Loud bang and the clutch stopped working ....
   / Loud bang and the clutch stopped working .... #1
Navvet
NC
Mahindra 4025 Bobcat S185 John Deere X495 John Deere 6x4 Gator
Mahindra 4025 4wd with 250 hours on it. Been a great tractor so far.
Was out on my road today doing some minor work, 1st gear, low range, 1200rpm, when I heard a moderately loud bang.
Pushed the brake and clutch and nothing happened. Tractor kept on rolling.
Slowed down when I reduced the throttle and finally stopped when I popped the tranny out of gear.
No obvious external damage and the clutch still controls the PTO, just won't disengage the transmission.
I figure I’ll start to split the tractor to check for internal damage in the clutch housing.
Any tech guru's have any suggestions on what to look for ?
   / Loud bang and the clutch stopped working .... #2
Before splitting, is there a inspection plate in the bottom of the bell housing?
Pto probably works of a switch on the pedal.
No inspection plate ...
The Transmission and the PTO are a dual clutch system off of a single pedal. Upper half of the pedal travel is the transmission and the lower is the PTO (so you can change gears without interrupting the PTO operation).
   / Loud bang and the clutch stopped working .... #4
I see, I was thinking it had independent PTO not live. Hate they did not put a inspection plate. Not that it would not change the need to split but at least you would have a idea of what you needed.
Yea, was hoping to find some one who has seen a similar problem and might have some tips.
Usually a good idea to pick the brains of those with more experience ....
Almost got the tractor ready to split, can't wait to see what's broken ...
   / Loud bang and the clutch stopped working .... #7
My 4110 is an independent PTO so no dual clutch but when my tractor had the same symptoms 3 times over the years it was 1 of the pressure plate thru bolts snapped - not the bolts that hold the plate to the flywheel, one of 3 bolts that hold the face plate against the springs between the cover and also hold one of the fingers the release bearing rides on. I tried to find just a new bolt, even at a clutch rebuilder in Nashville but no luck. Had to get a reman pressure plate.
   / Loud bang and the clutch stopped working .... #8
Maybe: Kentucky Driveline and Clutch-they are just south of Louisville, KY
I think I found my problem, surprisingly I didn't see any thing else damaged.
   / Loud bang and the clutch stopped working .... #10
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
434669 (A48836)
434669 (A48836)
