Prospective purchase for the mountains.
/ Prospective purchase for the mountains. #81
As far as a mower goes, I got rid of my zero turn and got a stand on mower. Night and day difference on the 15% slopes in my yard. Being able to counterbalance with my body makes a huge difference. And if I get in trouble, I just hop off.
The creation and maintenance phases used different machines in my situation. I used an older Case backhoe for creation, and my CUT for maintenance. The backhoe I sold when done with the creation phase. The hoe part of the backhoe makes for a great counterbalance if you keep it pointing uphill all the time; but can just as easily cause tipover if you have the hoe pointing downhill.
/ Prospective purchase for the mountains. #82
Hey all,
Last year, we purchased 105 acres in the mountains of Western North Carolina that are mostly wooded with about 6 acres of meadows in hollows and plenty of overgrown old logging roads that we'd like to reclaim. The prior owners quit maintaining everything a few years ago except for the lawn around the house and the driveway.
The main driveway is about a 3/4 mile and is useable for now. The other trails and meadows are overgrown and need a lot of work to get back to usable condition. In addition to cleanup, there seems to always be something on the property that needs done (trees, brush, etc).
Our original intent was to hire out local professionals to support the maintenance, but it is clearly cost prohibitive considering the ongoing work required. I'm capable of learning, but an I am admitted "city slicker" with no experience with tractors.
I'm looking for advice!
I tried local dealers with experience in the area, however nothing is in stock. I've found a 2038r in North Florida for what I consider an acceptable deal in these current times. However, the advice from dealer seems limited to their experience in tropical temps and flat ground use. For example: I was told that extra ballast isn't required except for filling up the tires with water (only water). Wheel spacers are not beneficial. I'm not knocking them, because they know their stuff.. just not familiar with the terrain of another area.
So I'm seeking out some advice and support from the forums. My first and major concern is safety with regards to tipping/rolling the tractor in the mountains.
1. My inclinometer has 13 degrees vertical as the max of our main roads on the property and that's just the driveways. I'm very concerned about tipping the tractor and wanting to configure it in the safest way for the mountains.
2. I was going to start with box blade, forks and bush-hog, (and ballast) and wait until determining if I need other equipment. Looking for input on if the standard frontier implements BB2060, RC2060 is adequate.
3. What comparative models would you recommend from Kubota, Massey etc..
4. What advice would you give to someone who is using their equipment higher in the mountains? I would probably use a Zero turn for the lawn grass. Tractor is truly for utility.
Thanks everyone!
I own 200 ac in piedmont of GA-i too had min to no experience with tractors. I watched a few YouTube videos of tractor rollovers on slopes(and many also of people using them correctly, daily, on slopes) and realized I was too ignorant at the time to purchase one(went thru exhaustive research to find a “mountain” vehicle, and like another poster commented, they were all European, or out of my price range. I also looked at track steers, but was worried about tracks popping off on a hill back in the woods, on a Sun right before i was to leave for long trip home
Certainly, I could have spent the time thats needed to learn, but i dont have that kind of margin in my life right now.
so i bought a telehandler.
Mower, tooth bucket, stump bucket and grapple followed. For me, it was, and has proven to be, the most user-friendly for someone of my limited knowledge (though I did manage to get an unstuckable machine stuck, if that tells you anything). It’s been a lot of fun learning about it, doing some minor maintenance on it, and thinking about what job/implement I need to do/buy next. I also agree, a backhoe would be really cool to have for jobs that probably take me a lot longer with my telehandler. You can get an idea of the slopes i keep cleared…
/ Prospective purchase for the mountains. #83
Boozle you have a situation very similar to mine - 138 acres in northern PA with some VERY steep hills, meadow, cultivated fields and wooded trails. I'm sure you have gotten a lot of great advice from the guys on here - I don't want to repeat too much, but my two cents worth;
-BE CAREFUL with a zero-turn on hilly lawn - the least bit damp or 'greasey' and they loose all traction and control unless you have ag tires with somewhat aggressive tread, and then it's still dicey. Yes zero-turns are fast and maneuverable, but for a very uneven lawn you may want a lawn tractor mower.
- don't skimp on a primary tractor. It's your life and health in your hands. You need HORSEPOWER, 4WD, ample ground clearance (i.e. not something with a belly mower) and versatility to do what you need to do. Don't go any smaller than 35-40HP with 4WD (tho' much larger tractors can get to be a problem when clearing trails in the woods).
- front ballast, filled tires (or an FEL - but they are VERY out of place in the woods) are absolutely necessary when climbing hills, especially if you're brushhogging or dragging a tree.
- watch your 'track' or wheel-spread - anything around 5' or less can be very dangerous on hills, or ANYWHERE with a raised FEL. All good tractors have adjustable track. A wider stance is better, if it'll fit in your barn.
