Looking for a multitasking utility trailer
/ Looking for a multitasking utility trailer #1
hube2
Paris, NY
Masey Ferguson GC1725M
I am looking for a trailer and not having much luck. Maybe what I'm looking for does not exist. Thought I would ask here and see if anyone has seen what I'm looking for.
What I'm looking for
  1. Needs to be enclosed, sides and back, so that I can haul small sized stone without it leaking out. This is where I'm having a hard time finding anything.
  2. It does not need to be capable of hauling my tractor
  3. Looking for something that can carry about a ton, give or take (1500-2500#)
  4. Would be nice if it had the ability to dump.
  5. Needs to be road legal, lights, etc
  6. Would like to be able to also tow it behind my tractor
  7. Light enough so that I can push/pull it around when it's not hooked to anything
I have been able to find enclosed trailers I can tow behind my tractor, but they are not made for road use. The only road trailers I have found have open sides or back which would not be suitable for haling stone.
/ Looking for a multitasking utility trailer #2
1. Needs to be enclosed, Enclosed trailer means it has a roof.
6. Would like to be able to also tow it behind my tractor, you need to add SMV signs (add blinking lights for road idiots)
7. Light enough so that I can push/pull it around when it's not hooked to anything, means single axle
/ Looking for a multitasking utility trailer #3
Army trailer?
Solid metal sides would contain a ton of stone.
Self contain surge brakes.
Separate mechanical brakes helps on farm.
Lunette hitch for better off road articulation.
Sideboards and canvas enclosure option.
I dump with the tractor. Some folks modify to dump mechanically.
Tow nicely on the road. Handles a full load of mulch to top of sideboards. Brakes are important.
Cheap. $500 years ago with 4 sideboards and full enclosure canvas. No rust. Had to wire for lights.
HD 16” wheels.
Some models have aluminum beds and run flat tires.
/ Looking for a multitasking utility trailer #4
/ Looking for a multitasking utility trailer #5
My trailer is not what you want - its a farm wagon. However - I bought brand new running gear from Horst and built this wagon to my exact needs. It's ten ton capacity. I carry large rock - large chunks of pine trunk and dirt & gravel. The build up is all wood. From the main beams to the floor to the sides.
Horst makes all types/models of running gear. If you are up to building your own. Mine took three days to assemble.
/ Looking for a multitasking utility trailer #6
You can get a single axel dump trailer with a 5200 pound axel that would carry and dump 2 tons.
haha, now I just need to find one. Seems that no one actually has any, like everything else lately.
/ Looking for a multitasking utility trailer #9
This looks like the same, or a very similar unit, 1600 Lb capacity:
$1500 with free shipping. Looks like some minimal gaps at the rear gate, so not sure about your 'small gravel' issue.
Listing doesn't specify flat packed, but there is a link to the assembly manual that clearly shows it is.
Note: This is a tilt bed trailer, but not a dump bed. You may be able to add a jacking mechanism at the front, but I'm not sure what that would do as far as lifting a load of dirt or gravel.
They also show a lower priced unit rated at 1300 Lbs for $1357 with one ramp and lower sides:
Both appear to be ready to ship.
Editing to add ... READ that one review carefully. Note the discrepancies about the rear gate and the gaps.
/ Looking for a multitasking utility trailer #10
If your area has equipment or farm auctions may be worth checking out.
/ Looking for a multitasking utility trailer #11
This trailer my grandfather made eighty years ago, it sounds like what you need and may give an idea if you want to make one. It has a 30's Chevrolet straight axle. I made a box for front to carry chains, etc.
Today if you could find a small truck bed in junk yard, cut the frame off all you'd need is a hitch. It would already have lights.
I use this one a lot. I'm sure it's had over a ton of stuff on it.
/ Looking for a multitasking utility trailer #12
Army trailer?
HD 16” wheels.
OMG your B26 is so cute. I want one now!
Read the review. Seems like it's not made all that well.
Well this is really the type of thing that I'm looking for, but I already have use of a traile r(not mine) I need to line with a tarp to keep the stone from leaking out of. This one would be better, I could probably use some EPDM to make flaps that would seal the corners. Will have to give it some thought.
Not to mention that they want $250 more from etrailer than what home depot has it listed for. I may go to home depot and see when they'd think they'd get them if I can even order one from them.
I was looking at something line this for my tractor https://www.northerntool.com/shop/tools/product_200311375_200311375. But was hoping to get something I could use on the road behind a vehicle. I don't think I could register this one. The place I get the stone is about 4 miles away and I'm not really supposed to use my tractor off my own property.
/ Looking for a multitasking utility trailer #14
this is your unicorn, Holy Grail :)
but this is what I was thinking of
or a heavy tarp, on a dump trailer
/ Looking for a multitasking utility trailer #15
I'd go with the HD one if buying new per OP's needs and specs. Size of the tractor matters, too. My 1.1L 2-range would haul that one empty in high and need to be in low with any load or on a slope. I'd expect 3-4 full scoops with the FEL to be quite a full load if not pushing it. Strips of carpet may suffice for gaps and not need attached. Consider a stall mat or DIY bedliner for the deck. Lots of ways to mechanize tilting with a full load, jack or winch & some bracket work.
Thanks for the input all. I am really thinking of getting the DK trailer that has been linked to, but the reviews I've read are concerning, everything from missing parts to issues getting it registered to how long it will last.
I really wish I could find some place in my area that has one of these things already put together so that I could look at the real thing. I hate making purchases like this online where I can't touch and see what it is I'm buying, but that seems to be what the world is coming to.
/ Looking for a multitasking utility trailer #17
I hear your concern hube2. Going from Cat 1 to Cat 2 implements - I've learned patience. Waiting for the implement to arrive at the dealer. A couple dealers couldn't understand why I wanted Cat 2 implements - when a Cat 1 was sure to fit. I quit going to those dealers.
Be patient - keep looking. You will find the "pearls".
/ Looking for a multitasking utility trailer #18
Like I suggsted on another one of these threads a few weeks ago, consider the Harbor Freight 1,750 lb unit. No deck, sides or back, but that allows you to build to your needs if you have the ability to do so. It's about $550, so lots of budget room for self design.
/ Looking for a multitasking utility trailer #19
I would avoid any trailer with 12 inch wheels. One I had required 90 PSI for rated capacity. Potholes and off-road use were not friendly to the tires.
When I've made long distance trips, most of the trailers I've seen beside the freeway, with tire trouble, had 8 or 12 inch wheels.
Bruce
/ Looking for a multitasking utility trailer #20
Watch local Craig's List or "marketplace"... Find something close to you specs and modify it where needed to do any chores you ask of it....
In all you specs the only thing you probably want to find is one the can DUMP... It would be hardest thing to modify to meet you needs...
2019 CATERPILLAR 226D SKID STEER (A62129)
2019 CATERPILLAR...
New/Unused Wolverine Mini Skid Steer 3 in 1 Bucket (A61166)
New/Unused...
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
2016 FREIGHTLINER CASCADIA 125 SLP T/A 6X2 SLEEPER TRUCK TRACTOR (A59908)
2016 FREIGHTLINER...
2019 Better Built 10 ton Gooseneck Flatbed Trailer, VIN 4MNDG2523K1000538 (A61166)
2019 Better Built...
2022 New Holland Power Star 90 Cab Tractor with Loader (A61166)
2022 New Holland...
