Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,058
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Been debating on a new flexwing mower. Specifically been noodling with the idea of a Schulte....but the Rhino 4150 keeps sticking in my head too.
The Rhino has an option of having a 'Bowtie' blade holder instead of the round stump jumper. My current flexwing simply has a (approx) 8" x 24" rectangular "bowtie" (without the bow!!) that hold the blades.
Looking at the Rhino I've been (over) thinking....stump jumper or bowtie, stump jumper or bowtie.... then it dawned on me.
I recently put new blades on my mower. Supposedly the prior owner NEVER put new blades on it making them maybe 20 years old. I had to get my diamond blade out for two of the six blades to literally cut the bolt in half to get that stupid nut separated so I could get the old blade off & new blade on.
Then it dawned on me.... (and actually this is a bit of a question since it's been years since I've had/seen a mower with the round pan)
Do you have EASY access to the bolts if mounted to the round pan such that you can reach in/up there with a 7" grinder to cut the bolts off?
With my current setup, I was able to raise mower height, lift wings up (and tie them back so they'd not droop/fall down) and was able to reach the UPPER side of the mounting bar to cut between the nut and lock washer to remove them. Do the bolts on the stump jumpers tend to have the edges of the pan be higher than the bolt so the pan gets in the way or is it a flat surface??
It just dawned on me that this simple issue could alone be a deciding factor for me. I would NOT want to get something if the spacing of it made it impossible to get under there with a grinder. That would have stopped me in my tracks. (I don't have any cutting flames so grinder was my only option)