- NEVER drag anything really heavy from a 3-point hitch, or from ANY point above the back axle. Use the 'draw-bar' under the back axle to drag heavy trees, etc. You don't want to ever flip over backwards.
- without an FEL you may find a 'boom pole' ($189.99 - Tractor Supply) is useful on your 3-pt., but WATCH YOUR WEIGHT LIMITS. A heavier one sells for about $350. With an FEL, clamp-on forks can be handy.
- I doubt you'll find ANY tractor that does it all well. You may find a good 40HP 4WD mid-size for the woods, treework and fields (something the size of my 34HP Ford model 1920); and a 30-40HP FEL/backhoe tractor (something like my Kubota L2850) for the 'flats and farmyard' the right combo, as I have. Learn your tractor's strengths and limitations.
- ROPS can be a real deficit in the woods - pulling down branches, knocking over 'deadmen', whipping saplings into your face. You may want to consider one that folds down, but on hills - do you really want to do that?
- at one time all I had was my father-in-law's '44 9N to do anything, and what I could do was limited. But it went EVERYWHERE on that place (trail clearing, mowing the 'top forty' up a 300' hill, pulling downed trees out of the ravine), and is still running with a 12V upgrade and is doing the light brushhogging. But I was much younger and carefree then - anything's possible, but extreme care is advised. If not overtaxed it will keep working forever, but with it's torque it will climb a tree if you're not careful (and has). A tractor is not a car - or even a truck. Be very careful with ANY tractor's power - learn to respect it, and use it carefully and thoughtfully and it will give you many, many years of hard work.
Enjoy. Go slow. Ask questions, take every answer with a 'grain of salt', and learn what works best in YOUR situation by carefully moving forward. Get help when appropriate - you can't do everything. I'm sure you bought your place to enjoy for years to come, not to die on (at least not anytime soon). Good luck.
/ Prospective purchase for the mountains. #84
Just to clarify icnu's post it is a compact telehandler, as in small:
But it does big jobs:
/ Prospective purchase for the mountains. #85
Hey all,
Thanks everyone!
Welcome to Western NC and its rocky soil.
I have a 100+ acres in Buncombe county that start at 1900 feet, rise to 3200 feet, and driveway 3/8 of mile long.
The two most important questions you have to answer is: How much time are you willing to devote to maintaining the property and what is your time worth?
Many responders have mentioned important points which I will try to draw together.
Time on machine is critical. Don't expect to be really productive or understand it capabilities until you reach 400 hours on machine.
Machine weight is critical. The heavier the machine the more stable and productive it is.
Weight allows you to put down more pressure when using backhoe or the loader and it gives you more traction on grades.
A tractor is only as capable or useful as the implements it can run.
Expect to spend almost as much on implements as on a good low hour used tractor.
Most tractors, unless they are geared, are basically a large hydraulic pump. The more horsepower the greater the pump flow and pressure and the more work the tractor can do.
Diesel only machine for power ( the ability to do drive the hydraulic pump ).
My M59 scales at 11,200 Lbs with Bradco grapple, filled tires, and backhoe.
Western NC has gets lots of rain and water running down hill carries lots of sediment and quickly erodes driveways.
I use a Kubota M59 with following to maintain and improve my property:
Backhoe with 12 foot dig depth
Kubota hydraulic thumb on 24" wide backhoe bucket
Skidsteer/Quick attach 84" wide loader bucket with 1 yard capacity when heaped
Bradco root rack grapple ( approx 1500 lbs )
Everything Attachments 9 foot box blade with rippers
Cat 2 3 point hitch and drawbar
"Top n Tilt" for 3 pt hitch so I can tilt the box blade to cut ditch or pitch driveway to run into ditch.
Skidsteer/Quick attach McMillen auger ( post hole digger) run off loader 3rd set of valves on joy stick
Skidsteer/Quick attach trailer moving ball hitch implement from CL Fab.
Power rake ( Harley rake ) for 3 point hitch.
Tires filled with beet juice for weight. Beet juice freezes way below any cold temp in NC and is non toxic.
Work light mounted front and back on ROPS. Can't tell you how many times an important project ran long and sun went down.
Bottom line. The more machine you buy the first time the more productive you will be and the less frustrated BUT ONLY if you are willing to spend the time on the machine. You can almost never have too much horsepower until you get near 80-100 hp and then you are into a very different category of light heavy equipment.
Hope this helps.
/ Prospective purchase for the mountains. #86
^ Awesome setup, M59, but you're over double his $30k budget, man.
Boozle, my only advice here beyond the good tips you have gotten, is to visit some dealerships and sit on tractors. Some tractors a huge beasts. If you can't fathom how they would fit down your trails, between trees, or navigate around buildings, etc, then step down one machine class size and try again. Get the largest and heaviest machine you can afford.
