Out of room for your attachments? Adding a shelf helps.
   / Out of room for your attachments? Adding a shelf helps. #1
GS1100GK
Knoxville
Kubota BX2370, B2601
Here is where I keep my grapple and bucket when not needed.
   / Out of room for your attachments? Adding a shelf helps. #2
   / Out of room for your attachments? Adding a shelf helps. #4
   / Out of room for your attachments? Adding a shelf helps. #5
Thanks for a good idea.
   / Out of room for your attachments? Adding a shelf helps. #6
I'm reserving comment until I see the supports. I think my grapple would collapse that, wall and all. o_O
   / Out of room for your attachments? Adding a shelf helps. #8
My grapple is 920 lbs, my bucket is 7 feet wide… the rear blade is 850 lbs….Do they come in concrete reinforced with steel :confused:
   / Out of room for your attachments? Adding a shelf helps. #9
OP's grapple is only a 55" or so and only weighs about 250lbs.
My EA 60" weighs 440lbs so it wouldn't require a lot of extra support. If you have a bigger grapple then yes, you would need some serious supports.
   / Out of room for your attachments? Adding a shelf helps. #10
I would want a diagonal brace going down to the sill plate just to make it stronger. There will come a time when engaging or disengaging the grapple to the tractor doesn't go as planned and extra weight is applied to the shelf. It is nice to stack items to make more room though.
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
