Hydraulic Pump, no load power use
/ Hydraulic Pump, no load power use #1
cmaas
Member
Kubota L2800, Ford 555A
I am fitting a 3 cu. in. pump to a custom vehicle. The pump is used intermittently and is powered by the vehicle's motor. Rather than disengage it using an electric clutch I am wondering if I can just leave it engaged full time. Can anyone tell me approximately how much torque it takes to spin a 3cu. in. 30gpm pump when it's not under load?
/ Hydraulic Pump, no load power use #2
Many years ago I was working for a gear pump manufacturer and they dd not publish any data but a pump producing 28 GPM at 1750 RPM required approximately 3 HP just to circulate that flow at 30 PSI. I do not know how much the HP requirement would vary with a smaller displacement at a higher RPM.
Thanks. I think I will try without the clutch but make provision for it to be installed later.
/ Hydraulic Pump, no load power use #4
Good idea - especially if the pump is being run fast a lot of the time w/o using its considerable output. > If it spins slowly due to low engine speed most of the time you use the vehicle it wouldnt be so attractive to clutch it to save the lower parasitic power use.
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A63118)
2025 Wacker Neuson...
2020 Inifiniti Q 50 Sedan (A61569)
2020 Inifiniti Q...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
