Kubota M4D-71 vs L6060 for newbie
/ Kubota M4D-71 vs L6060 for newbie #1
roadracer
Deere 325g & Deere 35g
Hi folks,
Unfortunately my local Kubota sales team is a lot more eager to sell what they can get than what I will need, so I want to get some external opinions.
I just moved on to a >150 acre property in the northern rockies and I need to do *everything*. To start with I need to do general construction as well as property development including road development, bridge construction, building foundations, etc. After we're a little more comfortable, we're looking at a wide variety of hobby farm agriculture. The property is currently irrigated for livestock pasture and that will continue but we likely want to move from direct grazing to a small hay operation (~30 acres of hay).
Based on my research the m4-71 is about the lowest HP that is reasonable to use with a baler. It's a much big tractor than the L6060 and I worry that it might be overkill in the long run. The L6060 also has the 3-range HST, which seems like it would be more convenient for the non-agricultural use cases. Anyone have any opinions or illuminating follow up questions that might help me sort this out? I'm a buy once / cry once kind of guy, but I'm also open to the possibility that I should get a much smaller "starter" tractor as a gateway into the right purchase.
Cheers!
/ Kubota M4D-71 vs L6060 for newbie #2
I have an M4 and it's what I would consider the bare minimum for anything hay related if you're only going to have one machine. And I'm at 900' ASL.
Your initial list of projects however aren't tractor projects, they're dozer or excavator projects.
Yeah, didn't mean to imply everything would get handled by the tractor, just what was reasonable. I would rent a mini-ex or hire someone to handle the stuff that is too big for me. I am at 4600'. With the turbo is that much of a factor?
I was imagining I would get a box blade, post hole auger, maybe a tele-boom, etc in order to help with the construction projects, but not replace a real dozer or ex.
/ Kubota M4D-71 vs L6060 for newbie #4
I just moved on to a >150 acre property in the northern Rockies.
How many of your total acres do you expect to "tractor"?
How many acres are flat, how many are hilly?
I do not hay myself but I live in the middle of hay country. You can hobby-hay from ten acres to 75 acres for your own animals. Few in north Florida try to hay as a living on less than 300 flat acres, which they process at high tractor speeds.
You can certainly process thirty acres of hay with an L6060. Round bales would be 800 pounds, rather than 1,200 pounds. L6060 would stack 800 pound round bales three high.
T-B-N ARCHIVE: hay baler for compact tractor site:tractorbynet.com
road development
-- L6060 / 'loaded' rear tires plus wheel weights.
bridge construction -- contract out to a professional
building foundations -- contract out to a professional.
The L6060 has the 3-range HST. I'm a buy once / cry once kind of guy,
The L6060 is Kubota's most powerful 'Grand L' model. 'Grand L' = Compact tractor nirvana. I worked through two economy tractors before finally buying my L3560, the lightest of the 'Grand L' models, eight happy years ago. The HST/PLUS transmission has an intermediate half-step level for each of the three ranges, extremely useful. New tractor owners tend to stall the engine many times per day. HST/PLUS has 'stall guard', which has eliminated stalling for me. I has been at least a year since I last stalled my tractor.
/ Kubota M4D-71 vs L6060 for newbie #5
With a turbo, no. With a natually aspirated diesel engine you would be down about ~~ 9% in engine horsepower at 4,600'. (3% per thousand, after 1,500')
/ Kubota M4D-71 vs L6060 for newbie #6
Kubota L6060
Kubota L6060 tractor photo
2013 -
L60 Series
Compact Utility tractor
Series:L5460L6060
Production
Manufacturer:Kubota
Type:Compact Utility tractor
Variants
L6060HST:ROPS
L6060HSTC:cab
Kubota L6060 Power
Engine (gross):62 hp
46.2 kW
Engine (net):60 hp
44.7 kW
PTO (claimed):53 hp
39.5 kW
Kubota L6060 Engine
Kubota 2.4L 4-cyl diesel
Fuel tank:13.5 gal
51.1 L
Mechanical
Chassis:4x4 MFWD 4WD
Steering:hydrostatic power
Brakes:wet disc
Cab:Two-post foldable ROPS. Grand Cab with air-conditioning optional.
Transmission:hydrostatic
Transmission
Transmission:HST Plus Hydrostatic transmission with three ranges plus Hydro Dual Speed Hi-Lo. The Dual Speed allows rapid switching between two speeds in range, either automatically or with a lever on the steering column.
Type:hydrostatic
Gears:infinite (3-range) forward and reverse
Photos
Kubota L6060
Hydraulics
Pump flow:9.4 gpm
35.6 lpm
Total flow:14.1 gpm
53.4 lpm
Steering flow:4.7 gpm
17.8 lpm
Tractor hitch
Rear Type:I/II (dual)
Control:position control, draft control optional
Rear lift (at 24"/610mm):2976 lbs
1349 kg
Power Take-off (PTO)
Rear PTO:independent
Rear RPM:540 (1.375)
Mid PTO:optional
Mid RPM:2000
Dimensions & Tires
Wheelbase:75.4 inches
191 cm
Weight:3990 to 4365 pounds
Front tire:9.5-16
Rear tire:14.9-26
Kubota L6060 attachments
snowblower
blade
front-end loader
Kubota LA1055 LoaderHeight (to pin):112.7 inches
286 cm
Clearance, dumped bucket:87.2 inches
221 cm
Dump reach:26.3 inches
66 cm
Dump angle:46°
Reach at ground:77.8 inches
197 cm
Rollback angle:42°
Breakout force (at 500mm):3171 lbs
1438 kg
Lift to full height (at pin):2361 lbs
1070 kg
Lift to full height (at 500mm):1784 lbs
809 kg
Bucket width:72 inches
182 cm
backhoe
Electrical
Ground:negative
Charging system:alternator
ROPS Charging amps:45
Cab Charging amps:60
Battery volts:12
/ Kubota M4D-71 vs L6060 for newbie #7
Two tractors (minimum), not necessarily simultaneously.
