greengoblin
- Joined
- Aug 17, 2023
- Messages
- 2
- Tractor
- John Deere 3032e
Hello
My frontier RC2060 brush cutter has started to feel a little odd, .. more than usual vibration and noise during operation and a tendency to sometimes shave dirt even when the cutter is not at the lowest position .
On inspecting the cutter,
1. I can see a thin film of oil on the underside around the shaft
2. The gearbox itself has oil (dark colored, not milky so no water in it)
3. The castle nut and cotter pin are in place
4. The output spindle from the gearbox to the blade assembly can freely move and wobble side to side .
On account of (4) , does that mean that something is worn in my gear box . If so, what could the issue be and what's my best plan of action to get things working again . I haven't dug into one of these gearboxes before
I was thinking of pulling the blade assembly, replacing the gearbox and then digging into the old gearbox .. as I'm not sure exactly what is worn.
Thoughts / Advice ?
Thoughts / Advice ?
