CB radios
/ CB radios #21
A lot of truckers were using those until the Coast Guard stepped in. Something about pesky federal laws... That's what caused the switch to MURS.
The closest CG to our area is 400 miles North to lake Michigan.
/ CB radios #23
Unlike previous replies, my CB radios are not noisy and channels crowded above channel 30. Out where we live there is very little CB band traffic, I hear a trucker on the highway once in a while.
I've noticed the same thing. Hooked one up to a power supply & antenna a few years ago and most channels were completely dead, a far cry from what they were like 40 years ago.
/ CB radios #24
I’ve been farming for 15+ years and continue to be frustrated by which “system” to use.
I’ll probably be retired by the time I figure it out.
We use typical small walkie talkies charged while in tractor cab. They work for about 1/2-1 mile, but we have very hilly ground here.
I’d like something better, but it’s so damn complicated.
/ CB radios #25
@Hay Dude , the GMRS system would work the best as you could get some 15 watt mobiles to put in the cabs. You can make them go from tractor to truck pretty easily with extra mounts and power cords that plug into "lighter" power sockets.
If you have fields all pretty close to one another, you could do a simple repeater that runs on solar and battery.
You can use "walkies" with individuals for spotting on loading and the such.
/ CB radios #26
Walkie talkies work pretty well for my situation. I bought 4 of them. They came with 2 chargers.
So far they are OK. When we get out of their range, we switch to cellies, but I still find myself wanting something better, but real convenient.
/ CB radios #27
It's still illegal. There is a reason they are called "Marine" radios
There are still Channels available on VHF that are not Marine Band. Logging Roads here use VHF (FM) Radios as do Police and Road Maintenance Crews. There are even Repeater Towers with Phone Access (if one pays for use) with a Keypad Mike.
Even UHF Channels, but around here VHF is used.
/ CB radios #28
Oh those are the higher 2M freq. and below the WOX public service weather channels. A bunch of background crap out there like packet radio and pulsing tones that are very annoying.
/ CB radios #29
You need to dump those silly 0.5W FRS walkies-talkie radios and go full GMRS.
GMRS goes from 5W up to 50W radios.
Here is the break down of FRS vs GMRS vs MURS
FRS 1-7:
FRS only: 0.5 watt maximum
GMRS: 5 watt maximum (more power here than CB) (y)
Repeater use: prohibited (simplex only)
License/call letters required: only when operating GMRS equipment greater than 0.5 watt (people sometimes use handles on FRS and GMRS; call letters must always be announced on-air regardless)
CTCSS/DCS: allowed
Regulation (FRS): 47 CFR 95.194c
Regulation (GMRS): 47 CFR 95.179
FRS 8-14:
GMRS: prohibited (though most mainstream GMRS HTs do include 0.5 watt coverage of 8-14 for interoperability purposes)
License/call letters required: no
CTCSS/DCS: allowed
This is where GMRS SHINES !
GMRS 15-22 (a.k.a. 550-725)
FRS only: not applicable (typically no kids messing in this area)
GMRS: 50 watts maximum :love: (Power equal to many 2M ham radios.)
Repeater use: allowed; +5 MHz shift (y)
License/call letters required: always; people sometimes use handles on GMRS but call letters must always be announced on-air regardless
CTCSS/DCS: allowed (may be required to access repeaters)
Other restrictions: Channels 19 and 21 (650/700) not permitted for use near the Canadian border
MURS
All channels: 2 watts maximum (n)
Bandwidth: 1-3: 11 kHz; 4-5: 20 kHz
Deviation: 1-3: 2.5 kHz; 4-5: 5 kHz
License required: not required for personal use, may be required if used during the course of duties in a place of business; people sometimes use handles on MURS when conducting personal communications
CTCSS/DCS: allowed
See also:
Family Radio Service - The RadioReference Wiki
General Mobile Radio Service - The RadioReference Wiki
Multi-Use Radio Service - The RadioReference Wiki
/ CB radios #30
<snip>
Why not just a Cell Booster? At least then you are calling Someone. Whole Room Boosters are relatively inexpensive, and when you want those quiet times, just shut it off.
That is often as useless as mammary glands on a male bovine.
I've a booster in my Mississippi house. I've got "dead areas" for my cell phone less than a hundred feet away. So IF I had an accident I couldn't call the wife, or emergency.
Frequently on local roads there are "skips" in cell service.
/ CB radios #31
Not the VHF ones used here, I have both NOAA and Canadian Weather, 5,6,and 7 Haul Channels. I no longer have Tower Access, because the Cell Booster can receive 4G (newer ones are 5G capable)
170.3100 Haul 5
171.0000 Haul 6
165.1800 Haul 7
You need them to Hunt on Logging roads if you don't want to get run over by a 55 ton Log Truck running 5o mph on it's way to the Mill.
/ CB radios #32
FRS 1-7:
CTCSS/DCS: allowed
FRS 8-14:
CTCSS/DCS: allowed
MURS
CTCSS/DCS: allowed
See also:
Appreciate the suggestions.
I find all these numbers, watts, models, specs, very confusing.
Just want powerful hand held walkie talkies that are affordable with about 2-3 miles range in hilly areas without having to get a gubmit rectal exam or be troubled with a lot of hassle.
/ CB radios #35
So those have enough range to talk 3 miles on hilly ground?
/ CB radios #36
They should be able to do it. I've haven't pushed mine more than about 2 miles through hills and timber.
/ CB radios #38
This threads is extremely informative, thanks to everyone for the great info!
/ CB radios #39
You need this Midland 5W to get over hilly regions. Those other Midland radios are more for campers and kids.
GXT67 Pro GMRS 5-Watt
/ CB radios #40
There are also GMRS Base stations. The higher the Watts, the stronger the signal output to cut thru the terrain.
Base Camp,
Midland XT511 GMRS Base Camp | 22-Channel GMRS Radio
The prized 50W GMRS mobile vehicle radio,
Midland MXT500 MicroMobile GMRS 50-Watt Two-Way Radio
There are other brands out there, yet Midland is one of the leaders in GMRS.
BAOFENG is a leader too.
This is my 10W GMRS radio for 1/10th the cost of the Midland.
Plus it gives you AM/FM radio to listen to, NOAA weather and a few more.
It claims 40 miles range. I've gotten a tad further in the line-of-site while standing in the back of my RAM truck bed up on a tall ridge. These will easily go 20 miles clearly and punch thru much of the hills.
I can listen to FM radio music and when a monitored channel for GMRS goes active, the FM turns off and the GMRS channel is then active. Yeah, took a bit to figure this out in the manual too.
The flashlight is a bit blinding. Great for trails or tractor work at night needing to spot places out in the field.
The 2.5A battery is great, yet like anything, the more you talk on high power the more juice it uses. Be sure to have a USB port in the vehicle and tractor.
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
Single Cedar Glider (A65583)
Single Cedar...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
3 Point Hay Tedder (A65640)
3 Point Hay Tedder...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
