Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,989
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
The thread to bend 1" steel got me thinking about this.
Though my project is now done, I went to replace the blades on my flexwing mower. Prior owner said they were original. If true, that means something like 20 years old.
I'm a persistent little cuss..... ultimately getting out the 7" grinder with diamond blade and cut two of them off. I flogged, beat, heated, sprayed, cussed at the other four and they finally came off.
I had a 1 11/16th's 3/4" drive socket. Only had 1/2" breaker.... snapped a 4" Craftsman extension clean in half (when at the time I also worked my 4x torque multiplier into the equation)
Got to thinking that it might be much easier if I had "real" heat, over & above my 'plumbers' MAP gas that I use for soldering.
What kind of tanks & tips (as in ends of the wand for the flame) would you recommend? Also...what issue is there with this likely having to be stored either in the garage or, out in the woods in a clearing where we keep implements? (I'm guessing the wisdom would say keep tanks out there and keep hoses/regulators in garage, which strikes me as logical)
In that other thread, Smokeydog said "Too big a tip can easily draw more acetylene that can come out of acetone solution and media in the tank. Then acetone gets entrained. Causing all kinds of safety issues and damage to your equipment."
Can anyone explain what this means?
(trying to learn some basics before I decide that I want/need to do this....might be smarter/easier to borrow my brother in law every now & then....but I don't like doing that too much)
