Battery based electric vehicles of today and tomorrow.
Status
Not open for further replies.
/ Battery based electric vehicles of today and tomorrow. #4,322
The vessel will operate within the area of Kiel, between Reventlou and Wellingdorf and has a capacity of 140 pedestrians and 60 bicycles. It is expected to enter service at the end of the year 2020. The project is supported by the state department of traffic and digital infrastructure of the German government as part of the clean-air-program.
Yup, and the entire time those pedestrians & bicyclists are on there they are either peddling or walking in a hamster cage to generate the power necessary, correct? 🙂😉🙃
/ Battery based electric vehicles of today and tomorrow. #4,323
Larry Caldwell said:
One huge energy source that is almost undeveloped is geothermal. The whole world is waking up to that thanks to the demand for battery lithium.
I've was around geothermal plants in my youth, do you know what a maintenance nightmare they are? The Sulphur, etc destroys vanes, piping, boilers, etc, etc. How much do you save if you are changing out parts all the time to keep it running? How much (in the way of emissions) crap, as many call it, is put up in the air producing the spare parts? Since you probably live close to El Centro (from Salton sea inference) check with the maintenance folks that work on those dirty plants around there.
/ Battery based electric vehicles of today and tomorrow. #4,324
Yes, the limit on geothermal has been getting them to run profitably. If processing geothermal brine is a profit center, they move from being a power generation plant to being a co-gen facility. Geothermal is well understood but, as you point out, it's outrageously expensive to run. Brine mining might tip the scale a bit. Nobody is in the business of making electricity for free.
Like it or not, I think we're going to move away from fossil fuels. Geothermal is one of the power options, but so far it has not been profitable. It has the advantage of being up 24/7, except when the plant breaks down. :oops:
What are our options? I'm not a fan of solar because of things like night, clouds, and snow storms. Wind would be an option if we had long distance electrical transmission, but we don't, and nobody is building it. River hydro is built out, and tidal hydro has few practical sites. Nuclear has an uphill political battle.
As others have pointed out, it makes no sense to convert the world to electricity and then use fossil fuels to generate the electricity. My crystal ball gets fractured any time I try to guess the future. Maybe power generation will become a cottage industry, with solar cells on every house. That might keep the family flivver running, but it's not going to run steel mills.
/ Battery based electric vehicles of today and tomorrow. #4,326
A lot of shopping centres and car parks have free fast charging bays here
Almost no shopping center has fast charging bays, at any price.
What is fairly common (and near useless, but "it looks like one is helping") is a 7.2kW J1772 L2 EVSE. It is not a charger, is Electric Vehicle Service Equipment. It is little more than a smart extension cord. These cost about $500 for hardware plus installation.
... and if we went for an electric car we can get a deal with the power companies for $1 a day to charge, unfortunately the charging platform is cost prohibitive to make it a deal for me and we live too far away from charging stations.
I seem to recall seeing that a Tesla charger is about $20k.
A Tesla Wall Connector is $550 for up to 17 kW. Not all Teslas can accept the full 17 kW. Requires a 240VAC 90A circuit. If you install close to your distribution panel then parts will be less than $100. A Tesla Wall Connector comes with the car. My old one was 9.6kW for the full abilities of a NEMA 14-50 (the common RV 50A hook up) but newer may be a bit less.
Tesla does not sell Superchargers to individuals or companies. Based on construction permit filings it is estimated to cost $50,000 per charging bay. Building something safe enough idiots with drivers licenses can make 120 kW (newest is 250kW) electrical connections is not cheap or easy. 400V DC at 300A for 120kW.
/ Battery based electric vehicles of today and tomorrow. #4,327
I've still never seen a charging station.
/ Battery based electric vehicles of today and tomorrow. #4,328
*in person
I can't charge a vehicle via a photo.
/ Battery based electric vehicles of today and tomorrow. #4,329
My Model 3 SR+ Red Tesla is scheduled to be delivered on the 15th. Delivery date was moved from Oct18-Nov07 to this 15, I'm pumped :)
Went with the SR+ because in Québec, we get a $8,000 payback (on top of the $5,000 the federal gives at purchase) on any electric vehicle below $60,000 MSRP. Model 3 LR is over that amount and it then become way too expensive compared to the SR+.
My daughter bought one last spring and we calculated that going back and forth to the cottage (200 KM total), it costs her (well, me since she charges at home lol) the same amount it cost my old SUV (Tucson 2013) for the prorated cost of a oil change for 200 KM :oops: So actually, the cost of gas saved is 100% saving :cool:
/ Battery based electric vehicles of today and tomorrow. #4,331
On a similar note, I'm looking next spring to assemble a 'geothermal' air conditioning by pumping water from the bottom of the lake (it's source fed so the lake bottom is almost always cold) into an old radiator near the cottage that would then circulate that cooled air into the cottage. Water leaving the radiator will be returned to the lake.
Within limits that could work as weak heat source to keep a building above freezing. Throw in a water source heat pump if you ever need all season comfort
/ Battery based electric vehicles of today and tomorrow. #4,333
I have looked into that. Suggest you throw a loop into the lake. Pump your clean working fluid through the pipe. Keeps the inside of your radiators clean.
The equations for heat transfer are not hard. Many geothermal sites have done the math for you.
Edit: You can not suck water up a pipe higher than 25' or so. Somewhere around 30' is the physical limit under ideal conditions with a perfect vacuum to draw it up. But if you have a loop you can push your working fluid most any height. A loop into the lake and back out.
Then once you have had your fun, replace the radiator with a geothermal heat pump.
/ Battery based electric vehicles of today and tomorrow. #4,334
saw a photo from asia? where a guy had been using one of the quick charge stations for all day parking, which is a big no no.
the photo i saw showed that someone had disassembled his front end etc and left the parts in a pile
/ Battery based electric vehicles of today and tomorrow. #4,335
Do you think that he'll do it again? Some people are more important than the rest of us. Years ago I went deep sea fishing with a group from work. One guy showed up late with his new GF, so left his car in a no parking zone. When we got back his car had been towed... I've always wondered how impressed that made his date.
/ Battery based electric vehicles of today and tomorrow. #4,336
Tesla charges more for an idle vehicle at Supercharger than to charge.
/ Battery based electric vehicles of today and tomorrow. #4,339
This sounds like it could make a good wheel mounted motor. A doubling of the torque sounds positive.
All I see is happy-talk and bad-mouthing others at the site and in the video. YASA | Electric Motor Manufacturers | Automotive OEM | YASA Ltd didn't provide any more.
Wheel-mounted motors are a bad idea.
Status
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
BOOM FOR HYDROVAC TRUCK (A68842)
BOOM FOR HYDROVAC...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
CAT 345CL Sprockets (A68134)
CAT 345CL...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2019 Ford F-450 Ext. Cab Knapheide Service Truck with Liftgate (A66736)
2019 Ford F-450...
