Rotary Cutter Brush cutting for beginners...
/ Brush cutting for beginners... #1
Torvy
Super Member
North East Texas
TYM T574H
So, one of the tasks I will have with my new piece of land is maintaining utility easements. Technically, I could wait for the utility companies to cut them, but I live there, they don't. 2/3 of my easements are buried gas lines, so they only come out if there is a big problem...almost never. The power line guys are only worried about the trees and the easement is wide enough they are not really an issue. My wife and I are in agreement that we have no interest in a 'lawn'. As such, I will not need a finish mower (I am pretty sure). If we did have something later it would be extremely small and could be easily done using a push mower.
That being said, the land is wooded and seedlings and saplings will pop up rather frequently. There are also non-easement open areas (see avatar photo) that we need basic maintenance.
I am looking for something that is user friendly. I love to work, but I am not a mechanic.
My question or request: Please discuss the pros and cons of the rotary cutter versus the flail cutter. The budget will only fit one or the other. I am especially interested in hearing from people who have used both.
Thanks!
/ Brush cutting for beginners... #2
Not sure on any cutter to recommends, but I have found that any trees or sapling you cut either do it BELOW ground level or leave them tall enough tall enough to be seen and drive around.... Previous owner cut a bunch off about 6 inched above ground, and even after 12 years of working property still discover one or more with the mower deck of riding mower and stops mower suddenly trying to throw operator over steering wheel... Solution for me is dig down around stump and use chainsaw with "OLD" chain to cut below ground level...
Good advice! I think anything more than an inch or two diameter I would uproot the stump. I am considering a tree puller attachment that may help with that as well.
/ Brush cutting for beginners... #4
Thanks!
The more power you have in your mule the better; what do you know about tractors in general????????
A sub compact mule is out of the question unless you want to spend night after night mowing.
You also need to know how much snow you have to deal with each winter to purchase a big enough snow blower and back blade.
Just be very aware that you need to check what your liability if any is for this "easement" as you may not legally be able to mow it.
Do this easy work first then we can help you with a mower and a mule with a cab and air conditioner.
Do your home work first, find out if you can legally mow it then wander down the decision tree path and then do an upside down decision tree and then go to a
local dealer without your wallet or check book or credit card in hand and UNDERSTAND FULLY that that they are only interested in seeing that credit card slip across the reader or a bank check in their paws for an undersized mule and the wrong mower which is a rotary cutter as you want to cut everything down to 2 inches in height every time you mow.
If you can legally mow it your going to be years and money ahead renting a tracked FECON forestry mulcher and in so doing you will not have to mow that often to worry about it.
renting a mulcher with a flail head for a week or two will save you lots of money.
/ Brush cutting for beginners... #5
Between the two I decided on a flail mower with hammer knives. It mulches really really nice. Plus I found it easier to control size wise vs. a rotary cutter.
/ Brush cutting for beginners... #6
Depends on the scale. Are were talking 100' (or less) or 1,000' (or more)?
RCs are almost indestructible. They're good for heavier brush and saplings. OK on grass, but larger expanses of it less so. Fails have more moving parts and are therefore more prone to incurring mechanical issues: they require more maintenance than RCs; how much really depends on how used/abused. In general, flails are better suited for areas that have been well-worked and have next to no unknowns: flails don't like stumps and rocks; RCs don't like them either, but they don't suffer the damage that a flail might. RCs are cheaper to purchase.
If you're only looking to use a tractor for this I'd think about hiring someone else to do it on a regular basis. Might be more cost effective: keep in mind maintenance and repair costs.
I know enough to know that I don't know. Growing up, my dad was (for about 10 years) a partner in an IH dealership. I worked as a gopher in the shop and have a solid basic understanding of tractors...have driven the old-school stuff...but I am old now and the market has changed drastically. Thankfully, I live in Texas. On the rare occasions that it snows, I can ignore it until it melts. I spend my youth up north and appreciate your consideration of snow...just not a thing in my situation.
My legal issues are quite simple in Texas...I need to allow the utilities access to my property on their easements and if I build or plant anything on it, they have no liability if they destroy it. I cannot, for example, put a locked gate across the entrance. I can, however, put an old-school barbed-wire fence/gate. Worst case is they drive over it and I an have some fence mending to do. Again, I appreciate you thoughtfulness. I know easements can be a sticky wicket, especially in other states.
A forestry mulcher is WAY too much for me to handle. The easements are wide and only have weeds and small saplings to handle. The entire property is only 18.5 acres, so I probably have a total of 2-3 acres of easements and open areas to mow. These are also great ways for me to traverse the property. Even my small SUV can handle it. I'll likely cut 4-6 times a year depending on rain. I will look into the FECON option if we ever decide to clear some of our land. As it is, I really like the pine and the timber is a crop unto itself.
In all likelihood, I would buy most implements used unless they were a deal as a package. My bigger fear is that I buy too much tractor, not too little. I have a home boss who is how shall we say it nicely...frugal. She will be the only reason we were in too small a tractor.
/ Brush cutting for beginners... #8
@Torvey, my recommendation is a brush hog. You have no idea what is in those power lines and gas lines.. I mow them on our property and I am cleaning them up so the seat pucker surprises are fewer.. But i would not run a flail there. Rocks, stumps, you name it, its there. I think it would tear a flail to pieces.
