Just another junk chainsaw
/ Just another junk chainsaw #1,121
I was looking at an Echo CS620P with a 24" bar, any opinions?
Need a step up from my CS490 for bucking some of the bigger Ash trees.
I have an old crafstman 40cc, think I might try and get that one running proper again too as a backup. Only runs when cold and then quits when warm, will start with carb clean and go back to basic settings on carb and adjust from there.
Echo 620 is worth the jump in price about 150 over the 590.
Little heavy for cc size but one of the better 60cc saws out there right now IMO.
/ Just another junk chainsaw #1,123
I was at our local refuse center at the beginning of the summer and just so happened to look into the metal recycling dumpster and there sat this nice looking Husky 345. I ever so subtly grabbed it out of the dumpster and took it home. To my surprise I put a little gas in it and it fired right up!! It had a gas leak so I figured I'd take it to my saw guy to give it a once over. He replaced the junky plastic intake for a metal one and a few other things, ended up costing me $100. HOW'S THAT FOR ANOTHER JUNK CHAINSAW?
Husqvarna 3120 wood ported, unlimited coil, fully adjustable H side carb 3120. 😋.
6 tanks on the new oem ported topend by Jason Egan.
Hard not to buy from the local. I'm selling for him. Pending right now through Fri.
Just so you folks know. The stihl 462 got a redesign and released this year.
Helps to stop breaking pistons I was told.
TS = this was changed April 2021 at Serial 190015190 ... the current 4 we have are new versions.
These cylinder changes bring it in line with the crankcase changes. Their was enough feedback from western fallers they intend them to be able to run 36" bars... I personally just keep a 28" Duralite/ES Light on them.
If your going to run a 3120. IMO dont use the flocked one I see in almost all of them. Try the OEM option. Foam with cage and use some Belray air filter oil.
What I suggested to local. Worked great.
/ Just another junk chainsaw #1,127
I really liked my 346, and wish that I'd bought a new crank for it rather than listening to the saw shop when they told me the 3 year old saw wasn't worth fixing.
If I was buying a saw today in that size. I would be looking at the echo 4910 or 50.
I ran a woods ported one the other day and it was out cutting a woods ported 346.
Stock no clue yet but the shop south of me has them and looks good I just havent ran it in cut. Usally stock they need a muffler mod at least on a echo. But so do other brands sometimes.
Small husky mount in 3/8LP and extra 325 tip. 6K products picco 3/8LP 7T rim
Limber set up.
/ Just another junk chainsaw #1,130
I bought a 490 this spring to use brushing out property lines. So far it seems like a pretty good saw and I may even use it for limbing this fall.
Those are the budget saw in that size. Real weak performace wise in stock porting. But they are built good.
/ Just another junk chainsaw #1,132
I have an Echo CS490- use a 20" bar for felling, but need to put the 18" bar on for bucking as it overheats cutting big (greater than 30") Ash.
I have had it for 4 years now and it always starts and runs well. Had my local guy tweak the fuel so it runs richer and smoother. Plastic clutch cover is only weak link, but it's cheap if you do break it.
Use mine a lot with all the dead ash around.
/ Just another junk chainsaw #1,133
I have a 590 that I use for heavier work. The trees on my property aren't that big so between the two saws they are all that I need. I also bought their largest brush saw. I would like to run Huskies but they cost about 40-50% more and I can't justify the expense for what little saw work I do.
There's a brand new 490 close in box for 190. But I wont even look being I know I can get a 4910 300ish.
Super nice and light too. All of them in that size.
Checking out the 4910 and some others yesterday at the local makita echo efco dealer.
Picked up some maddog files being my saveedge no longer doing chainsaw files since cv19. They cant get blanks in to cut local.
Pulling crank case halves for folks. For 3 saws. The mess at the end.
2 fly side for 3750 x 2 and 1 pto side for a 3000. Not all in pics.
/ Just another junk chainsaw #1,137
You can almost see the saw through all that dirt. :)
Yep and that is just the dead ones bought for parts. You should see some that come in as runners being used. :ROFLMAO:
Shame folks dont take care of their tools they work with. They want to pay the hourly wage for me to clean to be able to work on that. I'm ok with it but dont like it.
Just 1 of many that come in like that.
I may of finally got my first true parts saw out of all of these I been getting.
Little chrome bore poulan in 54cc that will cut with or out cut the more expensive brands. For 1/4 of the money. They are built alot like the stihl 034.
This one come to me from MI when guy grove done to by the woods ported 3120 and bunch of bars and chains.
He stated it came with a bunch of saws he got and has been setting for 2 years. So it was past onto me.
Scuffing had started on piston and cylinder which is no biggie for me. Found the cheap line for impulse had slipped off.
Lot of wrong fasteners and where muffler leaked with different bolts too.
The pro side had JB on it and appears almost like it had cut [alms at one time.
So thats where I stopped for now.
While grilling yesterday I disappeared into barn to see what was under the JB.
Curiosity how bad it was killing me to know.
Digging JB out I found 2 pin holes but none into the crankcase. Parts she is.
Someones only saw yes it could be used. But not really needed here in that shape. Cutting palms does this in the south. How it happen here no clue. Came from a guy in MI.
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
