Would you give up a tractor for a skid steer (CTL)?
   / Would you give up a tractor for a skid steer (CTL)? #31
No way! Tractors are kewl and you can’t put a pricetag on kool.
Or spellin. 😜
   / Would you give up a tractor for a skid steer (CTL)? #32
Well,--- I can live without tractors, but stay away from my skidloaders or we gonna have a problem!!!!! I use mine every day and have made about all the attachments for them.
IF I need a tractor for 1 or 2 jobs, I go next door and borrow 1 of my neighbors tractors!
   / Would you give up a tractor for a skid steer (CTL)? #33
Not a chance for giving up a tractor for ss or ctl. Overall cost to maintain is insane on a ctl and ss. Bumpy ride and traction sucks. Only thing I see as a plus towards ss/ctl is maneuverability. Almost any attachment for a ss will go on a loader although remote hyd and maneuverability is more problematic on a tractor.
   / Would you give up a tractor for a skid steer (CTL)? #34
The maintenance cost isn’t that bad. It’s probably $5 an hour in track wear. Otherwise the maintenance isn’t much different from other equipment. $5 an hour hardly counts as insane in my book. And these machines will work circles around a compact tractor. Not only will they work circles they’re much tougher. How far do you have to look to find story’s of tractors with drained fluids because a limb ripped a filter off, busted front axels because they’re wimpy, tweaked loaders because they’re wimpy, bent cylinders because they’re not dozers, the 3 point hitch ripped off because they can’t run a backhoe? A CTL doesn’t break every time you mistreat it. Bottom line if you want to do actual work get a CTL, if you want to play around your house get a tractor.
   / Would you give up a tractor for a skid steer (CTL)? #35
You bring up an interesting part I didn't specify size of tractor. With a scut and cut you are definitely correct with ctl/ss being tougher, depending on what type of ss. I was meaning a true industrial loader/backhoe in 8-10k lb or 40+ hp range
   / Would you give up a tractor for a skid steer (CTL)? #36
An industrial loader is NOT a tractor. Even a larger farm tractor isn’t as strong or durable as a CTL. But this thread wasn’t started to compare industrial loaders and farm tractors to a CTL. It was started to compare compact tractors. And a compact tractor has the advantage of not tearing up the grass but when it comes time to actually do work the CTL is way more capable.
   / Would you give up a tractor for a skid steer (CTL)? #37
I'm meaning jd 110tlb or g-k-m size kubota for the size of tractor.
   / Would you give up a tractor for a skid steer (CTL)? #38
The JD110 was a tractor and it was famous or lack there of for busted bell housings. The M59 was a better tool but it’s still not nearly as tough as a CTL.
   / Would you give up a tractor for a skid steer (CTL)? #39
I consider the loader on my kubota m9540 basically for "chores" only and agree with 4570. Now I'll load out of a pile and fork or grapple loads, but will not do any heavy ground engagement or digging work with it. But then I do have a large SS to jump on.
   / Would you give up a tractor for a skid steer (CTL)? #40
got a tractor with loader, also purchased attachments such as grass cutting, snow blowing and backhoe, all I can say it sits in a container, did try to trench the gas and electric lines, after a couple days and only about 30 feet I purchased a real backhoe in a CAT 420, it cleared the ground, dut a couple miles of trenches and still works today after 15 years, I also have a skidsteer, it does the snow blowing, grass cutting and just about any job I need around the acreage, meanwhile the tractor and attachments have been parked for 12 years
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
207279 (A52708)
207279 (A52708)
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
