entirely because I hate the tiny front wheels on them. I've seen those get stuck so easily compared to the M series larger front wheels for 4wd.
I also get the sense that L series is altogether a lighter duty machine, but also smaller overall for the power they have. I'm starting to wonder if the smaller size would be a good thing for the hills that I'll be working on, and also working around and under trees a lot.
I own both a 4WD L6060HSTC and an MX5800HST. I looked at an M but decided the slightly smaller MX would suit my needs. So far, it has.
- The front wheels are larger on the MX and do provide a bit more traction. I use the MX mostly for earthwork with a BH92 hoe. For some reason, the hoe is more stable on the MX than on the L6060 even though the L is slightly heavier.
- I mow 7 acres & plow snow with the L6060 and recently traded up from an L6060HST to the L6060HSTC cabbed model. I'm getting older and needed the creature comforts. The heat is great when plowing at 10 degrees and the A/C is nice while mowing when it's 95. You say you don't want a cab but consider the future.
- I mow steep slopes with the L6060 equipped with R4 tires and see no RPM or traction loss when mowing uphill using my 84" finish mower.
I think the answer to your question really depends on how you plan to use the tractor. Don't overlook the MX series as was previously suggested.
/ M vs. L series in 45-60 HP range #38
The bigger tires is only a R4 thing. And its only the front tires.
Both have the same size AG's....with 9.5-16 fronts and either 13.6-28 or 14.9-26 rears
Both have 17.5L24 rears but the MX has 12-16.5 fronts and the L has 10-16.5 fronts
/ M vs. L series in 45-60 HP range #39
There's mention of running a flail. Flails tend to eat power. I'm running a 7' flail on my 55hp Kioti and it's about all that that tractor can handle: flail manufacturer says 60hp min, so it's not like it's a surprise; it's mitigated by having to run slower- I have rough ground and a lot of trees.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2016 GMC Seirra Denali 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 GMC Seirra...
Caterpillar 279-5360 72in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A59228)
Caterpillar...
