Battery based electric vehicles of today and tomorrow.
Status
Not open for further replies.
   / Battery based electric vehicles of today and tomorrow. #4,331
One huge energy source that is almost undeveloped is geothermal. The whole world is waking up to that thanks to the demand for battery lithium.
On a similar note, I'm looking next spring to assemble a 'geothermal' air conditioning by pumping water from the bottom of the lake (it's source fed so the lake bottom is almost always cold) into an old radiator near the cottage that would then circulate that cooled air into the cottage. Water leaving the radiator will be returned to the lake.
Within limits that could work as weak heat source to keep a building above freezing. Throw in a water source heat pump if you ever need all season comfort
   / Battery based electric vehicles of today and tomorrow. #4,333
I have looked into that. Suggest you throw a loop into the lake. Pump your clean working fluid through the pipe. Keeps the inside of your radiators clean.
The equations for heat transfer are not hard. Many geothermal sites have done the math for you.
Edit: You can not suck water up a pipe higher than 25' or so. Somewhere around 30' is the physical limit under ideal conditions with a perfect vacuum to draw it up. But if you have a loop you can push your working fluid most any height. A loop into the lake and back out.
Then once you have had your fun, replace the radiator with a geothermal heat pump.
   / Battery based electric vehicles of today and tomorrow. #4,334
saw a photo from asia? where a guy had been using one of the quick charge stations for all day parking, which is a big no no.
the photo i saw showed that someone had disassembled his front end etc and left the parts in a pile
   / Battery based electric vehicles of today and tomorrow. #4,335
Do you think that he'll do it again? Some people are more important than the rest of us. Years ago I went deep sea fishing with a group from work. One guy showed up late with his new GF, so left his car in a no parking zone. When we got back his car had been towed... I've always wondered how impressed that made his date.
   / Battery based electric vehicles of today and tomorrow. #4,336
Tesla charges more for an idle vehicle at Supercharger than to charge.
   / Battery based electric vehicles of today and tomorrow. #4,339
This sounds like it could make a good wheel mounted motor. A doubling of the torque sounds positive.
All I see is happy-talk and bad-mouthing others at the site and in the video. YASA | Electric Motor Manufacturers | Automotive OEM | YASA Ltd didn't provide any more.
Wheel-mounted motors are a bad idea.
Status
2355 (A58376)
2355 (A58376)
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
MMS MS36C Skid Steer (A57149)
MMS MS36C Skid...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2008 John Deere 310SJ Backhoe (A59213)
2008 John Deere...
