Thomas
Epic Contributor
- Joined
- Apr 6, 2000
- Messages
- 32,402
- Location
- Lebanon,NH.
- Tractor
- Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
Cars?! This is a tractor forum? I'd assume OP wants it for his tractor.......A lot of modern cars don't have many safe jacking/jackstand points underneath. There's a few products with the same idea of letting you use one point to lift and hold the car up. None of them are cheap, but neither is damaging the underside of the car or having it fall on you. You'll want two, or four if you plan lift the car totally off the ground to work under it.
I'd check the collapsed height. It might be the picture but these look like they'd be too tall to get under many modern cars.
Oriented correctly on a flat solid surface a concrete block has quite an impressive compressive strength...which is compounded with a cap block......I also cringe when people use cinder blocks for jack stands...
Perhaps if you know what you are doing, line everything perfectly, and use a cap as you say; yet how many people actually do any of the above? Many people stand them on end, where they have that nice concave end for the frame to rest in. They crumble way too easily if you don't have them set just right. Why even take a chance when jack stands are do cheap?Oriented correctly on a flat solid surface a concrete block has quite an impressive compressive strength...which is compounded with a cap block...
You are right...if not oriented correctly for the load they are very dangerous...Perhaps if you know what you are doing, line everything perfectly, and use a cap as you say; yet how many people actually do any of the above? Many people stand them on end, where they have that nice concave end for the frame to rest in. They crumble way too easily if you don't have them set just right. Why even take a chance when jack stands are do cheap?
(Or in my case, own a chain saw and plenty of trees.)
It does seem like a handy gadget, though a bit expensive for what you get.I bought one of those about 10 years ago, but I don't think it was quite that expensive at the time. I carry it in my truck because I don't trust the cheap OEM screw jacks to change a tire on the side of the road.
It is also handy in combination with my floor jack for rotating tires.
Yeah, I've noticed that too. On my wife's car there's what looks like a jack pad underneath, but it's not. Wonder how many owners damaged their cars by trying to jack from that point.A lot of modern cars don't have many safe jacking/jackstand points underneath.
Agree, flats are pretty rare these days, it's been forever since I've had one.Tires have gotten better over the years, I have to wonder how many people even change them. Many just call AAA. Given the mickey mouse spares which come in vehicles, I can't say that I blame them.
I run 10 plys on both pickups because I hate changing tires... usually in the pouring rain.
Just for the record...I've seen on more than one occasion where a car sitting on typical jack stands can be shoved in a direction that will roll the car/truck right off the jack stands as they fall over...won't ever happen with properly placed CMUs...Most people that don’t have better sense than using concrete blocks for jack stands aren’t going to use them right either. Bottom line is concrete blocks should never be used as jack stands.
