3 Point Lower Arms and Backhoe
/ 3 Point Lower Arms and Backhoe #1
ScotNH
NH
Mahindra eMax 22l
Hello all. I’m a new tractor owner. I just got my Mahindra eMax 22l with FEL, MMM, and backhoe a few weeks ago and currently have about 30 hours on it. I’ve recently discovered “Backhoe Dollies”, and would like to build one to store my backhoe on during the winter. The issue that I have is that the lower arms for the 3 point hitch get secured to the drawbar with an “arm retainer” before the backhoe is put on, and they extend out to the point that they would prevent me from lowering the backhoe onto a dolly.
My initial thought is that I could just remove the lower arms completely prior to putting the backhoe on, but it made me wonder if the reason they supply the arm retainer is because that is a huge hassle. Is it necessary to have the lower arms of the 3 point hitch attached to the tractor and secured to the arm retainer when having the backhoe on? Is the process of removing and reinstalling these arms simple, as it would appear, or is there something tricky about it, like the need to remove a rear tire to remove the long pin the arms connect to?
I’ve attached a picture showing one of the arms extending beyond the backhoe, and a diagram of the arm retainer.
Thanks in advance.
/ 3 Point Lower Arms and Backhoe #2
Different brand and color of machine, but I don't store my arms that way. I pull them up and to the sides, then shock cord them to the ROPS.
If you want to keep doing yours that way, you could experiment with your method. Use the outriggers to support the BH and drive forward a bit (as you do now to unhook), then release the arms from that keeper and pull them out of the way and remove the keeper before settling the BH down onto the platform/dolly.
I don't use a dolly as such. I unhook as described above, then put a couple of chunks of RR tie under the BH before setting it down in place.
/ 3 Point Lower Arms and Backhoe #3
Thanks in advance.View attachment 705235View attachment 705236
I always remove my lower arms together with the upright section that connects to the lift arms at the top. Pretty easy to do on my machine. Looks like you can just slide the pin that holds the lower arm in place enough to pull the lower arm out and then simply slide the pin back into place without having to remove the wheel. Not sure though as I don't know what sort of clearance you have. Hard to tell from your photos.
Hope this helps!!
/ 3 Point Lower Arms and Backhoe #4
As a new tractor owner do you have a ballast box or spreader to mount on your three point as a counterweight to your FEL for the winter?
Over the years I have saw many of those backhoes stored in different formats, not sure any are better than the other since you still have exposed ram cylinders. The backhoes main job is counterweight, on the smaller tractors they do not get much use for most people.
I may end up going this route for simplicity.
I agree, it looks simple, but if it is that easy, I wonder why they supply the arm retainer and have you attach that, instead of just removing the lower arms before mounting the backhoe. I guess I just need to give it a try. I just wasn’t sure if there was some good reason they are left on, with the added step of the arm retainer, instead of just pulling a couple of pins and removing them Prior to reattaching the backhoe.
I have a box blade that I’ll be attaching when then backhoe is stored. My rear tires are also filled.
/ 3 Point Lower Arms and Backhoe #7
Huh. I figgered the main purpose for a hydraulic digging machine was to ... you know ... dig.
Who knew?
Lots for sale at prices that never sell, the ones I know who have them rent excavators. Say it is faster and more comfortable, age related?
/ 3 Point Lower Arms and Backhoe #8
I have the Max 26xl which uses the same arm retainer set up. The 3 point arms do not need to be on for any reason with the backhoe on and in use. It is just much easier to utilize the retainer than to remove the arms themselves.
Have you removed the backhoe yet? The basic process is to remove the pins, use the stabilizer arms to lift it up and out of the mounting plate, pull forward, shut off the tractor and disconnect the hydraulics, and pull away.
If you are going to build and utilize a dolly the process will be the same. The only difference will be staging it on the dolly rather than the floor or ground. The 3 point arms still shouldn't interfere with this for installation or removal.
The only issue I have had is the stabilizer arms will bleed off over time allowing everything to drop lower. I use a few jack stands under the frame to prevent this, but you could build a support into the dolly also.
I have removed the backhoe a few times. I need to remove it every time I use my mid mount mower. The drooping outriggers is what lead me to start researching different ways to store the backhoe.
The dollies that I have seen, you do not use the outrigger arms at all. You lower the bucket and the frame onto a support built into the dolly. The dolly with support rolls in just an inch or so beneath the frame, and when you push the backhoe off the pins, the frame itself lands on the dolly. The lower 3 point arms extended beyond the frame would prevent this. This video isn’t the design I’ll be using, but it shows the basic idea, and I think you could see how those arms extending
The dolly would give me some flexibility as to where I store it all winter long, since I would be able to wheel it into a corner of my garage that I can’t back it into to detach. It would also not take up as much space with the outriggers up.
For now, I’ll start putting support under the frame when I detach, and I’ll see how the process of removing the lower arms goes the next time I plan to put the backhoe back on.
Thanks for the replies.
/ 3 Point Lower Arms and Backhoe #10
I worked the snot out of my BH. Way more convenient than renting, at least for me.
/ 3 Point Lower Arms and Backhoe #11
ScotNH, I see what you mean now. I had a different dolly concept I mind.
Not sure about yours but on mine when the arms are unpinned from the retainer they pretty much drop to the floor, and without the adjusters hooked up they swing outward pretty far also. Any chance you could just do that while dropping or installing the hoe?
/ 3 Point Lower Arms and Backhoe #12
I didn't use my old BH much except for occasional digging holes or trenches. For rear weight I usually carried a heavy back blade.
But then one day we got a used BH that had a thumb attachment. That thumb and bucket combo turns out to be a whole different tool. It's so handy for general chores that it lives on the tractor permanently. We hardly ever use it for digging.
BTW, I take the lower arms off when the BH is on. But those arms are heavy and then have to be stored somewhere.
I kind of like the way yours stay on the tractor. If it were mine I'd keep that system and modify the dolly.
rScotty
I think that might be an option. I bet I can just get under there and remove the 2 bolts holding the arms to the retainer, and swing them off to the side. Normally I unhook them from the retainer after unhooking the backhoe. Unless there is something about the backhoe physically preventing me from releasing them, it shouldn’t be a problem. Thanks for the idea. I’ll definitely take a look at that soon.
rScotty
This is some of the feedback I was looking for. I guessed they created the system because it was an improvement over just having to remove and store the bars, but I don’t have the prior experience to judge that for myself. I think with the idea tmcj gave me, I may be able to release the arms from the retainer prior to removing the backhoe, and use the dolly design I had in mind. Keeping the benefits of not having to remove and store the arms just by changing the order in which I release/connect them from the retainer.
Thanks again for the replies!
/ 3 Point Lower Arms and Backhoe #14
The backhoes main purpose is digging. Just because someone doesn’t know how to use it, does not change that.
By the time you get your excavator out here I would already have finished the digging and be on my way.
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
VERMEER FT 100 FORESTRY MULCHER (A65053)
VERMEER FT 100...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
1991 Polar MC 312 General T/A Chemical Tanker Trailer (A64194)
1991 Polar MC 312...
