My Place: a CAT, Mahindra, and Ducks
   / My Place: a CAT, Mahindra, and Ducks #481
My 2003 Cummins doesn't use DEF, but has chips. Even an electronic throttle. Nothing I own uses DEF. I hope to keep it that way.
hugs, Brandi
My 05 has a lot more sensors than I’d like it to have. If I could find a early 90s truck that had working ac, wasn’t junk, and had a mechanical injection Cummins I’d probably buy it.
They are out there. Ya just gotta look.
hugs, Brandi
   / My Place: a CAT, Mahindra, and Ducks #486
Me 3 !!!(y)
Good job on shoring that blade up. I must admit, I was suspect of it prior, but figured you might just be leveling smooth dirt with it. But now it should be good to go for most applications. Watch out for roots.
   / My Place: a CAT, Mahindra, and Ducks #487
Me too, even though most of what you do is beyond me.(y)
Cheers,
Mike
   / My Place: a CAT, Mahindra, and Ducks #488
I like your blade. I saw a crew working along the rode that used a large metal pipe to smooth out the ground. I'm guessing it was about a 10 inch metal pipe about 8 feet long. They cut a hole in the side of the pipe for the teeth of the bucket to fit into, and ran a chain from the ends of the pipe to the bucket to hold it in place. The results where very nice!!!!
2015 Honda Accord Sedan (A55758)
2015 Honda Accord...
Lockwood 480 Pecan Harvester (A55301)
Lockwood 480 Pecan...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
(INOP) 2005 GENIE S-65 MANLIFT (A52705)
(INOP) 2005 GENIE...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2007 John Deere 624J Wheel Loader (A54865)
2007 John Deere...
