Dmacleo
- Joined
- Sep 11, 2020
- Messages
- 1,569
- Location
- Etna, Maine
- Tractor
- 2010 MF GC2400 Owner, 2012 MF1532 User
least you didn't break half the mount off deck like I did LOLIn the process of fixing one of my 2325 MMM wheels... apparently the snap ring fell off, then the washer, then the wheel shaft dropped down. Had no idea until I raised the MMM and parked the tractor, noticed the front right (pivoting) wheel was hanging down. Have no idea how that happened, but will replace washer & snap ring...
heck of a time heating, aligning, welding to get brackets close to correct angles so wheel sits where it should on cement and maintains front to rear level. mine looks odd now due to ribbon bends in mount but axle sits w/i 1/16 inch of stock now.
mine was left rear, only time I ran full throttle 4wd low range when mowing. caught wheel on landscape timber as cutting corner. didn't even really feel it. almost (7/8 was tore) fully tore one section of bracket and bent the other.