Thanks! So as update, I found a well used Ventrac with Tough Cut with a few attachments that will be a starting point for the basic property mowing/maintenance. After that, I'm going to take my time to find the right deal on a more general purpose machine for some of the other projects that involve loader and heavy duty implements. This way I'll feel safe and can begin work on the most urgent projects of maintenance while learning more about what my actual needs are in the forest.
Every bullet point here has been engrained from this post has stuck with me (Widest stance, Weights, Filled tires with Beet juice, no turning up hill, slow everything, up and down inclines, CoG low, loader low, higher HP, etc).
I never expected a 9 page thread on my questions, but it is a statement to how great this forum is. Thank you all sincerely for taking the time to help. It's a great community.
B
/ Prospective purchase for the mountains. #88
I'd never heard of PowerTrac, but your note made me look, as I mow (etc.) on what I consider pretty steep ground with my Kubota BX subcompact, and the potential for rolling is always on my mind to some degree.
Which type/model did you get, and how is it working for you so far?
I bought a pt1430.
It is set to be delivered next week, but after playing with it during the demo, I’m sure I’ll be more than pleased at what I can do with it, in areas my tractor could never access.
/ Prospective purchase for the mountains. #89
B
Congratulations!
Buy something used, then use it and learn. I think that's a great way to go.
Can't wait to see photos, and hear about your Ventrac experience.
BTW, I did see that Ventrac is selling toy models of one of their machines....the 4000 I think.
rScotty
/ Prospective purchase for the mountains. #90
I am a "city slicker" with no experience with tractors.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor weight is more important identifying compact tractor capability than tractor horsepower.
The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Bare tractor weight is a fundamental tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
I spreadsheet tractor and implement specs, often a revealing exercise which cuts through specification clutter. I have a column for cost per pound.
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
A quality dealer, reasonably close, available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after eight years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
BUY ENOUGH TRACTOR.​
The Deere 2038r is in the lighter tranche of compact tractors at 2,500 pounds bare tractor weight. Compact tractors under 3,000 pounds bare weight operate in landscape, kitchen/commercial garden or hobby farm applications on one to ten flat acres. I would consider the forward PTO of the Deere 2038r or any other light tractor a damage prone hindrance on slopes or in woods.
For 105 acres, reclamation and maintenance I recommend a wider, heavier tractor weighing 3,500 to 4,500 pounds bare tractor weight.These are the mid-weights in the compact tractor category and sell in high unit volumes. Every tractor brand has at least an economy and deluxe compact tractor model in this weight.
Tractors are inherently unstable operating on sloped ground. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability working sloped or uneven ground. A 6" to 10" wider rear axle substantially decreases tractor rollover potential.
As part of property maintenance of 100 acres of forest you will need to pick up tree trunk sections weighing 1,000 to 2,000 pounds on a regular basis.
T-B-N ARCHIVE:
TRACTOR FOR STEEP HILLS SLOPES MOUNTAINS site:tractorbynet.com
When considering a tractor purchase, bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
RELEVENT THREADS FROM THE T-B-N ARCHIVE:
tractor for sloped hilly steep ground site: tractorbynet.com
This
Aebi - Model TT211 - Slope Tractors
tractor is used in Switzerland on mountain sides low center of gravity and 4 wheel drive
They have have dealers through out the US
Don’t think of loading tires with water only they will freeze up in the winter
picked her up today. Not the best condition, but it'll do the job and give something to clean up!
/ Prospective purchase for the mountains. #92
Have fun!
/ Prospective purchase for the mountains. #93
B
Boozle,
One more piece of advice.
Grease ( Molybdenum Disulfide ) is your best friend and too many machines get ruined because they don't get greased frequently enough. The combination of high pressure/ high loads, dirt, sand water, and dry rotating surfaces will quickly turn a good machine into junk. Get a grease pump with locking tip and buy grease in 5 gallon buckets. You will save massive amounts of time and money and the machine will get properly greased and live a long useful life because this setup makes it easy and less costly. Cartridge grease is 5-10 times cost of bucket grease. The tip locks onto the grease nipple so no need to press it on by hand.
Use water and a spray nozzle to wash the old grease, dirt, etc away from the grease nipples before greasing. Wash grease fittings and grease where family members or pets won't be walking.
Your choice to take the time to find best choice/ deal on more general purpose machine is a good one. Machines ( new or used ) are horrendously expensive right now because of COVID. Every home owner had time on their hands so the landscapers got super busy and sucked up everything related to landscaping or property improvement ( machines, trailers, implements ) so prices went thru the roof.
Enjoy playing in the mountains of WNC.
