Anything better than wire nuts?
/ Anything better than wire nuts? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
My skills at electrical work are a little lacking. I was replacing an outside double flood light today. I’ve never had good luck with wire nuts. I was trying to get the wire nuts to stay connected, get the wires stuffed back in the box, and get the fixture screwed back into the box while standing on a ladder. It didn’t happen when I dropped it and broke an insulator where one light bulb screws in. I definitely broke it when I threw it in a trash can as hard as I could..
I went and bought another fixture and asked the guy at the hardware store if there was anything better. He said there is a setup where the wires are inserted and it snaps shut on them but he says they don’t work that great. With the wife helping we got it installed but it still took three tries to get the wire nuts to stay. Is there a better way?
/ Anything better than wire nuts? #2
There are some that push in and twist to remove, and some with levers to lock the wire in or release it.
Here are some.
Maybe a real electrician can post their preferences.
Bruce
/ Anything better than wire nuts? #4
Ideal makes push in connectors that work great. They are the way to go with solid wires...not work as good with stranded wires. But way more expensive than ideal tan colored wire nuts which are my go to device.
/ Anything better than wire nuts? #5
Some wire nuts are just threaded plastic which I throw those in the trash. The wire spring ones work ok for me if sized to the wires. About 1/2" insulation stripped, wires twisted tight together with pliers before wire nut. When that's tight I wrap electrical tape around it.
/ Anything better than wire nuts? #6
Just a general comment on the subject...
One of the most common mistakes made by DIY electricians is not understanding the importance of making tight connections regardless of the application...
/ Anything better than wire nuts? #7
Probably a wago nut and they’re brilliant for connecting lights. They make them with levers to release the clamp and others that you just push in. You’ll want the one with the releasable clamp for light fixtures.
/ Anything better than wire nuts? #8
I agree with grsthegreat the Ideal push-on are great, especially with solid wire (some of the recessed lighting manufacturers have them pre-installed on the pigtails in their fixtures)... as for wire nut I prefer the Ideal Twisters over traditional wire nuts...
Some of the pics BCP posted are what the hardware store had and the guy said they aren’t that great. I was joining solid wire, Romex, with stranded wire from the fixture.
/ Anything better than wire nuts? #10
In an ideal world, I try to solder stranded wire before trying to join stranded wire to solid wire. I have never found that stranded onto solid works well in a wire nut, even when I have left the stranded sticking out beyond the solid.
+1 on the wago connectors. Definitely do not use Chinese knockoffs; none of the ones I have seen are even UL listed, nor are they well made and a couple use combustible plastics.
All the best,
Peter
Looks like the Wago connectors less than $1 each if you get a package of 75 assorted ones. Seems like a deal to me. I broke a $39 light fixture earlier today.
/ Anything better than wire nuts? #12
I used some of these about 50 some years ago and was very confident that the wires would never come loose. Had not seen any again until just recently.
/ Anything better than wire nuts? #13
All the best,
Peter
Ive used stranded to solid for years. Never have issues. But you have to use professional grade products.
/ Anything better than wire nuts? #14
My only problem with wago connectors are the few times they have opened up on me when shoved into a junction box.
/ Anything better than wire nuts? #15
I grabbed two different designs out of my stash that I liked in my working days and both under the magnifying glass said 3M. I bought some crimp connectors off bezos junk store and they were garbage.
/ Anything better than wire nuts? #16
I don't think I would trust those wago things. I know when you get a good wire nut tight it stays tight until you unscrew it. Not sure how the plastic in the wago connector will hold up over time.
/ Anything better than wire nuts? #17
'Anything better than wire nuts'..... certainly....
Whole cashews......... (y)
/ Anything better than wire nuts? #19
I also have had great success using WAGO electrical connectors. These are the highest quality electrical connectors I have ever used. These are German made and absolutely will never break the connection once the lever is pressed down.
/ Anything better than wire nuts? #20
I use wire nuts just about every day in my day job. The comments about the size wire nut MUST be sized to the gauge of wire, and *how many* wires you're trying to put under the same wire nut are spot on. The other issue with using wire nuts is all the wires must be stripped to the same correct length for the nut. Then getting all the wires lined up so their tips are even with each other, you can't have one wire sticking out further, or one wire hanging back in the bunch. Then after twisting the nut onto the wires until it is tight, you MUST tug-test each of the wires under the nut to make sure none of them are loose and pull free.
I use the Ideal brand wire nuts most of the time. And that's because I've had good luck with them. Most of the wires that I deal with are 12 ga and under (smaller). On the 20 ga and smaller wire, I prefer Scotch-Locks over wire nuts. They are a gel filled snap-crimp style connector that is/was heavily used in the telephone industry.
Done correctly, wire nuts will never loosen up. Even cramming them into a J-box. But J-boxes have a similar rule to wire nuts. The J-box MUST be sized to how many wires (and wire nuts) you are trying to cram into it. I see more electricians violating this "rule" than just about anything else out there (more so than the "pipe fill" rules about how many wires you can fit in a conduit). You can always add an extension ring to a J-box if the wires won't fit. Most electricians will just try their hardest to cram and overstuff a J-box so they don't have to go get an extension ring.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