I think to begin with you should be looking at a full size construction backhoe. Once the big jobs are done, switch to a tractor for more general utility and haying. Consider paying someone local to do the hay for a couple or few years to start to before you jump into that.
Thanks folks!
To be clear, this "enterprise" is not intended to support anyone's living. The cost of land prohibits that even it was my goal, which it's not. About half the land is flat enough for conventional agriculture. More if you wanted to try growing some grapes, etc.
As for the other projects, I'm trying to do as much as is reasonable myself. Not to save money, but because I think it's fun.
My DIY bridge is only rated at 10klbs. If I needed something for a full cement truck, I'd have the pros put it in for sure.
Starting with a backhoe is an interesting idea. I wonder if used tractors are experiencing the same price hike as used cars...
/ Kubota M4D-71 vs L6060 for newbie #9
Starting with a backhoe-loader is an interesting idea. I wonder if used tractors are experiencing the same price hikes as used cars...
About 75 acres is flat enough for conventional agriculture.
An L6060 uses 72" and 84" wide implements. Bare weight 4,000 pounds. Sufficient for 30 acres.
An M4-71 uses 84", 96" and 108" wide implements. Bare weight 6,000 pounds.
Most farming 75 acres would prefer the wider implements behind a M4-71.
The importance of tractor weight eludes many tractor neophytes when shopping.
How do you value your time?
Thanks folks. I've decided to get the M4D-071. Curious what the lead time will be for an order. Does anyone have guidance on what is normal for pricing on these tractors relative to MSRP? I was under the impression that they tended to sell for 10-15% below MSRP but maybe that is not true anymore with the limited supply.
/ Kubota M4D-71 vs L6060 for newbie #11
Highly likely you’ll pay MSRP or more.
/ Kubota M4D-71 vs L6060 for newbie #12
Depends on your dealer. I’ve bought roughly $500k (at list - can’t recall actual prices) from my dealer over the past 8 years. He doesn’t inflate my prices now knowing not to upset me.
/ Kubota M4D-71 vs L6060 for newbie #13
Discuss with your dealer the process for obtaining a tractor and implement sales tax exemption.
This varies tremendously from state to state. Usually easiest to qualify for an ag or forestry sales tax exemption in big-ag states. Quite simple in Florida. A one page declaration.
If you enter your LOCATION into your T-B-N PROFILE someone may tell you the exemption qualifications in your state. Your LOCATION encourages replies better tailored to your conditions.
Congratulations on the land. Congratulations on the tractor decision.
Someone FINALLY buying ENOUGH TRACTOR the FIRST TIME.
/ Kubota M4D-71 vs L6060 for newbie #14
If the dealer can’t come close to 20% off, join one of many horse associations and get 20% that way. I just priced one that way. Dealer was able to get within $200 bucks without equine program with current incentives. Waiting on inventory to test drive/finalize deal.
No sales tax in MT, thankfully. Looks like equine is going to get it as cheap as it'll go. If I was going to finance, MSRP + incentive rates seems like it's a little bit better deal. Waiting to hear back on lead time, etc
/ Kubota M4D-71 vs L6060 for newbie #16
Why not start out with a clapped out backhoe or skid loader to start and THEN if you get to haying (the only thing I saw necessary for tractor ownership) you can tackle that. Meanwhile, you have robust loader and backhoe far exceeding what a tractor can do.
/ Kubota M4D-71 vs L6060 for newbie #17
I priced out an M4-71 this spring. A dealer had 2 tractors sitting, old stock. By the time I had it speced out the way I needed, it was close to CAN $ 100,000. I got the price from two different dealers. The one who had it in stock, the other closer to me but would have sourced it from the other. The same tractor, different price.
I passed it on. Couldn't separate from the 6430 premium.
/ Kubota M4D-71 vs L6060 for newbie #18
"If the dealer can’t come close to 20% off, join one of many horse associations and get 20% that way. I just priced one that way. Dealer was able to get within $200 bucks without equine program with current incentives. Waiting on inventory to test drive/finalize deal."
I didn't know about these equine discounts. I wonder if they have them north of the border...
Tractor arrived at the dealership today! Unfortunately wasn't able to take delivery yet.
Also, for those who raised the very reasonable prospect of getting a TLB instead of a tractor, I ended up just going wild and getting a 3.5 ton mini ex in addition to the tractor. I told me wife it was cheaper than getting a porsche...
20800 (A56859)
20800 (A56859)
3pt 12 Shank Chisel Plow (A60462)
3pt 12 Shank...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A60352)
2015 Peterbilt 348...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
