Chasing down a vibration in Woods brush mower
   / Chasing down a vibration in Woods brush mower #1
MESSMAKER
Bluegrass,KY
DK4710SE
My 3 year old Brushbull has picked up a good bit of vibration as the RPMs go up. I have checked the PTO shaft and blades and they seem OK. I found that one of the bolts holding down the gearbox was not tight, but I took care of that. I suspected that Maybe I bent an output shaft. I have run cutters for decades and never had this happen. I have watched the rotation of the blades but I am not sure I can trust my eyes. Anyone have any ideas?
   / Chasing down a vibration in Woods brush mower #2
Output shaft bearings?
   / Chasing down a vibration in Woods brush mower #3
Mine (BB60.50) only incured vibrations after the blades hit serious metal debris mowing along side the Interstate, and slightly bent a blade. It was just a minor deformation, barely noticeable, but at 15,000 rpm, it was enough to create vibrations. I ordered both new blades and bearings from German Bliss, but the blade replacement eliminated the vibrations. I now have a set of backup bearings just in case.
   / Chasing down a vibration in Woods brush mower #5
Yeah, that thing must sound like a jet engine. 15,000 rpm! o_O
   / Chasing down a vibration in Woods brush mower #6
Yikes....your right. In the cutter specs, its 15,000 fpm on the blade, not the rpm.
   / Chasing down a vibration in Woods brush mower #7
On my BB48x the welds that connected the crossbar to the blade pan broke.
Replaced the blade pan and cured my vibration.
I guess it could be the blade pan. It is dented but in one piece.
New blades are $175. What is the cost on the blade pan?
   / Chasing down a vibration in Woods brush mower #9
I don’t remember the cost exactly, but it was around $200
I have replaced 2 blades because they broke. Rocks, stumps, logs and other things I have hit with this cutter.
But, the condition of the blades have not caused any vibrations.
Loose gear box and broken welds on the blade have caused vibrations.
   / Chasing down a vibration in Woods brush mower #10
Make sure your blades are swinging freely. If mine bottom out or get any grass in between the pan and blades it will shake like crazy. I usually sray some lube up there and swing them by hand to loosen them up. This has happened on al 3 of my cutters over the yrs.
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2002 Henderson FSP Sandspreader (A55973)
2002 Henderson FSP...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 STOUGHTON 53FT DRY VAN (A57880)
2016 STOUGHTON...
