How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #41
I am putting new seals in and apparently I need to get the bottom nut to 600 ft lb. I do not have that kind of torque wrench. How do most people achieve this? Thanks.
Tighten as tight as you can get it with a cheater bar then give it another 1/2 turn.
I have to give props to Summit Bobcat in Walden NY. They read the manual over the phone for me. 300ft lb is what the manual calls for and speaks nothing of thread sealant. I have a torque wrench that goes to 250ft lb.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #43
Turn of the nut method is very common with 3/4” and larger bolts. Amount of rotation of nut after snugging is factor of bolt length
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #44
And diameter, hardness, thread pitch and required clamping force. It's called 'torque to yield'. Very, very common in contemporary engines. Hardware is typically (but not always) single use.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #45
IF you don't want to use a "torque" multiplier", One can always make a torque wrench extension....
Example snatched from GOOGLE IMAGES (not my work)...
Suggest if you going to 600ft-lbs to go big on fabrication...
I'm amazed that this setup works but it apparently does. Seems like the torque wrench needs to be measuring "force" instead of "torque" applied to the outer end of the extension lever. I guess torque is the same as force in this case, I'm just not "seeing it".
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #46
Maybe you're thinking of torque as an engine or something revolves. That's rotational force x rpm = horsepower.
But in this case, torquing nuts, the rotational force is measured at zero rpm. So it is simple pounds applied - without motion - at x distance from the center of rotation. ie ft-lbs.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #47
Torque is torque whether it is pistons torquing a crankshaft or a torque wrench torquing a bolt. It is force trying to induce rotation.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #48
and the continuing discussion about....
is torque measured in
ft/pounds
or
pound/ft
i had a physics prof go thru the entire derivation years ago that illustrated that torque is noted in pound/ft
you can measure auto speed in hours per mile but .....
funny how people disagree on this term
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #49
I'm not sure if you are open to spending any money, but I bought a 3/4" digital torque adapter for this purpose. I knew my brush hog called for that level of torque, trailer lug nuts were 200, and the new gooseneck hitch I was installing on my truck needed 375. I would have probably settled for several ugga-duggas from my Milwaukee high torque 1/2" impact if it hadn't been for the Gooseneck hitch. That was the most important in my eyes, so I started looking and found this adapter. It may or may not be the most accurate item on the market, but I'm sure it was better than me guessing. For $80 or so, I haven't regretted it one bit, and have used it more than I expected.
Hey that’s pretty cool. Looks a bit delicate, but yeah, pretty cool.
Audible alert!
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #50
I would use a cheater bar and the "TFAR" method. (T-that F-feels A-about R-right)
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #51
Got to wonder why the industry developed torque wrenches, torque multipliers and developed torque specification if a 125 pound person bouncing on end of 4 foot pipe is good enough....
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #52
ft/pounds
or
pound/ft
Well since all my work and specification seem to be in FT-LBS I won try to argue anything... I will just stay in FT-LBS arena...
But!
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #53
It is a matter of "calibrating" the 125 pound person. After you do this a few dozen times with a torque wrench (or after breaking a bunch of bolts/studs) muscle memory lets you know how much to apply to a give bolt diameter. In most cases, the recommended torque is a ballpark number, not rocket science.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #54
Do we want to open the discussion on lubricated vs non lubricated surfaces and threads? 🤣
Its actually very important, 450 lubed is 600 to 650 dry. Buy an impact gun that does max 700 and let it rip.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #56
But!
thx for posting that article! for years i've been trying to get a straight answer and that did it!
i kinda miss those old physics problems when, after 2 hours you look up and say, what the he// am i trying to figure out?
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #57
Or some other math solution. I'd use a 2.5 foot bar and my 240 lbs.
Assuming you can get the nut in a horizontal orientation, you don't need the exact distance. Say you have a 3-foot bar, so you want 200 lb. on the nut. If you weigh 240, stand on the scale and put weight on the 3 foot bar until only 40 lb is showing on the scale. My approach is that if the number is so high I don't need to be too exact but you can get as close as you want with the above scheme.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #58
Assuming you have a scale handy. Most of the places I have to put 200lb of torque on a nut I don't have a scale that will weigh more than a few pounds available.
My bathroom scale is kept in my bathroom, about 100 yards from my shop.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #59
Redneck torque wrench... hook a fish scale to the end of your breaker bar?
2019 GALYEAN...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2020 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2020 Globe Trailer...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A61568)
2015 International...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
