LD1
Epic Contributor
In the first post you asked if anyone had specs for the cylinder on that backhoe but you have failed to give a model of the hoe?
Regarding a cylinder.....There should be nothing wrong with your current cross tubes. They are the right pin diameter and right width and no clearance issues. So simply shop for a cylinder that has the right bore, stroke, and rod diameter. Dont worry about what ends it has.....clevis, swivel eye, cross tube, etc. Sometimes one is cheaper than the other. Simply cut them off and disregard whatever comes on the cylinder that fits your specs. Then cut YOUR cross tubes off and weld on the new cylinder. Dont get much simpler than that.
