M vs. L series in 45-60 HP range
/ M vs. L series in 45-60 HP range #1
Brambleberry
Kubota 4850 EverClutch
I've been looking for a used Kubota to upgrade from my old Ferguson to35 that is accumulating too many problems.
I'm wanting something a little more powerful to run my flail mower without bogging down, possibility of haying in the future, and strong 3pt to lift those occasional loads that my Bobcat 743 skidsteer (1300lb roc) can't do.
4wd is a must since I'm dealing with hilly terrain. Wide base/low center of gravity is also ideal for the same reason. I do not want a FEL since I have the skidsteer which is a much better tool for material moving, though if I find the right tractor that has one and still a decent price, I'd be okay with it, or possibly sell it to help with the purchase price. Actively do NOT want a cab.
I've been avoiding looking at L series tractors almost entirely because I hate the tiny front wheels on them. I've seen those get stuck so easily compared to the M series larger front wheels for 4wd.
I also get the sense that L series is altogether a lighter duty machine, but also smaller overall for the power they have. I'm starting to wonder if the smaller size would be a good thing for the hills that I'll be working on, and also working around and under trees a lot.
My actual question then is this:
Am I correct in avoiding the L series or should I open my mind a little to considering them? I see a lot more L series out there so I have more options to choose from, but I also wonder if that's because everyone has just traded theirs in for a M series.
Thanks for any help!
/ M vs. L series in 45-60 HP range #2
You have identified the main differences between the L series and M series.
You have to make up you mind which set of tractor attributes will serve you best.
The only advantage I see to the L series is potential compatibility with some of your to35 implements.
I've been avoiding looking at L series tractors almost entirely because I hate the tiny front wheels on them. I've seen those get stuck easily.
Posting your location would aid this evaluation.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
I sense the L series is altogether a lighter duty machine, but also smaller overall for the power they have.
The heavier M series are constructed of thicker steel.
/ M vs. L series in 45-60 HP range #3
Ferguson TO-35 Dimensions​
Ferguson TO-35 tractor photo
1954 - 1960
Utility tractor
Series:TO-35
35
Dimensions
Wheelbase:72 inches
182 cm
Length:117 inches
297 cm
Width:63.5 inches
161 cm
Height:57 inches
144 cm
Operating weight:3200 lbs
1451 kg
Ballasted weight:5775 lbs
2619 kg
Ground clearance:13.5 inches
34 cm
Front tread:46 to 80 inches
116 to 203 cm
Rear tread:48 to 76 inches
121 to 193 cm
Ferguson TO-35 Power
Drawbar (tested):30.51 hp
22.8 kW
PTO (tested):32.93 hp
24.6 kW
Belt (tested):33.24 hp
24.8 kW
A Kubota MX series tractor would provide a minor increase in weight, a 50% increase in engine and PTO power and a minor increase in width. Diesel Kubota MX will require fueling less frequently than a gas engine TO35. Big wheels/tires on the MX series.
You will not find a more
satisfied tranche of tractor owners than those operating Kubota 'Grand L' tractors. The MX is an economy tractor, the Grand Ls are deluxe models in the same weight range. If you will tractor into your 70's as I have, the higher acquisition cost of a Grand L will be offset by greater comfort and ease of operation as you age.
Unusally for an economy tractor the current MX series have adjustable rear wheel/tire spreads with R4s. The Grand L tractors have featured adjustable rear wheel/tires spreads for at least the last two interactions spanning twenty years. If you widen the wheel stance you will leave tire tracks behind the tractor if your existing implements are used
/ M vs. L series in 45-60 HP range #4
What kind of haying do you plan on? For what it's worth I just got a new field to hay and worked it the last eight days with a square baler behind my MX and never put it in 4wd, and the MX is on R4s, while working slopes that laterally would have instantly rolled the tractor. It's really not a lot larger physically than the L, probably a little less than half way to an M.
If you're making squares the L47xx is probably fine, I wouldn't go any smaller for weight and power. MX would be my choice for a small square baler but anything else I think you need to go up to the M, and really 70+ engine if you're pulling a large round baller in hilly terrain is probably what you will need.
/ M vs. L series in 45-60 HP range #5
1954 - 1960
Utility tractor
Series:TO-35
35
Dimensions
Wheelbase:72 inches
182 cm
Length:117 inches
297 cm
Width:63.5 inches
161 cm
Height:57 inches
144 cm
1451 kg
2619 kg
34 cm
116 to 203 cm
121 to 193 cm
A Kubota MX series tractor would provide a minor increase in weight, a minor increase in engine and PTO power and a minor increase in width. The weight increase would not be discernible during operation.
If HST I think power would be barely noticeable over the geared MF as well, but an L series would be at a real disadvantage compared the the MF I think.
/ M vs. L series in 45-60 HP range #6
The "L" series includes a WIDE range of sizes, weights, horsepower and features. At the top end, with the "Grand L" models over about 40 hp, they are largely comparable to some of the smaller utility models in power and weight.
I used a 46 hp Grand L for more than 15 years. It was not an "altogether lighter duty machine" at all... it moved many yards of dirt and hundreds of trees we cut.
With today's shortages, I don't know what you'll find when you go shopping, but I wouldn't turn up my nose at one of the bigger GL models if you find one. Worth a least a look.
