/ Harbor Freight Tools that don't suck #14,441
My battery operated fuel pump bit the dust an hour ago. Guess I'll have to go buy a new one for 11 bucks. This one lasted 3 years. Not bad for 11 bucks.
Mine's still going strong. Long as the Duracell D-size batteries keep going. 😆
Lesson also learned, do not keep batteries in the unit, only when using them. Batteries will leak. Hard to find rechargeable D-size at a great price.
/ Harbor Freight Tools that don't suck #14,442
Don't post that on the other forum we are on, someone will want it....lol I suggested to HF that they need to convert it to a Li-Ion batter pack that interchanges with the Bauer stuff. They are hard on batteries if you use them a lot. the motor gave up on my first one so I bought 2 this time. still the same price.. Now I have a spare. Got almost 3 years out of the first one and that is a lot if diesel fuel pumped (in the field). My open station M9 has a high fill cap behind the seat and it's hard to fill so I use the battery pump.
checked out the V Belt store you suggested. be getting my belts there from here on out, thanks.
/ Harbor Freight Tools that don't suck #14,443
Note that I bought the Harbor Freight 3/8" Earthquake ratchet. I did a couple small jobs (intake manifold gaskets, installed some accessories, but infrequently used over a 2 year period. Went to use it last week and ripped the head gear smooth. Junk. Can't buy a head insert like you would expect. Had no choice but toss it and go buy a Milwaukee fuel 3/8" ratchet. I doubt a Milwaukee will break. It's the gold standard behind the stupid $500 Snap-On.
/ Harbor Freight Tools that don't suck #14,444
I have an air ratchet. I really prefer air tools so long as I'm near the shop and the air line.
Brings me another really good bargain from HF..
I bought one of their driveway monitors 3 years ago and other than new batteries every 6 months (not HF batteries either) it works flawlessly. One sensor in the drive and one sensor out by the barn on the round about drive. I always know when someone is in the drive. Bunker Hill, 10 bucks (batteries not included)... good buy in my opinion.
keep forgetting to mention it...
/ Harbor Freight Tools that don't suck #14,445
Was just out in the shop working on a metal project and using my Chief 4.5" angle grinder to dress some welds. I have to say, it's amazingly quiet, much quieter than any electric angle grinder I've ever used and well balanced and very smooth too but what really got my interest was, because I like to look 'under the covers on power tools' was the grease ports in the gear head. There is one in the front above the spindle lock, a removeable screw that accesses the gear train that you can apply grease in and another on the top of the polished aluminum housing that is a needle grease port, just like my high buck IR impact guns have so greasing the gear train is easy (even though there is no mention of it in the included instructions).
This tool is built to last a long time. I'm impressed.
Usually on corded angle grinders, first thing I do is take the head apart and replace the 'smooze' grease that is usually inside with quality synthetic grease, which helps them but I tend to find the smoke in the motors anyway, especially the cheap (and noisy) HF corded grinders. What is inside the cheap HF and other cheapo grinders don't even look like grease, looks like fish guts and everyone is noisy and everyone gets hot pretty quick. I don't baby any of them, I run them hard or until I find the smoke and I'm good at that.
Peering in the Chief, looks to me like it's filled with quality lubricant too. I'm impressed, but especially impressed with how quiet it runs. No geartrain noise at all, just the air exhaust and even that isn't bad. it's well worth 100 bucks.
First time I used it hard.
/ Harbor Freight Tools that don't suck #14,446
I bought the
BAUER Corded 4-1/2 in. 8 Amp Paddle Switch Angle Grinder with Tool-Free Guard and have been pretty happy with it.
Used to cut some metal and flap disks and shaping disk on wood.
/ Harbor Freight Tools that don't suck #14,447
I bought one and it quit operating within a few months. Luck of the draw, I guess.
/ Harbor Freight Tools that don't suck #14,449
I keep forgetting to post up my experiences with my Pacific Hydrostar 3200 psi Pressure Washer I bought about 8 years ago. I believe the Pacific Hydrostar brand name has been dropped but HF still offers the pressure washer under another HF coined name..
Anyway, bought it 'open box' for 250 bucks 8 years ago and it's been flawless and I use it a lot. I wash down all my farm equipment and my vehicles summer, fall and winter.
I keep it in the heated shop in the winter so it don't freeze (a frozen pressure washer pump renders it junk as it cracks the ceramic pistons inside, always drain one if stored in an unheated space and add pump saver or RV anti-freeze before storing.
So on with the review.. Has a Predator 6.5 engine, don't have a clue how many hours on the engine but still has the original spark plug and I do change the oil and clean the foam air filter every fall. The radial triplex pump has also been flawless and the pump oil gets changed when I service the motor (30 weight non detergent motor oil).
The only negative is the hose, it was a cheap plastic covered hose that died pretty quick so I replaced it with a real pressure washer hose (wire braid, neoprene covered with quick detach ends from Amazon fir 55 bucks, that issues solved.
The wand has been trouble free though I've replaced all the spray tips (they have them at Menards for 10 bucks for an entire assortment).
I also purchased a foam cannon from Amazon that fits on the end of the wand's quick disconnect, works well for dispensing car wash and ZEP Purple degreaser.
