Fire on John Deere mower
/ Fire on John Deere mower #21
I won't spray water on my tractor but do use the air compressor to blow off all the dust and debris after EVERY mowing. Parts stay dry rather than soaked down and causing rust, and water in and around the engine parts, the electronic parts, the bearings, and such can't be very good for longevity. But just may be me. Not putting down whatever anyone else likes to do.
/ Fire on John Deere mower #22
Two points I have to add.
Lady around here once cut the grass around her place, parked it next to her house and went to take a shower. Next thing, the house was in flames!
I have a Steiner 430 Diesel MAX that was given to me, burned to destruction, that was used to try and push a burning brush pile. The FD showed up reasonably quickly, but to see the machine, you would would think it had been in a burned builiding.
3rd point, check your fire extinguishers for content. A shot extinguisher is about as good as a rock.
/ Fire on John Deere mower #23
Looks like a box store special to me. Get an insurance check and go buy another, they are, after all, expendable.
/ Fire on John Deere mower #24
I have had issues with my Husqvarna rider when dealing with thick piles of leaves in the fall. It is easy to catch as there is smoke and the smell of smoldering leaves. This year and last year, I started using a mulching blade and not letting the leaves build up on the grass too much. It takes more sessions to mulch them than to bag them, but it is only seat time. I did have a small fire once due to my laziness. I thought it was just the "normal" smoldering smoke from the leaves but I let it go too long. Learned my lesson...if it smokes or smells even a bit, I clean the area out.
Have to agree that it seems your issue was a gas leak of some sort as dead leaves/grass will smolder before bursting into flame.
Hope your homeowners policy helps out. Mine has $1000 deductible so it would still be painful. One thing I like about ZT's is the engine is up and out of the way. Nearly impossible to have a grass/leaf fire.
/ Fire on John Deere mower #25
There have been some JD combines that have caught fire while working. They are usually a total loss, as by the time it is noticed, it is too late to do anything. If you think a mower is costly, price a combine.
Speaking of combines, a local Farmer told me the fire extinguisher in the cab is for the operator's "peace of mind" he will be able to get out, not put the fire out. By the time he knows it's on fire, it will be a total loss
/ Fire on John Deere mower #26
Found many of my extinguishers plugged with mud wasps. Can be easily cleaned out usually, but not when something is on fire.
Big problem, especially with todays plastic encased equipment. You can't put out a fire if you can't get at the source!
/ Fire on John Deere mower #27
Appreciate the heads up, and will do some checking. Hadn't thought of that and it was not included when doing the "pointer in the green" zone check. tks
/ Fire on John Deere mower #28
I think it was the new JD S series combines that when they first hit the market there as a faulty hydraulic fitting that would spray hydraulic oil on the turbo when it failed. Instant roman candle.
/ Fire on John Deere mower #29
An experienced farm manager I know told his employees if a tractor ever caught on fire to throw their cell phone into the blaze and walk calmly back to the farm office to report the incident.
/ Fire on John Deere mower #30
:laughing::laughing: Oh so much truth in that one sentence then one can imagine.....:D
Glad all I have is coastal going to bed and rye waking up and blue stem drying out.....leaves....what are those....????:dance1::laughing:
Update.
I received a voucher from John Deere today for the full purchase price.
To be presented at a dealer of my choosing.
All in all, it was pretty painless so far. We will see when I get to the dealer if that remains the case.
They said that the cause couldn’t be determined but suspected debris around the muffler.
I had told them that I had just had the hood up and knew there wasn’t anything but it’s over and done with I guess.
/ Fire on John Deere mower #32
Very strange for them to do that when they suspect owner negligence.
/ Fire on John Deere mower #33
Good for you to get compensated. Did you ask if it was also valid at a Kubota Dealer? Kidding! lol
It does make my point about how useless having a fire extinguisher (or two) can be. Even on a lawn tractor. You can spray all you want on the exterior plastic of a machine and have no effect on the fire. Of course, a gasoline fire is that much more stubborn to put out.
/ Fire on John Deere mower #34
Well it happened to me too.
Still don’t know the reason why. It started in the front near the exhaust. But it didn’t have any electrical issues or gas leaks. It was the first time we mowed my daughters backyard. It wasn’t that big a yard 60x45 feet. The grass wasn’t that long. It only took about 1/2 hour to complete the lawn. Put the mower in the shed, then 10 minutes later smoke coming out of the shed. I ran to find 7 inches of flame coming out of both sides of the front hood. I pulled it out of the shed. Was too far from the water hose. Couldn’t find the fire extinguisher. So buckets of water finally put it out
More pictures here: John Deere E110 on Fire
/ Fire on John Deere mower #36
Fortunately, I’ve never had an issue other than once in the Fall while mowing, some leaves caught on fire on the back of the ZTR. I guess they got wedged in and the hot muffler caught the leaves on fire.
It wasn’t a big deal and the leaves just burned out. I was in the back 40 so to speak and did not have an extinguisher. It was scary for a few seconds.
Now I have an extinguisher attached to the toll bar.
MoKelly
/ Fire on John Deere mower #37
whenever the wife mows the yards, i have her leave the mower outside my shop to cool down and so i can hose it off, blow it off with air compressor. main reason i do this is its so hot im afraid it could catch on fire. never has, but still leary.
/ Fire on John Deere mower #38
Contact the Consumer Product Safety Commission. I bet they'll want to hear about your tractor. A major recall may be in order if JD doesn't replace it outright. There's no way a lawn tractor should go up in flames.
Do NOT tamper with it. A CPSC rep will want to inspect it. I called years ago when my Murray fuel tank started leaking and they (Sears) didn't want to do anything about it. CPSC came out and looked it over. It wasn't long after that, the series was recalled and I got a new tank. The leak was caused by a manufacturing fault and was covered by the warranty. (The tank split at a molding seam.)
Give JD a chance to remedy your loss. If they hem-haw around, let them know it's a safety issue and you're prepared to report it to CPSC. CPSC has a lot of attorneys. They like cases like this. CPSC can force a recall of the entire product series.
Many years ago I had a safety issue with a 200HP OMC outboard.
They kept giving me the run around, and I threatened to contact the CPSC.
They called their local dealer to tell him to fix it now!
Fixed... it was!
/ Fire on John Deere mower #39
Interesting, how come we don't hear about other lawn mower tractors going up in flames ? Just JD !
/ Fire on John Deere mower #40
I've seen plenty. Husqvarna, cub cadet, deere it happens to them all. every single one I've seen started at the muffler.
like most issues with outdoor power equipment in general, the operator can prevent problems just by cleaning/maintaining the equipment.
I'm surprised JD payed up for the OP.
2019 MACK PINNACLE (A65643)
2019 MACK PINNACLE...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2012 FREIGHTLINER M2 (A65643)
2012 FREIGHTLINER...
2026 Electric Tricycle (A64194)
2026 Electric...
E-Z Trail 3400 Gravity Wagon (A66285)
E-Z Trail 3400...
