clearing land
/ clearing land #1
rickyb01
Mayflower
1976 Deutz 3006 1962 John Deere 1010
I have ran into a bit of a snag. I cleared about 3 acres for a home site and have started clearing another 4 acres for a back yard or open area to home site. Most of the work I have hired done and they removed 7 year old pines so not much of a root. The person I hired came in with a small dozer and piled all the pines up which I have burned. The dozer started on the back 4 acres but at the time it was just to wet and really tore up the ground before I was able to get him stopped and on his way. Currently I have a 65 horsepower 2wd tractor and a front end loader. I have managed to take down the rest of the pines on the back 4 acres with tractor. I'm looking to buy a New Holland 70 workmaster 4x4 and the dealer I'm purchasing it from took it in with a bad hydraulic pump which they are changing out for a new one. It also has the third remote. Looks like it will 4-6 weeks before I can pick it up due to most of the staff has covid and not working. I have a 66" wicked grapple on order that will take 14 weeks to get here. After saying all this what choices do I have on cleaning up this area now with my 2wd. I thought about a rock rake but I think my tractor will overpower one and just tear the tines off or bend them up. I have an old chisele plow that was my grandfathers that I could sink in the ground for a foot and see what it does. There is a lot of small debris that really needs to be removed somehow and I really don't want to do it by hand. Any implements that I can use to help with this or am I looking at waiting for my wicked root rake to come in. For some of you guys that have done this what are the next steps on getting that three acres of yard ready? Mostly I would like to remove all the small pine branches that were broken up. No rocks to speak of and ground already has a nice slope to it. I thought about hiring someone with a root rake on a dozer to come in and make a pass but being a rural area I cant find anyone that will do it. Looking for suggestions.
/ clearing land #2
So you are asking what you can use to clean up smaller debris on that back 4 acres where you have already cleared the trees? Can you describe the debris? Size, type, density? Still have stumps or other trees standing?
/ clearing land
Basically both areas since I have the trees taking off. The front three acres is down to dirt with no grass but a bunch of small broke tree limbs or sticks. None bigger than a 2" and I picked most up by hand on the bigger stuff.
One the back four acrea I have taken all the pines down and going spray the grass to kill this week. Going fill up the ruts that dozer left on the back 4 acres. The back has some roots and bigger debris to move. Really would like a dozer with root rake to go thru there but may have to wait on my root rake for tractor. Implements that I have are chisel plow, disk and box blade. I also have a home made drag out of chain link
/ clearing land #4
You need something to push it I assume because you can't run over it first. Do you have a bucket on your Front Loader? Why not just try and push smaller bits of it up into a pile?
/ clearing land #5
Sounds like fairly small material in the front part, if it were me I'd disk it a few times then rake it. Probably be ready for grass seed with one or two chucks of wood here and there you could hand pick.
I'm confused about the back four. Why do you want to root rake it? Another option for $150, or so, subsoiler and break up/pull obvious close to the surface roots and material. Then disk and rake.
Guess it all depends on what you want to do with it since I assume you're not trying to build a 3+ acre pad for a house.
/ clearing land
[U]Jchonline[/U] its a little to much area to push up in a pile. I do think I could start disking it and then maybe run a rock rake thru it to gather up my wood (trash)
Sea2summit the back 4 is not as clean as the front 3. There are some roots still left and some ruts left by the dozer. Of course I can go thru and hand pick up most wood branches 2" or bigger but that's a lot of work. And I can only do this on the weekend because I still work during the week in another town until the end of this year.
The 3 acre is basically going be my yard where the house will sit. The 4 acres will be an opening in back that will be bush hogged. Now I have had an engineer down and his recommendation for the four acres is to strip the three inches of top soil off and add a foot of fill and spread back out the top soil. Right now I don't see how someone can strip off topsoil until I can clean it up better, get trash out and level those ruts.
/ clearing land #8
A foot of fill on 4 acres is 400 large dump truck loads.... You need at least a D6 dozer for a few weeks to strip 3 inches, spread a foot of material and then redistribute the top soil. Unless your pockets are deep, live with it for awhile and do a little at a time with your new equipment.
/ clearing land
JJT good catch but I’m only going do about 1 acre at a time. Should have typed that in. I’m going to go talk with a farmer that selling off his land about his case 550 dozer. If he is selling I may be buying it.
Jeff9366 you think the ratchet rake will catch all or most wood and let dirt thru. Looks like it may act like a scrapper blade when pulling backwards making pile of dirt and sticks?
/ clearing land #10
It sounds like a job for a landscape rake to me. They can be had with gauge wheels to if your worried about it digging in too much.
/ clearing land #11
I agree a landscape rake is the best solution for debris. But if you want to improvise get landscape tines here $100 and bolt on with u bolts to your box blade. Lot of 15 Rake Tines 13 3/4'' x 15 1/4'' Landscape Rock Rake Tines NEW FAST SHIP | eBay
Rake debris into piles and back drag piles into one large pile with loader then burn eventually, then chisel plow 3-6", rough level with your bucket, then disc with the drag then seed.
/ clearing land #12
I have the Ratchet rake and yes, it does collect everything and clog with dirt and sticks. For my bony/rocky soil reclamation from stumped ground, it was useless as it bounced off the rocks and left plies of sticks everywhere. So a landscape rake is a better option to windrow (angle) the major debris into piles every 10' or so then scoop this/back drag with the FEL, leaving the small 1" stuff to till or disc in.
/ clearing land #13
I was going to suggest the same thing. I removed every other tine from mine and put a 100lb suitcase weight over the pivot and it acts far better for large debris now.
Landscape rakes also have so many uses when it comes to putting in lawns and maintaining gravel driveways so ita not something you will only use once. There also not very expensive. A hell of alot cheaper than putting even 6in of fill on 1ac.
/ clearing land
Carl_NH you gave me an ideal. A couple of years ago a neighbor gave me a couple of grader blades to get them out of his yard. I could order those tines and covert one to a rake. Beats spending 500-800 for one. Rick
/ clearing land #15
You already have a chisel plow. Hook that thing up and go to town. That's what I use to drag debris in piles. and it breaks up the ground and does a good job at filling in stump holes. I have a 7 shank chisel plow that I can pull as deep as I want. It's going to collect debris but just raise it up and back up. Pull it all to one area and pile it with your loader.
/ clearing land #16
I'm in the process of "upgrading" one of my barren fields. It's about 10 acres. I live right in the middle of the area that is/was affected by the current "heat dome". So, you can appreciate that I didn't first burn off this field. I'm not too overly keen on RoundUp either.
First, I disked the hell out of the field. Then followed with my LPGS - scarifiers down. Then LPGS with scarifiers up. It's now smooth as a babies butt.
I'm going to plant it to a wildflower - dry land grass mix. I'm waiting for the wet season, this fall to spread the seeds. I just hope we have a wet season this fall.
/ clearing land
Yes sir I am doing that this weekend.
OOSIK what’s a lpgs
/ clearing land #18
Land Plane Grading Scraper. Another implement used to smooth out driveways or tilled land. The beauty of this implement - almost zero learning curve and it does a great job. Kind of like a high tech woven fence drag. Just hook it up to the 3-point and pull it.
/ clearing land #19
Like this. This is one I just finished fabbing up. I'm waiting on some dry weather to Ospho and paint.
/ clearing land #20
Can't wait to see how it works!
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
International 1020 15' Platform (A66408)
International 1020...
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
