Chasing down a vibration in Woods brush mower
   / Chasing down a vibration in Woods brush mower #1
MESSMAKER
Bluegrass,KY
DK4710SE
My 3 year old Brushbull has picked up a good bit of vibration as the RPMs go up. I have checked the PTO shaft and blades and they seem OK. I found that one of the bolts holding down the gearbox was not tight, but I took care of that. I suspected that Maybe I bent an output shaft. I have run cutters for decades and never had this happen. I have watched the rotation of the blades but I am not sure I can trust my eyes. Anyone have any ideas?
   / Chasing down a vibration in Woods brush mower #2
Output shaft bearings?
   / Chasing down a vibration in Woods brush mower #3
Mine (BB60.50) only incured vibrations after the blades hit serious metal debris mowing along side the Interstate, and slightly bent a blade. It was just a minor deformation, barely noticeable, but at 15,000 rpm, it was enough to create vibrations. I ordered both new blades and bearings from German Bliss, but the blade replacement eliminated the vibrations. I now have a set of backup bearings just in case.
   / Chasing down a vibration in Woods brush mower #5
Yeah, that thing must sound like a jet engine. 15,000 rpm! o_O
   / Chasing down a vibration in Woods brush mower #6
Yikes....your right. In the cutter specs, its 15,000 fpm on the blade, not the rpm.
   / Chasing down a vibration in Woods brush mower #7
On my BB48x the welds that connected the crossbar to the blade pan broke.
Replaced the blade pan and cured my vibration.
I guess it could be the blade pan. It is dented but in one piece.
New blades are $175. What is the cost on the blade pan?
   / Chasing down a vibration in Woods brush mower #9
I don’t remember the cost exactly, but it was around $200
I have replaced 2 blades because they broke. Rocks, stumps, logs and other things I have hit with this cutter.
But, the condition of the blades have not caused any vibrations.
Loose gear box and broken welds on the blade have caused vibrations.
   / Chasing down a vibration in Woods brush mower #10
Make sure your blades are swinging freely. If mine bottom out or get any grass in between the pan and blades it will shake like crazy. I usually sray some lube up there and swing them by hand to loosen them up. This has happened on al 3 of my cutters over the yrs.
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2012 NISSAN Rogue (A56859)
2012 NISSAN Rogue...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2017 JOHN DEERE 323E SKID STEER (A52709)
2017 JOHN DEERE...
