Extendable Links 3 Point?? DK5010
/ Extendable Links 3 Point?? DK5010 #1
monteu
NE Kansas
Kioti DK5010
I have a DK5010HS and am wondering where to buy the extendable links I've heard some mention. I have a real pain hooking up to implements. Does anyone have a link for them? Thanks
/ Extendable Links 3 Point?? DK5010 #2
Both my Kioti's bought used came with adjustable, multi hole side links. Plus the OE lift arms that have the top push, slide-out feature that allows several inches of movement. It's gold finished zinc oxide bar steel with like 6 holes for the adjustment pins. My DK35SE was bought from Wichita Tractor in KS by an Abilene man. Other one came from GA same parts on the rear side arms so it must be pretty common?
/ Extendable Links 3 Point?? DK5010 #3
I ordered my DK4510 with Telescopic Link Kit, Part# DKA145 for just under $400
/ Extendable Links 3 Point?? DK5010 #4
I’ve seen adjustable lift arms at one of my local fleet stores. You may try looking for them there.
/ Extendable Links 3 Point?? DK5010 #6
+1 on InyJays post. Kit also comes with telescoping swaybars 😊
/ Extendable Links 3 Point?? DK5010 #7
Maybe just a std full 3pt quick hitch? :unsure:
That or the Euro draft link hooks. :cool:
I think that either would be less money and most likely easier to connect to your implements. (y)
The Euro draft link hooks would replace your existing fixed ball swivel ends and get welded on basically at the same point as the ball swivels are now welded on at. Unlike the std 3pt quick hitch, the Euro end hooks can be used for any width hitch that your current ball swivel ends allow you to connect to. :)
/ Extendable Links 3 Point?? DK5010 #8
I am SO spoiled, I have had the extendable arms for almost 25 years,,
How else would you connect a 1,000+ pound mower to a 10,000 pound tractor??
/ Extendable Links 3 Point?? DK5010 #9
With this.... :)
/ Extendable Links 3 Point?? DK5010 #11
Oh, yea,, I forgot to mention, when that hitch has half as many hours of field work as the arms on my tractor, those hook arms will be either well worn, or replaced.
That looks like an expensive assembly to replace.
I have replaced the ends on the arms of two tractors, they just wear out.
/ Extendable Links 3 Point?? DK5010 #12
That is good, on your side of the "pond",, and now,,
but,,
40 years ago when my tractor was already a half decade old,, that hitch probably did not exist.
and,,
even now, in the USA,, that hitch does not exist.
This Euro style hitch has been available for a looong time.
And yes, it does exist in the USA. Brian at Fit Rite sells them, he is the one in the post just above yours, and so does Agristore, and I'm sure more places sells those.
About wear, when is that going to happen? After 10,000 hours? Yeah probably. The most wear it will get will be at the ball and on the latch, both of which are readily available at a very low cost.
The latch come as a kit with a couple springs and roll pins. It's very easy to replace, with a simple hammer and a punch to take the roll pin out. A set of balls is like $10 or $12.
Heck, even it does need replacing after 5000 hours or something, it's still cheap considering a lot of the pain that this style takes out of the extendable or fixed links. All you need to do, is set the width of the arms for whatever implement you're using, back up and lift the 3 pt. Not need to lift the arms by hand to align and slide on the pins, or to keep kicking the arms till slides on the pin like the fixed ends or to move the implement around by hand to get it square to the tractor.
/ Extendable Links 3 Point?? DK5010 #13
I basically have a similar hitch on my 4105 JD,, Pat's Quick Hitch.
yes, it is nice.
You still have the multi step need of adjusting the width somehow,,
as well as the time of correctly positioning the tractor,,
I like my extendable arms better than the Pats.
but,, wear,, Hmmmmmmm,, a couple thousand hours pulling a dusty plow will destroy any end.
That type duty will even destroy the top link.
Search for a JD CAT2 top link on eBay,, most of the used ones available need the ball end near the attachment replaced.
The ball is falling out due to wear of dust in the top link end.
But, I agree, 10,000 hours of "Gentleman Operation" of a tractor (mowing, moving hay) will show zero wear on any three point hitch end.
/ Extendable Links 3 Point?? DK5010 #14
Adjusting the width is easy, all I need to do is take the pin out of the stabilizers, move the arms to the desired width and put the pit back on the stabilizers in the proper hole. Then I simply back up to the implement, if it's out of square, I just push it a little bit with the tractor and then lower the arms, back up a 1" or 2 and lift the arms. Connect the top link and the PTO shaft without getting the frame of one of those Harbor freight quick hitches in the way and I'm done.
Comparing Pats with these Euro hooks? Yeah, no. It's like apples to oranges. Pats lacks the freedom of movement that a ball joint provides and then break bolts or bend stuff because things need to move in all directions and they can't. Plus, it extends like 4" or something, which is actually a big deal as it may require new PTO shafts or PTO shaft extensions which I fully dislike.
There are people on this forum that have used all types of quick hitches and ended up converting to this Euro style.
/ Extendable Links 3 Point?? DK5010 #15
I am installing the telescoping kitchen arms. It is fairly simple minus one thing. There is one bolt on each pin for the lower arm. This keeps the pivot pin from walking out and rotaing. They will come out but, you will never get them back in. There is not enough clearance with the loader frame installed. I will post pictures later.
/ Extendable Links 3 Point?? DK5010 #16
I do not know why it put kitchen arms. Should have been three point arms.
/ Extendable Links 3 Point?? DK5010 #17
Turns out I just needed more patience. Hitchbarms attached and functional
2006 PETERBILT 379 TRI-AXLE (INOPERABLE) (A67714)
2006 PETERBILT 379...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2017 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
2025 JMR 8ftx4ft Safety Basket Skid Steer Attachment (A66734)
2025 JMR 8ftx4ft...