Bought a spare pump from Northern Hydraulics because I figured the supplied pump would puke pretty quick but 8 years later, still going strong as is the engine and the whole thing is mounted on a nice cart with real wheels that have air in them...
I totally recommend the pressure washer. heck of a bargain and long lasting and trouble free.
/ Harbor Freight Tools that don't suck #14,450
I just bought the EU2000 Predator inverter generator....kudos to 5030 for talking up the Predator engines...I decided to give it a try. I plan to use it for my border line tree trimming // hedge trimming. Ran it for several hours today and am pleased as punch so far!! Cost me $540.00 but is still way cheaper than other name brands.
Extremely quiet, sips fuel, powers up my corded hedge trimmer and Portland electric chainsaw; starts easily, and is easy to move along by hand. It's about 47lbs - so not real light but is hand transportable.
To be safe I also bought the 1 year extended warranty but am hoping I don't ever need it.
I didn't feel so safe with the Portland chainsaw so I got the 2 year warranty on that item. I know some think those extended warranties are useless but it just made me feel better knowing I can just bring it back for an exchange if it goes bad before time runs out. Hopefully I'll not need it and just mentally kick myself for spending extra $ but...if it shows the smoke - it just goes back. Keeping my fingers crossed.
Thanks for the pep words about Predator engines 5030, that pushed me to go ahead and get one.
/ Harbor Freight Tools that don't suck #14,452
I just talked my BIL into buying a 2000w Predator. It is very quiet just like my new Honda 2200 and it is one pull to start.
I would have done the same except I want to try paralleling it with my Honda EU3000. Now that I said this I suppose I should post again in the genny thread.
/ Harbor Freight Tools that don't suck #14,453
Maybe this belongs in a different thread: I bought HF's smallest hitch cargo rack, the ATV version. Then I made a 1.25 to 2 inch receiver adapter to put it on my little Ford Focus Wagon. The rack is rated 300 lbs but I don't expect to load it over maybe 50 lbs, to maintain stability on a light car. In 100 miles each way last weekend I never felt any inertia as great as the effect of ordinary crosswind.
To mount the rack on the Ford's 1.25" receiver, i welded HF's ATV Hitch Adapter to an extra 1.25" hitch stinger to make the needed 2" receiver.
And an untended stress test for the adapter - I bottomed it hard coming out of a gas station. This was before I had painted it. The welds and the hitch overall showed no damage. It's a keeper.
/ Harbor Freight Tools that don't suck #14,454
I assume you’re describing the Lynxx 40 volt pole saw? I’ve got the pole saw, chain saw, and the leaf blower. I use the pole saw a lot for trimming up lower branches on oak trees for clearance for tractors. I also use the pole saw for cutting down cedars. I can reach in and notch it in the direction I want it to fall, the cut backside until it goes over. The battery life is very good and use of Oregon bar and chain is a plus.
When I got my 40 volt chain saw it leaked oil bad. I took it back to the store, for an exchange, and the manager told me to keep the battery and charger so .. I now have a spare battery.
I keep some bar oil in a mustard container .. flow is very controllable. I also use a similar mustard container for blue marker dye for sprayers.
I love how long the pole saw cuts without needing sharpening! Got scared the other day as it made an awful noise like the drive gear tearing apart. Took plastic head apart (783 screws, give or take) and there were screws that should hold the motor and worm gear in place against the chain drive gear. Screws had backed off letting the gears not engage but make bad noises. Tightened, reassembled, works like new!
/ Harbor Freight Tools that don't suck #14,455
I've a rather long driveway (~100 yards) with overarching trees and limbs about 10' to 12' above the pavement.
I've an Echo pole pruner that goes out 17'. But I prefer to use my HF Lynxx and my M4700. I'll stand up by the seat, trim a few limbs, sometimes dropping them directly in the bucket. Creep forward, repeat. Then come back and pick up the trimmings.
With the Echo there's less wear and tear on the M4700, but more on me.
But there have been rumors that the Lynxx line is being discontinued.
linky
/ Harbor Freight Tools that don't suck #14,456
I really like the riding mower lift for hosing off underneath after mowing damp grass and mud. Well made and a great price after 20% off! Had it for six years and no problems. 👍🏻👍🏻👍🏻☮️✌🏻
/ Harbor Freight Tools that don't suck #14,457
Have one as well, has to be 5 years ols, no issues. Have one of their floor jacks too. No issues with that either. It's the 'Rapid Pump' model in aluminum chassis.
/ Harbor Freight Tools that don't suck #14,458
Mine is the ‘Rapid Pump’ aluminum model also…The only problem I had was with the welds holding the handle on broke, so I just drilled for a bolt and nut problem fixed!☮️✌🏻
/ Harbor Freight Tools that don't suck #14,460
linky
Already has been, haven't seen any Lynx tools in my nearest store for the better part of a year. They did have some 40V batteries out back, picked up an extra one "just in case".
A shame, I have the pole saw and the 14" chainsaw. Both are decent enough for the price, but lesson learned on HF battery tools.
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
FONTAINE SPECIALIZED LOWBOY (A60736)
FONTAINE...
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
Auger and Bit (A60352)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
