LED Light Bar
/ LED Light Bar #1
Kubotafan
Gold Member
Nova Scotia, Canada
G1800AWS, B3030HSDCC, L3540HSTCC, JD710A
I have a L3540 Kubota Cab tractor and it has the original work lights. One of the front is gone and I am thinking about replacing both with a LED light bar. I am wondering what brightness I should get for snowblowing at night. I got by with what was on the tractor, but wouldn't mind a little more light. Any recommendations?
/ LED Light Bar #3
I don't know if you could have too much light, I have 5000 lumens forwards and backwards, and truthfully would like more. The combination spot and flood options is a good one. I like the really cold white light, so the bigger the number on the Kelvin scale the better. LEDs are great.
/ LED Light Bar #4
Agreed with the two posts above. Pay close attention to the “flood” and “spot” functions. I have a combination front LED bar that is light years (pun intended) better than the factory lighting. In the rear, I’m only running a small LED flood light and it’s more than enough light IMO.
/ LED Light Bar
Do you know what model light bar you have?
/ LED Light Bar #6
/ LED Light Bar #7
My light bar is several years old and not available on Amazon anymore. It’s a 26” flood/spot combo. I just bought a Nilight kit that contained a 26” bar (that I gave to my neighbor) and two 18w flood Pods. I ended up only using one of the pods for the rear. Will save the other for something else of if this one fails.
/ LED Light Bar #8
I put (4) 54w combo flood / spot LEDs on my L4060. I believe they were about $30 each no name on eBay. Incredible improvement over stock halogens, but in hindsight I think (4) 36w LEDs would have sufficed.
Regardless, they turn night into day!
/ LED Light Bar #9
I'm pretty well all LEDded up now!
Even my inside cab light is now a 5 inch LED strip. Like WOW sure bright.
I used double sticky tape to install it and wired a switch in line.
Rear is 2 floods for snow and up front a combination spot/flood.
My hazard 'strobe' is a DIY affair rigged up inside of my old modified* plastic dome. (*cut to shorten)
I mounted it 4 inches proud on a 4 inch magnet as I am known to be lazy and not clear my roof snow.
Should I snag it on a low branch it simply dangles 'til I re install.
Night snow blowing is no longer a blind chore.
/ LED Light Bar #10
Led panels are installed in Armstrong ceilings, stretch and suspended ceilings, plasterboard structures. This type of lamp is also installed as overhead and pendant lights. LED panels are chosen because they: Give an even, soft light. Diodes do not pulsate, and the plafond diffuses the light evenly. In this light, it is comfortable to work: the vision is less tired. Do not overheat. Diodes heat up during operation, but the luminaire design distributes the heat evenly, not overheating the device. The lamps are fire-safe. Operates at different temperatures. The luminaire Ultra-Bright Collapsible LED Lanterns by Vont | The Grommet® will not deteriorate from increased or decreased temperature and works in the temperature range from -20 to +40 degrees.
/ LED Light Bar #11
Have any of you felt that you had too much light at night with blowing snow? I've had it so bright and with the blowing snow was completely lost and drove off the pavement well into the field it was blowing so hard. I've only lived here for 30 and constructed the driveway 34 years ago so its not like I don't know my way.
/ LED Light Bar #12
Let there be light - L4060 light bars & nice auxiliary fuse box is my light bar install on my L4060hstc years ago. I love the light, but if I have to do it over again I'd probably just go with 4 mini LED bars. Less wiring, less bracketry, welding & general work. I use the bars a decent bit, but not as much as I'd expected. Good quality 4" cubes or 4" x 8" mini bars on each corner would be enough.
I don't plow or blow in heavy blowing snow, but expect my bars would blind me if I tried with them on. Headlights wouldn't be enough (except when I lifted my stainless plow, then they would be plenty to blind me).
/ LED Light Bar #13
I went with a 42 inch Rigid led on my new Kubota 1100.Throws out a lot of light.
/ LED Light Bar #14
In case this thread attracts others not only looking for snow time, I have a light bar on the front and one on the back of the top of my ROPS (one forward, one backwards). I lost a headlight and don't care, it's superfluous.
I'll note that a single light bar isn't ideal for backhoe work, however; I plan to get a couple combo spot/floods like were posted previously. Maybe two pairs... one front, one back.... but I think I should probably also do a sub-fuse-box so I can clean up the wiring!
/ LED Light Bar #15
The curved bars I put on mine are both. Focused spot in the middle, then a crinkled reflector on the outer third of LEDs on each side (in addition to being on the outside of the curve). Gets you spot & flood in one. Not sure what size those combo units start being an option.
/ LED Light Bar #16
The Brighter the better. I have 13" bar lights front and back on my tractor and am happy with them. Recently added 20" on my UTV. I find the 13's are brighter even with less Lumens because they act more like high beams instead of a spread floodlight like the 20". The 13" units are cheaper and better lighting for my dollar.
Snowblowing with the bar lights is excellent.
/ LED Light Bar #17
I have to agree that there are times when more light is not better. It comes from living in a wind tunnel. There are times I shut down all the lights and I can see better once my eyes adjust than with the lights on.
/ LED Light Bar #18
Mine have 6 modes controlled by a yellow wire. I connected the yellow wire to a momentary rocker and switch the led to yellow or yellow/white to not blind my helpers and see in the snow.
/ LED Light Bar #19
I disconnected my factory headlights right behind the housing and ran the wire up the ROPS to two of the LED cubes, one on each side. Allowed me to have light over the loader bucket. Highly recommend the modification. Use the tractor year round and of course it's dark at 5:30pm come December here so it does get used for snow removal on a regular basis.
/ LED Light Bar #20
When I was changing the LED lights on my tractor I used the wrong LED drivers, look out for that. The wrong power supply type for LED lights is a bigger issue than you might think. I bought the lights I wanted to change to off Joom and the power supply was mismatched with the light. After some time the lights stopped working. I looked into this issue and found that I was not the only one to have experienced it, it’s actually quite common. When buying the lights you should make sure the driver is the right one or you should buy one yourself. I usually buy the ecopac led driver.
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
Unverferth HT25 Header Trailer (A66285)
Unverferth HT25...
JOHN DEERE R4023 SELF-PROPELLED SPRAYER (A64277)
JOHN DEERE R4023...
