Low Power BX2200
   / Low Power BX2200 #11
Maybe I just have more expectation of this 2200. My G1900 has no problem at all with a bagger. The 2200 has trouble even without the bagger.
I think it is probably the weight and mower width that make the difference you are seeing. BXs are surprisingly heavy. My BX1500 with belly mower is about 1500#. Your 2200 with bigger mower is probably around 1700#. I believe these are at least 500# more than the G1900. Its a harder climb for the "heavyweights" ;). Then theres the probably wider mower on your BX2200.
   / Low Power BX2200 #12
That combination is probably just using all its power
Dad and I both have BX2230's that we use mowers and baggers. His mower deck is 60" and he uses a Kubota bagger. My 54" mower goes into a JD self dumping hopper(that someone setup for a BX) with a blower. My setup definately weighs more than dad's. They have enough power to run the mower deck and the bagger blower. Jon
   / Low Power BX2200 #13
Lots of variables. You dont mention hills. - - The OP is perceiving reduced power cutting grass going uphill with a bagger. How thick is the grass? How steep is the slope? Around this part of the country we have had good rain and growing conditions for grass. Turf tends to get thicker and take more power to cut as good conditions persist throughout the summer. This is the OPs 1st season with his BX2200 and his basis for comparison is with a smaller lighter tractor mower that has almost the same HP. It could be a fuel problem, but he has addressed that with fuel and filter changes. - It could be that the conditions just exceed the HP margin of the 2200 and he just needs to let up a little on the go pedal as he goes up the hill.
   / Low Power BX2200 #14
Not really. Ran my BX for 15 years through some really heavy stuff and NEVER wanted for power. Would eat anything ot could drive over. Something definitely wrong if it's bogging as the OP describes.
   / Low Power BX2200 #15
So you went slow.
   / Low Power BX2200 #16
So you went slow.
I'm old enough to think slow has its virtues. But the BX cut way faster than any lawn tractor I ever had. Seriously, the limit was how fast the deck could clear the discharge, never power from the engine.
   / Low Power BX2200
Slight incline, not really a hill and the grass it not very thick. I'm cutting at 4" and I can't be cutting more and an inch or two off. Even with the PTO off the RPMs go down more than I think it should as I go up the slight incline.
I'm thinking it has to be a fuel problem or a lack of fuel. Lift pumps are pretty cheap so I might just replace that. I will also change the filters and pump out all the fuel again just to rule out the fuel system.
   / Low Power BX2200 #18
Yes. That is sounding like inhibited fuel flow. My BX1500 has 2 fuel filters; one under the belly and another up by the injection pump. Check for a second filter if you havent already. I have had good luck with my lift pump. Its original at ~3500hrs.
   / Low Power BX2200 #19
Have you been able to find the problem yet?
   / Low Power BX2200
I've got the new pump and another set of filters but havent had a chance to install them yet. I hope to get to it this weekend. I've been cutting my grass the past several weeks and the tractor still seems to be low on power. I raised the RPM governor just a bit and it didnt help.
I talked to my x-father in law (who i bought it from) and he said that he had never experienced low power. He looked at the incline where I notice the problem and said that "thats not even a hill". lol
I plan on completely draining all the fuel, blowing out the return lines, replacing the filters(again) and installing the new lift pump.
UNUSED PABREAK DB220 - 84" HYD DOZER BLADE (A57193)
UNUSED PABREAK...
Caterpillar 299D3 (A53317)
Caterpillar 299D3...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
2016 Dodge Ram Promaster 1500 (A53317)
2016 Dodge Ram...
Hose Reel (A53424)
Hose Reel (A53424)
