Surprised by need for rear ballast with L 4060 in this situation
   / Surprised by need for rear ballast with L 4060 in this situation #51
I know. Anyone that knows me knows I am NO fan of the tort lawyer, BUT in this case if someone had just taken the time at the dealership to warn this individual (however ignorant he may be) about the dangers of using the bare tractor without any ballast and insisted on selling him at least a ballast box and at least talking to him about loaded tires or wheel weights he might still be alive. In the big scheme of the tractor purchase even for a low end tractor like the 3038e, the additional couple hundred bucks for a stinking ballast box might have saved him. At least he would have had the chance to think a little about it.
We don't know what exactly happened and under what circumstances he rolled his tractor over. I can guess. My guess would be he lifted a load with the FEL, and he had the loader bucket well above the hood of the tractor like all NEW tractor owners do (because they are ignorant of the dangers) and he turned the tractor on slightly uneven ground or the high side tire found a protruding rock or the low side tire found a hole and the tractor overturned. He probably wasn't wearing a seat belt, and we don't know about the ROPS, but in any case he became trapped under the tractor and was crushed.
How many pictures of rolled over tractors have we seen here on this forum? Plenty, that's how many. And where is the loader bucket in relation to the hood of the tractor? Well above it in almost all cases. I grew up as a child around tractors and machinery, and had a pretty good idea of how to stay safe around them, but even I had a few close calls. I never rolled one, but I sure had the rear tires come up off the ground because of improper ballasting. Lessons learned, don't do that again.
In addition to not having enough ballast the pivoting front axel makes a tractor much more unstable vs other equipment that has a solid axel under the loader.
   / Surprised by need for rear ballast with L 4060 in this situation #52
You’ve calculated wrong. Say you take a board that’s 3 feet long and you put a pencil under both ends 1 foot from the end. You’ve got 1 foot from each pivot to the end and you’ve got 1 foot between the pivots. That’s our tractor with ballast hanging off one end and a loader off the other. You put a 1 pound weight on both sides of the board. Excluding the weight of the board each pencil is supporting 1 pound. Now you put another 1 pound weight on one side. Under your logic the board should now be totally balanced on the one pencil. Its not because the weight is farther out than the pivot. It only lifts 1/2 pound off the pencil for every pound you put on the opposite side.
How can you not understand this...
Yes, at the opposite end of the board it's "lifting" 1/2 pound in your example, but at the second pencil it's "lifting" 1lb. That math doesn't change.
   / Surprised by need for rear ballast with L 4060 in this situation #53
If it lifted 1 pound off the pencil that only had 1 pound to start with it would be balanced on the second pencil but it’s not. You’re claiming it’s a 1-1 lever but it’s not. It’s a 2x1 lever. Adding the second weight only lifted 1/2 pound off vs a pound.
   / Surprised by need for rear ballast with L 4060 in this situation #54
Probably the reason most of them tip and kill someone, not often talked about
You are talking about two separate points compared to the fulcrum. We’re talking about reducing stress on the front axle. How about this, what if I made the pencils weigh 1lb each to simulate ballasted tires then put 1lb on one end, what happens?
   / Surprised by need for rear ballast with L 4060 in this situation #55
Don’t forget that there are two conditions being talked about. One is with the rear wheels firmly on the ground, the other is with them light or nearly off the ground.
For arguments sake, say the rear wheels are not touching the ground due to the load on the FEL. At this point the front axle is supporting the weight of the tractor, rear ballast and the actual load being lifted. In this case the rear ballast allows or causes an increased load on the front axle.
When the loader is not lifting, the rear ballast will decrease the load on the front axle.
   / Surprised by need for rear ballast with L 4060 in this situation #56
Don’t get ahead of my trap ;)
   / Surprised by need for rear ballast with L 4060 in this situation #57
I recently bought an L4060. I have a 4000 lbs SS QA fork attachment that I used with the L48 TLB that I sold before buying the L4060. I know it’s heavier than what one might normally buy for that size tractor, but I had it already. I have some units of hardwood lumber that I have moved around with the L4060, that are about 32” wide and 12’-16’ long, some of which weigh 1400-1500 lbs. I have beet juice in the tires for ballast. I was able to move that lumber around with no problem, while working slowly and carefully as I moved it.
Anyway, today I bought 25 leftover 4x8 sheets of 1/2” OSB from a guy and he brought them to me. We unloaded them from his pickup and put them on the forks of my tractor so I could move them to a different place on my property. These 25 sheets weigh 48 lbs. each, for a total of 1200 lbs. I had no problem lifting the 25 sheets, but my rear wheels were so light that they spun on my gravel drive.
My old L48 was my first tractor, and I always had the backhoe on it, and I never had a problem lifting anything with the FEL, and it spoiled me in that regard. I’ve been reading the many cautionary tales on TBN of hairy situations with rear wheels lifting off the ground, so when I have been moving my piles of lumber around, I’ve been very careful, and had no problems. But I was completely taken by surprise today when I couldn’t move with only 1200 lbs plus the fork weight because I didn’t have adequate ballast. Of course, OSB is 48” wide as opposed to the 32” widths of the lumber piles I’d been moving. I don’t remember my physics lessons.....is there an exponential increase in the leverage exerted as the load gets wider and further away from the fulcrum of the front wheels? Is there a simple math formula that would help me with anticipating when I have too much weight, based on the projection of the load? Thanks.
Here's the load weight chart for my forklift, thought it might be interesting, wish it had the actual numbers for all the distance points. Unlike the radial lift on a loader though, its lift capacity doesn't change throughout the lift range.
   / Surprised by need for rear ballast with L 4060 in this situation #58
After going through this thread, I get the feeling that maybe those who believe that 3 pt ballast won't alleviate the front axle, are using tractors with just a single axle, the rear one. In that case, yes, the front axle is irrelevant because it's not there. 😅
   / Surprised by need for rear ballast with L 4060 in this situation #59
Gah, I should know better.. but yeah, the 2nd weight lifted 1/2 pound IN ADDITION to the 1/2 pound already being lifted by the first weight - AT THE "LOADER", not the pencil. "Rear" pencil has 2 lbs one foot away, and 1 lb two feet away. Sounds balanced to me...
[edit to add] Where I was going with this is that the "You didn’t do the math right for starters." post referred to up-thread was not wrong IMHO. It was a calculation of the effect of rear weight on _front axle loading_ not the weight required to offset some particular weight in the loader.
In the pencil example, if the rear pencil is the pivot point, rear weight counts 1x and front weight counts 2x when it comes to load on the front pencil.
Z.
   / Surprised by need for rear ballast with L 4060 in this situation #60
Z.
You’re right I didn’t do the math in the pencil demonstration right. But the concept is still right. You should really move the back pencil back 6” so the distance is 6” 18” between centers and 12” on the front and repeat the pencil and board test. measuring the distance between the tractor axels like 2 posters have done is still wrong. You need to measure the distance from the load center on the FEL to the rear axel and from the rear axle to the ballast load center to determine the ratio.
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
