Cahaba Valley Farm
Veteran Member
Don't use it in either of my M9's. I use Chevron All Weather THC Synthetic which is actually a bit more than SUDT anyway. 30 gallons to change both.
Out of curiosity why?
That makes sense.because it has better cold temperature flowability and it's orange in color unlike Kubota fluid which is clear. Chevron is easier to see on my dipsticks.
If you don't mind me asking where you located?It gets cold here, real cold, like it is today (15F). I sill always warm the units up when I use them anyway. I'd say with 6K and 3K meter hours on them, I'm doing something right. I also use Shell Rotella T6, 5-40. Engines crank easier in cold temps.
Why?If I owned hydrostatic units, I'd only use Kubota SUDT but all mine are gear drive.
You need to order the coupon based on your tractor size. Small B, BX, LX get $10 off of One 5 gallon bucket of Kubota UDT or Super UDT2 hydraulic fluid - Bigger tractors can get 2 for L models or 3 buckets for M (Excluding M7)... I was going to buy it anyway, why not save some dough?
Kubota Parts Coupon for Hydraulic oil
You’ll be lucky to drain 10 gallons out without individually purging the cylinders. A dry system might take 15.
