Oil & Fuel Kubota Promo; coupon for hydraulic oil.
/ Kubota Promo; coupon for hydraulic oil. #22
Out of curiosity why?
because it has better cold temperature flowability and it's orange in color unlike Kubota fluid which is clear. Chevron is easier to see on my dipsticks. It gets cold here, real cold, like it is today (15F). I sill always warm the units up when I use them anyway. I'd say with 6K and 3K meter hours on them, I'm doing something right. I also use Shell Rotella T6, 5-40. Engines crank easier in cold temps.
Chevron is hard to get for most people but my jobber is a Chevron distributor, Shell too.
If I owned hydrostatic units, I'd only use Kubota SUDT but all mine are gear drive.
/ Kubota Promo; coupon for hydraulic oil. #23
That makes sense.
If you don't mind me asking where you located?
Why?
/ Kubota Promo; coupon for hydraulic oil. #24
You need to order the coupon based on your tractor size. Small B, BX, LX get $10 off of One 5 gallon bucket of Kubota UDT or Super UDT2 hydraulic fluid - Bigger tractors can get 2 for L models or 3 buckets for M (Excluding M7)... I was going to buy it anyway, why not save some dough?
Kubota Parts Coupon for Hydraulic oil
Just received an E-Mail with Kubota UDT2 discount authorization, for 2 five gallon pails.
To apply, I was required to include my tractor model and serial number, apparently for Kubota to ascertain just how many 5 gallon pails I should be entitled to for discounting.
I have an L48 TLB, which according to the manual needs 15 gallons.
They sent me authorization for only 2 five gallon pails.
Are they suggesting that I only should only change 2/3 of the SUDT2?:mur:
/ Kubota Promo; coupon for hydraulic oil. #25
You’ll be lucky to drain 10 gallons out without individually purging the cylinders. A dry system might take 15.
/ Kubota Promo; coupon for hydraulic oil. #26
Thank you for that!
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
WATER TRAILER (A58214)
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
