problems with my drainfield
/ problems with my drainfield #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
New system that has finally passed inspection, during cover up I noticed the sand making holes in the drainfield fabric. Large holes as in tears. Why would this happen? Cheap fabric? I told them to stop. They claim fabric isnt even a county requirement. I do not believe that and am going to investigate further.
Ive had one problem after another with these people. They werent the cheapest but they should have been.
The fabric has been exposed to the elements for a couple of weeks and we did get alot of rain.
Ive said it before and Ill say it again as a warning, you have to watch everyone cause they will always do whats best for them and disregard your interests.
/ problems with my drainfield #3
Perhaps the SUN ruined the fabric?? left out
in the sun will destroy a lot of stuff! Should make
them put a new layer down on top of whats already
there!
willy
/ problems with my drainfield #4
Confirm requirement with the county. Are these people even licensed for septic installation? Do they use fabric now instead of straw for drain fields?
/ problems with my drainfield #5
I think you will be OK. They are correct that the fabric is not a requirement on top of infiltrators...., but it is a nice touch - especially where you have fine grained soil like yours looks to be.
Since you are concerned - and if the county will allow - it wouldn't hurt to put another layer of coarse & heavy geotextile right on top of that existing fabric. Home Depot carries some good gray geotextile fabric. Geo fabric slows down dirt & sand infiltration but doesn't completely block it and also allows for some air to get down there.
You are always wise to stop and get an inspection now when you have concerns. Expect to pay a reasonable stop work fee. But where you are at right now is about the right point to call for inspection. If already inspected, then simply proceed.
Those black plastic infiltrators work differently than drain tiles, but what you have going there looks like a nice job.
From what I see in the photo, my engineering profs would be pleased.
rScotty.
rScotty.
They brought out a 50 hp tractor to fill or cover up the drainfield, a tractor would have destroyed the field by running back and forth over it, they should have brought a mini ex or something similar with a long reach bucket to fill it in. They simply do not care and assume I am ignorant.
There will be no stop work fee, if anything they should be refunding me for my wasted time meeting them out there more than once because they have blundered something.
/ problems with my drainfield #7
This is my new septic with infiltrators; no need for fabric. Yours aren't as deep, but that is probably a FLA thing. Mine are 72 inches to the bottom, 54 inches to the top. I had no issues driving a tractor over them for backfilling, but my soil looks much more stable than yours.
/ problems with my drainfield #8
The fabric isn’t needed. I don’t even know what good it would do. It’s intended to go on a gravel bed system and keep the dirt out of the gravel. But covering the plastic I don’t see any point. Also as deep as that is covering it with a tractor wouldn’t hurt anything as long as it was adequately dry. Until mini excavators and skid steers got popular a few years ago virtually all septics were put in and covered with backhoes. A lot of septic guys still use backhoes now for septics. They’re pretty good at that job.
What is going to keep the loose sugar sand from going inside the infiltrators and clogging any drainoff as it leaves the tank and flows down the infiltrators? There are holes in the sides.
I guess Im not seeing how laying hollow half round plastic tubing in the sand is going to control/disperse the waste to begin with?
Driving a tractor over the loose sand would surely throw the level of the outlet pipe off at a minimum which of course would render the size of the field nearly useless.
/ problems with my drainfield #10
The outlet pipe is supposed to lay on undisturbed earth so it can’t settle. And nobody with any sense would drive the tractor straight on it. Work from the high side and push the dirt in. It’s deep enough it’s not going to hurt it. A tracked skid steer would definitely be better but there’s plenty of systems that have been covered with backhoes or tractors.
/ problems with my drainfield #11
It's your system,you will live with it long after installers are gone and it's your money paying for it. Get it like you want it ow because a do over later on isn't much of an option.
/ problems with my drainfield #12
We are required to use butcher block paper on top of the 4 inch pvc pipe with holes but the half plastic boxes just dirt and 3 feet is the max depth of drain field as of 15 years ago.
willy
/ problems with my drainfield #13
That's encouraging. Realizing that you are not seeing all of how it works is the first step in understanding what is going on.
Those side slits in the Infiltrators are not just there by accident. They are a compromise and are angled so that in most soils the natural cohesion of the soil (clay content) will keep the soil intact next to the plastic and little soil will seep inside.
The ability of soil to stand up is called the "angle of repose". The infiltrator people really ought to make different infiltrators for different soils. Probably will someday
Sugar sand like you have there is a special case. It has very little clay content and it doesn't stand by itself at all. The angle of repose is very small. That means the sugar sand will tend to seep sideways - hence the need for the geotextile covering to prevent it entering the slits just as you said.
But the same low clay content means your sugar sand exchanges gasses well and also does not compact under load like a clay soil will do.
So....in your installation the infiltrators can be a little higher, and compaction of the sand on top is not generally going to be a problem.
I agree completely about the need to support the piping to the infiltrators & wish more installers paid more attention to that. It's the weak point in many septic designs. Good catch.
rScotty
/ problems with my drainfield #14
I had a similar septic system installed 20yrs ago. On my system the waste is held in septic tanks to decompose & liquid is absorbed by soil around/under infiltrators. If solid waste is under infiltrators then septic system is not operating as designed.
Come to find out according to the county the cloth is not mandatory nor needed. It would have passed inspection whether it was there or not. Evidently the slits are facing in a way that sand supposedly will not fill the infiltrator. I am anxious to examine these more closely this weekend when I get back there.
/ problems with my drainfield #16
That sounds like how a standard system is supposed to work. The key to keeping a septic working is as much in the multiple section septic tanks as in the leach field. Porous fabric over the infiltrators may or may not be a requirement - county regs vary widely - but in some soils it is a good idea.
/ problems with my drainfield #17
That sounds like how a standard system is supposed to work. Porous fabric over the infiltrators may or may not be a requirement - county regs vary widely - but in some soils it is a good idea.
In Florida sand it IS a good idea!
/ problems with my drainfield #18
If you are really that worried about the ripped fabric back fill to the top of the chamber with crushed stone and use road fabric for a soil separator. Road fabric is far stronger and the stone will act like a bigger drain field along with helping to keep the fines out of the chamber.
Are you installing inspection ports at the far end of the chambers?
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A61572)
2013 Hitachi...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2019 Ford F-150XL (A64119)
2019 Ford F-150XL...