/ M vs. L series in 45-60 HP range #7
having owned L, MX, & M series, my take is that MX tries to bridge the L & M gap, but never really rises to the occasion & is always a wanna be M (at least my experience). i still consider the MX as a smaller cut tractor. the M series is in a league by itself for hd utility use. but expensive. try to find the XX40 series & avoid def, etc best regards
/ M vs. L series in 45-60 HP range #8
The Grand Ls all have the same frame..
Differences:
Front axle - L3560 & L4060 have a lighter front axle (and hence can only spec the small & medium loader but not the big one)
Tires - the more HP the bigger the tires at a few points
Engine - Bigger engine, turbo & intercooler at various points
3pt ball ends - L6060 & one or 2 of the bigger ones have Cat 1/2 ball ends on the end of the 3pt
Weight - Engine & tires, at best its 300 maybe 400lbs between a L3560 & L6060 all due to Engine & tires
Length & Height - entirely due to tires
My Grand L is the right size for me. Wish I had a L6060 instead of L4060 at times. More traction would be cool, but hauling & maneuvering a bigger heavier machine would not.
Only you (OP rather) can decide if bigger & heavier with more traction outweighs maneuverability & utility. Think he's already aware of the differences & it just comes down to evaluating his needs.
/ M vs. L series in 45-60 HP range #9
I replaced my mx5100 with a m6060. My opiniun is that I need a tractor to do work so I went with a more industrial model. In the long term, I am much happier with a "work" tractor.
/ M vs. L series in 45-60 HP range #10
Trust me, my L6060 is enormously more powerful than either of the MF 35 diesels that I once owned. Even noticeably more powerful than the 2007 MF 533 with 202 CI Perkins engine that I also once owned.
No comparison to any of the three regarding power convenience or work output, but it uses much more fuel than any of the MFs.
SDT
All super helpful stuff, thanks everyone.
One thing I'm still curious about is the hydraulics--is there a general difference in hydraulic flow rate between L and M series? I see such a huge range of flow rates across the different years and models as I look at them. Not sure how much I'd need a higher flow rate, but it would be a nice option to have.
/ M vs. L series in 45-60 HP range #12
As usual that can be one of those funky things. Some flow rate stats are presented as total hydraulic flow, others as usable hydraulic flow. Most machines have 2 pumps, a single pump with 2 chambers & outputs or a single pump that goes to a priority or splitter valve. Any way you slice it 20-50% of system flow goes to steering (maybe brakes too) & isn't otherwise usable for a loader or other implements.
All the L60 Grand Ls have a little under 10gpm usable and around 15gpm total system flow. A MX5800 has less than 1gpm more on each of those numbers. A M7060 has about 2 more it looks like. Probably mot enough to notice. I bet the M loaders actually move slower due to larger cylinder volume.
/ M vs. L series in 45-60 HP range #13
(Generally speaking....) Tractor hydraulic flow is for intermittent, not continuous use. Steering, FEL movement, hydraulic tilt, hydraulic Top Link control, scarifier extension/retraction etc. Power for implements is provided mechanically, through the PTO shaft.
The exception are Orchard & Vineyard tractors, which have high capacity hydraulic pumps to continuously operate high capacity sprayers.
Skid Steer pumps are relatively high capacity for much greater flow to continually power hydraulically operated implements which are mechanically continuously powered on a tractor. Skid Steers do not have a PTO.
/ M vs. L series in 45-60 HP range #14
I want something a little more powerful to run my flail mower without bogging down.
Transmission choice will have no effect on power transmission to PTO powered implements.
/ M vs. L series in 45-60 HP range #15
If stationary. Like a PTO generator, a chipper or something.
Once it start moving, that were the differences between transmissions will be very noticeable. One can't really mow anything just sitting still, right?
/ M vs. L series in 45-60 HP range #16
Jeff, you feeling okay? You're slipping today.
From the OP ;)
/ M vs. L series in 45-60 HP range #17
ANy of the larger L's, the MX or the small M's will be leaps and bounds ahead of an old ferguson.
The MX IS a good bridge between the L's and the M's. But once you get above the 5060 model....they are basically the same tractor...the GrandL's just cost more because all the bells and whistles. But they ride on the same sized AG tires. (There is a difference in the R4's though) as the MX has 12-16.5 and the Grand L's are 10's.
You havent mentioned your transmission of choice though. IF HST is important to you, that CANNOT be had in an M. The Larger GL's and the MX are as big as kubota goes with a HST. I am dreaming of a day when I can get a HST tractor riding on larger 20" or 24" front rims
/ M vs. L series in 45-60 HP range #18
The shuttle shift on the M4 is basically a HST in your hand. But he's on a manual tractor now so a clutch wont be mystery...unlike most kids these days.
/ M vs. L series in 45-60 HP range #19
What brand/model orchard/vineyard tractors are you talking about??
None of the orchard/vineyard tractors sold around here have larger hydraulic pumps than the other same size farm models, including mine!
SR
/ M vs. L series in 45-60 HP range #20
I passed 25 years in the employ of two Calfornia wineries.
At both wineries the O&V tractors were Deeres.
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2018 ADDCO ROAD SIGN DH1000-ALS (A60736)
2018 ADDCO ROAD...
2009 FORD F-150 (A60736)
2009 FORD F-150...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
