What is this valve?
/ What is this valve? #1
Florida2610D
Member
Yanmar 2610D
Yanmar 2610D
In front of the seat I have the 3 Point Lock valve.
Under the seat I have the 3 point speed valve.
Behind the seat on the side of the top link mount there is another handle/valve that moves about a 1/4 turn. What is this? Nothing in my documentation explains. I did not have this in my 155D.
Thanks guys for you input.
/ What is this valve? #2
Yanmar 2610D
Ah a fellow YM2610 owner. That sir locks the 3PT. And it pinches fingers too if you are not careful. ;)
/ What is this valve? #3
Yanmar 2610D
BTW, should you need the Parts Manual in PDF I can show you how to get it. :)
Thank you Sir. I figured you would be the first one to answer this question. So I assume this is a mechanical lock as opposed to the valve lock to the front?
/ What is this valve? #5
It does seem to be this way. Just be glad our machines are not like the F-FX Series with the 3PT UFO confusing controls.
/ What is this valve? #6
You got me to look at it again today. Yep, it's there. Just a lock-stopper at the back end to keep the 3PT in one position.
Wonder if a machine with a loader can still work up front and the 3PT can be locked. Makes sense as the knob under the seat would turn off both.
I tried closing the valve under the seat once, the tractor screamed at me to turn it back on. I don't think it plays well with the FEL spliced in the system.
/ What is this valve? #8
Nice tag line.
I'm debating on a 3PTO PTO tiller or a Hiller as the next attachment. Want to share the type of hiller you use. :)
/ What is this valve? #10
Really nice.
Yes, you need a disc harrow. A bottom plow does only 1/2 the work. The other 1/2 is the disc harrow. Or sell the bottom plow and get a PTO tiller. ;)
This is the KK from TSC or FnF.
I have a 5 ft tiller and I love it, but what fun is plowing if you don't have a harrow?
2019 PITTS LB35-33CS CUSTOM DELUXE LOWBOY TRL (A64276)
2019 PITTS...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
JCB 92" Clamshell Bucket (A64119)
JCB 92" Clamshell...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
