logsplitter question
/ logsplitter question #1
lynn patterson
I am wondering about whether I should rent a log splitter or buy one to run off my tractor hydraulics. I have one large tree down that has been cut up and usually have 1-2 trees per year that need to be cut up and split that I have taken down or fell on its own in a storm, so not a lot of use but fairly constant.
Is it generally better to have a self powered splitter or to use your tractor? Which is more reliable/durable? Do these require much maintenance? Is the operation pretty simple? I can rent from Home depot here for ~$100/ day and have seen ads on this site or others for hydraulic run for about $1200-1400
Appreciate any advice for a relative novice at this
/ logsplitter question #2
I would recommend buying a self powered unit.
Should be able to get one for under $1k.
Run it out of fuel when putting it away for the season and change the oil every 2 or 3 years with no more use then you say you will have.
I know I waited far too long before getting mine and that was back before the prices came down.
/ logsplitter question #3
I'd run the self powered screamer and save hours on the tractor. Make sure you use ethanol-free rec gas in it.
/ logsplitter question #4
Age old question which comes up regularly. You're best off browsing similar threads to see which answer suits you best.
/ logsplitter question #5
If you have one or two trees a year, why bother? Use a splitting maul.
If you are in poor health, look at one of the cheap electric splitters for under $350.
health not that bad but time availability is my biggest issue--hoping to get it done quicker
thanks
/ logsplitter question #9
So I will take a different approach / look at this... & I own a stand alone self-powered Timberwolve splitter & love it. However, if you are splitting only a couple trees a year then I would either consider renting a stand alone splitter (called someone else's problem when returned) or a 3pt splitter for your tractor (electric is not a bad option either as shooterdon recommended).
Rental..
- You need it for a very short period of time
- It is their problem to keep running
- you don't have to store it.... or maintain it..
- you only pay for the time you need it & when you pick it up... it is working... no troubleshooting... no bad gas issues... It Works
3pt Splitter..
- Depending on your tractor will be slower (unless you purchase one with it's own PTO pump) but you aren't splitting much...
- Almost zero maintenance... (no oil changes, no ethanol issues / no start issues.. etc)
- IMHO Tractor hour are not even a concern for the time to split a couple of trees pre year... diesels are made to run... you bought a tractor to use.. (if you were splitting 5+ cords a yr... then maybe)
- storage space for a 3pt splitter is much smaller than for a stand alone... (& drop it... no maintenance)
- Did I mention almost no maintenance
If you were looking to split a lot more wood per season... then I would have a completely different opinion. We split 4-6 cords a year, which is not much compared to some. We use our tractor to load & haul wood as we split. We supplement 60 -70% of our winter heat with wood.
So based on your description of use, I would either rent or use a 3Pt splitter.... I don't know what you have for a tractor, but for the limited use I don't think I would add a separate piece of equipment that needed regular maintenance (& I have one)...
/ logsplitter question #10
I just rented a 34ton gas powered splitter in MO. last week, it was $91.00 total for 24 hrs. In reality it only ran about 2-3 hours but it was so hot we had to take frequent breaks. Moving those large diameter pieces for multiple splits was a chore!
The 8 hr. rate was 75 (plus tax).
We split an old oak tree about 36-38" diameter at the trunk. We cut it up early June and just had to split (one day) and load (Next day early morning while somewhat cooler) last week.
I'd suggest you rent as well. Get everything cut up and piled together so it's ready, then go rent the splitter and split it all. On a nice day I'd say you can split 4-5 trees worth of wood.
/ logsplitter question #12
If you’re doing such a small volume of wood practically any option will get the job done. I don’t care much about hours on the tractor but I like having my tractor not powering the splitter so I can use it to move wood.
/ logsplitter question #13
I borrowed my neighbours splitter a few times and he suggested I buy a half share. I now own half share in a stand alone splitter. The tractor is used to lift the rounds up to the splitter deck.