As @DieselBound said, the rotary brush cutters are far more forgiving. Oh, you'll know it when you get on something.. but it wll survive. I took out a telco splice box that I did not know was hiding in the 10 foot tall stuff I was cutting.. that was quite the seat pucker surprise! Now I know its there and it will never happen again.. but that first cutting... you have no idea what is laying there.
Walk it.. its a good idea. Walking 15 acres and several miles of trails was a bit much to ask. I chose to cut it.. ran the brush hog high at about 6" that first time. Then dropped it to 4" where I cut now. 2".. and I would have lots of trouble.
Thanks! This is exactly the type of thing I am looking for. I've used cutters and mowers before, but never a flail. The tractor will be part of overall land management. Most of it is timber, so I will be using the loader quite a bit and maintaining the driveway, tilling a garden, fencing, etc.
The open area in my picture is part of about a 300 yard long cut through the timber. Eventually, the center will be our driveway (gravel, rock). We have 3 big easements that cut the property. They total about 1000 yards by about 30 feet wide. There are a few other open areas that will be cut until my home boss decides if she wants to plant something there, then it will be tilling or digging holes for trees. I am sure in the first few years it will be a rough area to mow as it has not been well maintained until the developer prepped it for sale.
/ Brush cutting for beginners... #10
I hate using a RC'er. I have rocks and have thrown softball size ones over 50ft. When I traded my tractor I included it in the trade.
My approach is different. I have a few areas that I used to brushhog but am trying an annual cover crop. I am using Dutch White clover as it grows 6-8" high and is suitable for my climate. I see no reason to mow it and it will feed and attract deer. By letting it go to seed, it will reseed itself over time.
I was able to establish it by spraying with Round Up and after the grass died off, using my landscape rake to level things out and scratch up the ground (mostly sand). After seeding, I reversed the rake and used it like a cultipacker to lightly press the seed down a bit.
I planted it last fall and it has done well. I may overseed a bit in some areas this fall. Seed rate I used was 6-8 lbs per acre. $50 for 10 lbs for the stuff I got, but I have seen it for $150/25 lbs.
Not sure what will work in your area but something you do not need to mow would keep things simple.
/ Brush cutting for beginners... #11
Thanks!
You are correct, you have no obligation to maintain the easements.
I chose to for my own use (& to please the wife.)
I use a finish mower.
Have a bush hog to do "extra" clearing in the woods & swamp.
If I only had one, it would be a flail mower.
They can cut almost as nice as a finish mower or do almost as much as a bush hog depending on how you adjust it.
Thanks! That sounds about right. I have driven the SUV over it and the new electronics really hate me. (kept slamming on the brakes for the weeds, haha) I wonder if dragging a log/fence post on chains (horizontally) would help to discover some of the hidden surprises. Eventually, I may plant something under the power lines (probably to hay). Cannot dig over the pipeline, though.
At some point I am going to need to do the math to figure out how long it will take to mow all of that. The good news is that I will be official retired and since no critter will be depending on me, I can do it tomorrow. That is especially useful in Texas summer as I will likely only be out there from 6am to noon at best. Too hot to work outside in the afternoon unless it is urgent.
Front....View attachment 706846
Over the hillView attachment 706853 View attachment 706854
Wow! That looks like a fairway! I am highly unlikely to ever try to make it look pretty. Knock down the noxious weeds and insect habitat. Make it more easily travelled. It is clear on part of the easement that the utility companies have not been doing their job. In some spots there were saplings/young pines that are at least a few years old.
I could see myself doing something like that eventually, especially under the powerlines. Not sure if alfalfa grows well in that soil, but I know I could trade a few hay bales for some beef, especially in years like this where it is dry up north and we get rain. My cousin runs over 1000 head in the Black Hills and they always seem to be buying or selling hay depending on the weather.
/ Brush cutting for beginners... #15
Be careful what you wish for. Growing and harvesting alfalfa takes more and bigger equipment. None of which is cheap. The reason I suggested clover is that once it is established it should be done!!! No more work and no stuff to maintain.
Frankly, not sure if it will be successful at smothering out weeds but it is worth a try for me.
/ Brush cutting for beginners... #16
Don't know your budget, but an out front mower is so much easier to use.
Paid 8 thousand for this used TORO 328D in May of 2014:
That is a 6' recycler deck.
This Toolcat is more versatile with FEL and 3 point hitch, new cost was 55 thousand in December of 2012:
Handles the 1800 pound, 7' brush hog just fine:
More pictures here: Toolcat 5610 F and 5610 G Series Pictures
Good luck with that...clover is good for bees as well, if you want another side hustle.
/ Brush cutting for beginners... #18
Rotary cutter. It will cut those saplings and shatter/splinter the trunks and they won't be a problem. The bigger stuff cut 4 feet above ground and pull the stump out with a chain. Cut the 4 foot piece off and toss the stump on the burn pile.
/ Brush cutting for beginners... #19
I think a RC is your best bet.
Buy a good one with the hanging chains. I was cuttingunder a pecan tree and the RC sent a pecan forward which hit the front tire and then hit me in the forehead. Knocked my hat off, and almost knocked me out and off the running tractor. I shut it down and took about 30 minutes to recover.
Be careful.
/ Brush cutting for beginners... #20
Be careful.
But did you get to eat the pecan???
Glad you're ok!
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
2006 Chevrolet Express 2500 Cargo Van (A64556)
2006 Chevrolet...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
