Out of room for your attachments? Adding a shelf helps.
   / Out of room for your attachments? Adding a shelf helps. #1
GS1100GK
Knoxville
Kubota BX2370, B2601
Here is where I keep my grapple and bucket when not needed.
   / Out of room for your attachments? Adding a shelf helps. #2
   / Out of room for your attachments? Adding a shelf helps. #4
   / Out of room for your attachments? Adding a shelf helps. #5
Thanks for a good idea.
   / Out of room for your attachments? Adding a shelf helps. #6
I'm reserving comment until I see the supports. I think my grapple would collapse that, wall and all. o_O
   / Out of room for your attachments? Adding a shelf helps. #8
My grapple is 920 lbs, my bucket is 7 feet wide… the rear blade is 850 lbs….Do they come in concrete reinforced with steel :confused:
   / Out of room for your attachments? Adding a shelf helps. #9
OP's grapple is only a 55" or so and only weighs about 250lbs.
My EA 60" weighs 440lbs so it wouldn't require a lot of extra support. If you have a bigger grapple then yes, you would need some serious supports.
   / Out of room for your attachments? Adding a shelf helps. #10
I would want a diagonal brace going down to the sill plate just to make it stronger. There will come a time when engaging or disengaging the grapple to the tractor doesn't go as planned and extra weight is applied to the shelf. It is nice to stack items to make more room though.
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