/ logsplitter question #14
I went with the Champion 7 ton and it works great for me and the price did not break the bank.
/ logsplitter question #15
With 1-2 trees per year, run it dry after every tree jib is finished. The ethanol in todays gas is hard on small passages when it sits for a few months. I suggest pulling the line to the carb when finished with the current needs and drain that fuel from the tank. Then run the motor till it dies using all fuel left in carb.
My $0.02 worth, I agree with not getting one for the tractor, due to wanting to load splits in either the bucket, a carryall or trailer on the tractor, also want tractor to move larger pieces of the tree to the splitter.
/ logsplitter question #16
I bought a high enough quality tractor in the first place, so I don't have to worry about trying to save a few hours off it, running my 3 point splitter!
SR
/ logsplitter question #17
All well and good for you but I have some oak on my property that laughs at my 20 ton splitter and tells me I should have a 30 ton.... Tonnage of splitter is relevant to type of wood being split (soft/hard or green/dry)....
/ logsplitter question #18
I bought a 27 ton Troy Built log splitter from Lowes about ten years ago for around $1,200. The reason for buying this was because of the Honda engine. In my opinion, the only thing that matters when buying something with a small engine is that it's a Honda engine. Everything else sucks. After ten years, it still starts easy and runs great!!!
Hooking up stuff to the tractor is always a pain. I don't think you could run it enough to matter on the hours, it's just a pain to unhook what's on the tractor, then hook up a splitter, then have to take it off again. I like to leave the attachment on the tractor for as long as possible. First time you do it, I'm sure it wont be an issue, but in five years, it will be something that you dread having to deal with.
Renting works for one time use, and for a lot of things, it's the smart way to go.
For me, I burn a cord of wood a year to heat the house and another cord sitting on our porch, just relaxing in the evening. Two cords isn't a lot by most standards, but it still takes time to cut, split and stack. I also work full time and I have a long list of things I'm working on, along with chores that need to be done every day. It is very hard to dedicate a full day to splitting wood. It's also a lot of work to do in one day. I tend to split according to how much gasoline I have. One tank of gas is a quick day, two tanks of gas is about my limit. It takes longer to stack it then it does to split it, and two tanks of gas is a lot of wood to stack. Doing it this way takes a few days, or even weeks, depending on what else I'm doing. Renting isn't an option. I just leave the splitter out until I have my rack full of wood.
I've also learned that for me, it's easiest to cut up the tree where it falls, into 10 to 15 foot lengths, and carry those logs to where I keep my log splitter. I cut them into rounds there, and then carry the rounds to my splitter. My splitter is right in front of where I stack my wood, so it hits the ground once, then I pick it up and stack it. For me, this seems to be the least amount of work to get the job done.
I don't mess around with big rounds. If I can't pick up a round, I don't want to mess with it. Ideally, I focus on the 12 to 18 inch branches with a few that will go bigger. There is so much wood on a tree that I can be picky and get what I want, and not kill myself messing with something so heavy that I might hurt myself. Sadly, I have so many oak trees that fall over every year from our Spring thunderstorms, that most end up rotting on the ground before I can get them to the burn pile.
/ logsplitter question #19
Yes, this. No diss meant to the guy with the toy splitter :) but I find my 12 ton will barely split my small (12" dia) elm logs. For any given size log, I find elm to be the toughest to split. I still split most everything else by hand!
/ logsplitter question #20
Personally I like a stand alone splitter so I can use the tractor for jockying logs around. For a very small amount I would consider an electric splitter. But I never tried using my electric splitter for anything substantial, like 18" oak.
I don't recall if you use the wood for anything like home heat or for campfires. You could have a friend cut it up and haul it away for firewood. Wouldn't take any effort, depending on the mess they might make. I am always looking for an easy free tree here and there.
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
Goosen Bale Chopper Hay Blower (A65579)
Goosen Bale...
