any toro groundsmaster fans on here?
/ any toro groundsmaster fans on here? #961
Was thinking of doing this as well. it seems all the grease fittings are 1/4 20 and all extensions I can find are 1/4 28. You found a grease gun hose with 1/4 20 to 1/8 npt? Or are the threaded fittings on your machine 1/8 NPT
Added some zerk fitting extensions to my groundsmasters today. Used a grease gun hose, 1/8” npt union, and zerk to make them.
I put the extension on the forward pto zerk because they are so hard to get to.
The buffalo turbine had three zerks under the safety grill, so I put some extensions there too so I wouldn’t have to pull the grill to grease. The extensions cost about $6 each to make.
/ any toro groundsmaster fans on here? #962
Hello everyone, I hope this thread is still active as I just purchased a Toro Groundsmaster with a 72" deck. It is in need of some love and I need help identifying exactly what I have. It has been repainted. Thankfully they left the Serial Tag on it. It's pretty beat up but what is readable on it is "30788-80929". It has a diesel engine as well and it is 2wd with power steering. Is this machine a 322-D or a 325-D? I have no idea how to identify it other than serial number. Also, the deck has a gearbox that is NOT a square it has a 45 degree angle gearbox. I called all the Toro dealers around me and they all tell me they can't get anything for it and they have no idea if its a 322-D or a 325-D. Any help would be greatly appreciated! Thanks!
/ any toro groundsmaster fans on here? #963
Wow! What a wealth of information on the grounds master mowers here. I just acquired a 328d with the kubota that needs a new hydraulic pump unit. Any guidance to what model number pump this is? Mower is quite some distance away and everything still needs a good cleaning for me to ID. Anyone know what they're looking at here?
/ any toro groundsmaster fans on here? #964
Toro has a lot of manuals online that could ID this for you. Have you looked online yet for your model/serial number to get a part #? If not you can do so here: Redirecting...
I did look a bit and found this: Redirecting...
Part # for the assembly (CHECK TO VERYFY!) that I found is
92-8947
TRANSMISSION ASM​
/ any toro groundsmaster fans on here? #965
its a 30626 22000000 range 2wd not sure if that helps id year? from your post looks like 92-8947 is correct
/ any toro groundsmaster fans on here? #967
From the model and serial number it is a 1988 322D:
The angled gearbox is right for an early model deck.
The 325D has an adjustable steering column, so the columns look different.
/ any toro groundsmaster fans on here? #969
Thank you very much! I was trying to find the difference between them and did not know that was a difference. Mine is not adjustable, so that makes sense!
/ any toro groundsmaster fans on here? #970
Have 3 345's and one PTO had some play and wobble so replacing the bearings. The ones we took out have a groove in the side I assume for the grease, the new ones I ordered which I ordered via part number from the part diagram don't have the groove.
Anyone come across this?
429970 (A61165)
429970 (A61165)
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2016 Nissan Sentra Sedan (A59231)
2016 Nissan Sentra...
2004 Volvo VNM S/A Day Cab Truck Tractor (A59230)
2004 Volvo VNM S/A...
2004 Ford F-450 4x4 Venturo ET18KX 2 Ton Crane Service Truck (A59230)
2004 Ford F-450...
2017 FREIGHTLINER CASCADIA SLEEPER (A59906)
2017 FREIGHTLINER...
