MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,909
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Thanks Egon.
My Get-up-and-Go Got-up-and-Went!We still have the ambition and ideas, Doofy, just not the energy. Yes - MANY fond memories of our times in Alaska.
IF you have the chainsaw and want to do it at low expense a chainsaw mill MIGHT be a solution.I have about 10,000 black locust trees. About 2000 of them are 12-20" diameter. I'd like to make 6x6 or 8x8s and use them to build a post and beam screen house by our pool in the next few years.
Thanks for the info.IF you have the chainsaw and want to do it at low expense a chainsaw mill MIGHT be a solution.
BUT black locust is HARD and you'll probably need at least a 90CC saw to do the cutting.
I've done 16 to 20 inch red maple with a 62CC saw and it was slow (and low). Moved up to a Stihl 660 and it was easy.
I've a 120CC in reserve.
0 Attachments
BUT if you don't have the saw an entry level Woodmizer or other brand sawmill is only about $3,500 and will save your back.
A good 90CC costs about $1,000 or more. And if you have 2,000 trees you could make good use of a sawmill.
Not much to it. The bar has a hole drilled in it with a 1/2 in. pillow block bolted on. Then a 1/2 in. rod is welded onto a flat iron plate that is bolted to the sliding frame and goes through the pillow block. Then a bunch of one in. Spacers to vary the thickness of the board being cut.For softwood (hemlock mostly) snapping lines, cross scoring with the chain saw, and then chipping out the waste with an axe makes for pretty fast work. I did all the floor beams in the shop that way. (24 x 32) one side only.
A D handled garden spade works pretty well as a spud to debark. Just let the tree set about two weeks after cutting to loosen up the bark.
I really like that guide frame set up Egon! NICE!
Can you show or describe the bar clamp details?
I'm NOT doing 2000 trees. I have them. But I'm not doing them.
Just looking into do enough to make a 12X16 screen house.
Thank youI used an Alaskan mill from granberg to cut two 2" planks, by 7' and used the bottom half for a garden bench.
I have a 20" bar on a 50cc with a ripping chain and it worked pretty well. Used a dead Ash trunk.
Very limiter width (about 10-12") width with that size bar.
First time got some scoring, took down with a flap disk and then orbital sander. Looks pretty good.
Started by screwing on an 8" 2x8 to the trunk, so came out pretty straight.
Egon, that setup is really nice!
From what I was told by our state forester, black locust was planted heavily around here for erosion control. The roots spread out and hold the soil in place.Around here black locust are found at/around old homesteads. They are not a native tree and were planted by homesteaders. Make great firewood and also fence posts. The problem - there just aren't that many.
I look out my kitchen window and see five Ponderosa pines that have been attacked by Pine Bark beetles. They were green trees last year. Most likely attacked because they were under stress.
In any case - I've got to cut them down and burn them. The beetles can cover and kill large swaths of pine forests.
That hurt shooterdon. That hurt.MossRoad,
Looks like in your situation a chainsaw mill is the way to go. Unless you get a "real" tractor...LOL
