Loud bang and the clutch stopped working ....
/ Loud bang and the clutch stopped working .... #1
Navvet
NC
Mahindra 4025 Bobcat S185 John Deere X495 John Deere 6x4 Gator
Mahindra 4025 4wd with 250 hours on it. Been a great tractor so far.
Was out on my road today doing some minor work, 1st gear, low range, 1200rpm, when I heard a moderately loud bang.
Pushed the brake and clutch and nothing happened. Tractor kept on rolling.
Slowed down when I reduced the throttle and finally stopped when I popped the tranny out of gear.
No obvious external damage and the clutch still controls the PTO, just won't disengage the transmission.
I figure I’ll start to split the tractor to check for internal damage in the clutch housing.
Any tech guru's have any suggestions on what to look for ?
/ Loud bang and the clutch stopped working .... #2
Before splitting, is there a inspection plate in the bottom of the bell housing?
Pto probably works of a switch on the pedal.
No inspection plate ...
The Transmission and the PTO are a dual clutch system off of a single pedal. Upper half of the pedal travel is the transmission and the lower is the PTO (so you can change gears without interrupting the PTO operation).
/ Loud bang and the clutch stopped working .... #4
I see, I was thinking it had independent PTO not live. Hate they did not put a inspection plate. Not that it would not change the need to split but at least you would have a idea of what you needed.
Yea, was hoping to find some one who has seen a similar problem and might have some tips.
Usually a good idea to pick the brains of those with more experience ....
Almost got the tractor ready to split, can't wait to see what's broken ...
/ Loud bang and the clutch stopped working .... #7
My 4110 is an independent PTO so no dual clutch but when my tractor had the same symptoms 3 times over the years it was 1 of the pressure plate thru bolts snapped - not the bolts that hold the plate to the flywheel, one of 3 bolts that hold the face plate against the springs between the cover and also hold one of the fingers the release bearing rides on. I tried to find just a new bolt, even at a clutch rebuilder in Nashville but no luck. Had to get a reman pressure plate.
/ Loud bang and the clutch stopped working .... #8
Maybe: Kentucky Driveline and Clutch-they are just south of Louisville, KY
I think I found my problem, surprisingly I didn't see any thing else damaged.
/ Loud bang and the clutch stopped working .... #10
That's a sorry excuse for a clutch disc. That kind of failure just shouldn't happen if the clutch is sized to the engine torque.
I thought so too until I realized that same clutch is used in a Case/IH 523 which has 11 more HP. I think its more of a one-off failure, especially with only 250 hours on the machine.
/ Loud bang and the clutch stopped working .... #13
That's how they build things now in the "Save the Planet" era. šŸ˜
/ Loud bang and the clutch stopped working .... #14
FWIW, r.e. that style of clutch: The guy who installed my replacement Kioti clutch used the pad style saying he'd found over the years that they are more robust than disc clutches. For reference he's a 74 yr old, lifetime tractor mechanic from a JD dealership background. I hope he's right. Clutches are very generic parts in tractors that often cover lots of brands/models.
Murphy's law applies to many mechanical parts?
Yes, I was amazed to see that the same clutch plate is listed as a replacement on an 80hp Case/IH 845. Should defiantly be strong enough for my little 40hp Mahindra.
/ Loud bang and the clutch stopped working .... #16
You mean it has the exact same part number??
SR
Welp, 3 days for shipping and 4 days grunting and tugging (and a new Harbor Freight 2 ton engine hoist) and I'm up and running again. I also changed the oil and hydraulic since I had it apart as well as full greasing and fixed some routing and protection issues with the wiring and hydraulics.
Dealer quoted me $4k to $5k and 30 to 90 days after they get the parts (Expected 3-4 months for parts delivery).
My total cost including clutch, release bearing, filters and fluids, plus a new engine hoist; less than $700.00
/ Loud bang and the clutch stopped working .... #19
Whatever got into them to use a radiator fan for a clutch plate?
/ Loud bang and the clutch stopped working .... #20
I think it's more likely made like that to save pennies/dollars and increase profit....
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
2013 Ram 3500 Utility Flatbed Truck (A60352)
2013 Ram 3500...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
2022 Horizon (A55973)
