Loud bang and the clutch stopped working ....
   / Loud bang and the clutch stopped working ....
That's a sorry excuse for a clutch disc. That kind of failure just shouldn't happen if the clutch is sized to the engine torque.
I thought so too until I realized that same clutch is used in a Case/IH 523 which has 11 more HP. I think its more of a one-off failure, especially with only 250 hours on the machine.
   / Loud bang and the clutch stopped working .... #13
That's how they build things now in the "Save the Planet" era. 😏
   / Loud bang and the clutch stopped working .... #14
FWIW, r.e. that style of clutch: The guy who installed my replacement Kioti clutch used the pad style saying he'd found over the years that they are more robust than disc clutches. For reference he's a 74 yr old, lifetime tractor mechanic from a JD dealership background. I hope he's right. Clutches are very generic parts in tractors that often cover lots of brands/models.
Murphy's law applies to many mechanical parts?
Yes, I was amazed to see that the same clutch plate is listed as a replacement on an 80hp Case/IH 845. Should defiantly be strong enough for my little 40hp Mahindra.
   / Loud bang and the clutch stopped working .... #16
You mean it has the exact same part number??
SR
Welp, 3 days for shipping and 4 days grunting and tugging (and a new Harbor Freight 2 ton engine hoist) and I'm up and running again. I also changed the oil and hydraulic since I had it apart as well as full greasing and fixed some routing and protection issues with the wiring and hydraulics.
Dealer quoted me $4k to $5k and 30 to 90 days after they get the parts (Expected 3-4 months for parts delivery).
My total cost including clutch, release bearing, filters and fluids, plus a new engine hoist; less than $700.00
   / Loud bang and the clutch stopped working .... #19
I think I found my problem, surprisingly I didn't see any thing else damaged.
Whatever got into them to use a radiator fan for a clutch plate?
   / Loud bang and the clutch stopped working .... #20
I think it's more likely made like that to save pennies/dollars and increase profit....
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
1267 (A50490)
1267 (A50490)
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2021 JCB 3TS 8T SKID LOADER (A51242)
2021 JCB 3TS 8T...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
