Oil Gearbox Kubota B2320 UDT, Superudt or SuperUdt 2
   / Oil Gearbox Kubota B2320 UDT, Superudt or SuperUdt 2 #1
Conchal Sao Paulo
Kubota B2320
hi people, i will change oil on my tractor kubota B2320, but i dont know whats oil used in gear box, can use Kubota UDT, Super UDT, or Super UDT2?, here in Brazil have, Mobil, John Deere Hygard, Texaco and Shell, which of these oil good for my tractor? can someone help me?
Mobil 424: Kubota UDT
Mobil 426: Kubota UDT
Mobil 428: Kubota Super UDT 2
John Deere HyGard: Kubota UDT
Texaco THD: Kubota UDT
Shell Sprirax S4 TXM: Not Specification for Kubota UDT
Can someone help me please?
Thanks.
   / Oil Gearbox Kubota B2320 UDT, Superudt or SuperUdt 2 #2
Your B2320 with the hydrostatic transmission(gearbox) will be happiest with an Super UDT fluid-quieter operation and better cold weather performance.
In warmer climates,UDT is OK,but Super is best and worth the money.
Good Luck!
Good Luck!
which oil do you think is better, Shell, Mobil, Texaco, or John Deere Hygard?
Thanks
   / Oil Gearbox Kubota B2320 UDT, Superudt or SuperUdt 2 #4
Thanks
Are Kubota UDT or Super UDT2 not available in Brazil, or are they lot more expensive?
   / Oil Gearbox Kubota B2320 UDT, Superudt or SuperUdt 2 #5
All the above fluids are good stuff,and will serve you well.
I still like the Kubote Super UDT2 or equivalent-the Mobil 428 in your case-a better synthetic.
Just do your maintenance-you'll be fine!
Great, I'm going to buy mobil 428.
Thank very much.
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2020 DRAGON ESP...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