/ Prospective purchase for the mountains. #94
I'll chime in on lawnmowers for steeper ground. I had a common 46" tractor style Husqvarna lawn mower from Lowe's and after 10 years of belts (expected) and many, many deck repairs (un-expected) and lots of spinning rear wheels and body weight shifting to create some traction-> I was at my Stihl dealer picking up a Motronic chainsaw only he could repair. They are a mom & pop Cub Cadet/Stihl dealer (he's a top level Stihl mechanic) and I asked what mower they sold was best for steep ground. His wife pointed at the only one they had left after selling several truckloads during the Joe Biden checks era had lots of people flush with money.
Cub Cadet RZT zero turn mowers are the trick she said. It's a typical zero turn but with a steering wheel, not the more common version with two steering arms. I began looking for a used one and had decided on a 46" as only two blades/spindles to maintain, uses less gas and mower cost less to begin with- plus I also went for the fabricated deck as they are 11ga steel not the more rounded formed steel decks, so much more durability. It also has a more sophisticated PTO set-up, better deck suspension, better safety factors in reverse, better seat, better seating position, better brake and more...
I bought a used 2019 RZT S, 46" fabricated deck and even though I'm not much of a lawn mower freak I gotta say they are the trick!
It's MUCH faster than the Husqvarna was, MUCH easier to steer & negotiate around trees, etc., has MORE power as a 24hp engine and it will flat climb a tree! Truth be known it's got enough traction to never slip and could easily get you in trouble as it will go where you shouldn't be mowing!!! Sort of reminds me of a 4wd PU truck in the winter which causes a false sense of traction. I will admit though that I now mow a couple of spots that I used a sting trimmer on before.
Not sure I'd agree with the HST comments above? Lots of logging machines are not HST but I will admit to never having owned an HST tractor.
/ Prospective purchase for the mountains. #95
Regular greasing makes them last longer, but it can also make a mess.
I prefer to use the any standard poly grease and really like the multipurpose polyurea "green grease" cartridges from John Deere.
Poly grease does a good job for medium duty tractor bushings and bearings and it cleans up nicely.
I do have a couple of places that I will sparingly use that messy black moly disulphide grease, but those places are heavy duty swing table bearings on a big backhoe. Big bearings that are heavily loaded on a backhoe that can exert off center loads of thousands of pounds of lift & pressure. I keep the black moly grease in its own grease gun in a separate container.
I wouldn't expect a Ventrac would have any similarly loaded bearings that would require messing with that kind of specialized thick black grease. It's true that moly grease does reduce friction more than the poly greases, but it sure makes a mess and stains things. A blob of it on your lawn will find your tennis shoes......
rScotty
/ Prospective purchase for the mountains. #96
I have a Kioti CK30 in IL 11 acres mostly flat but the ditch by the road is really steep. It is no fun when the rear of the tractor starts to slide sideways and the uphill front wheel gets really light. I’ve given up on mowing it both with the tractor and 2 different ferris zero turns. I let the county road guys do it with their ditch mowing tractors. The zero turn I had going across and it seemed one lever was full forward and the other was in reverse just to keep it pointed uphill enough to mow across the hill. There is a culvert at the bottom you don’t want to get into and that prevents you from going up and down. So I don’t have any experience in the mountains but have been in the o crap situations enough. I do think that for your property I would not consider anything under 35 hp and as others have said go big, heavy, and ballasted. Someone mentioned a tracked skidsteer as an option and I really think that you should take a look at those. I have not used them but have hired 2 pros for projects on my property and that is what they used. They are incredible machines. I saw one pick up an oak log about 15 ft long that would barely fit in the grapple. The back end was coming off the ground but after a few tries they got it up and moved. I think they excel at construction and destruction type of work which sounds like what you need. Someone mentioned the option of a manual trans tractor which seems like a really bad idea for a newbie on hills. I have borrowed a buddies huge old JD to move some equipment my loader wouldn’t pick up. It was a manual. I felt like spider man with both arms and legs going at the same time and nothing but your rear holding you onto the seat. (I have owned manual trans cars and trucks for 30 years) The CK30 is HST so you have one foot firmly planted in addition to your rear on the seat. So whatever you buy test it out and make sure you like the pedal placement and controls. There are a lot of options. My CK has the forward/reverse AND left/right brake pedals all on the right foot with nothing on the left side (except the rear diff lock which is handy even with 4x4 to get you un-stuck) Seems like a dumb setup but my brakes should last forever because they only get used for parking. I think nearly every tractor implement has an equivalent skidsteer attachment. I swear I saw a brand new DEERE tracked machine on a trailer with a backhoe attachment on the rear (engine) end!?! the other day. Back when the CK was purchased, the main task for it was mowing about 7 acres a week and pushing some snow in the winter. since then the mowing has been reduced and I purchased a farm property with 6 acre hay field, put up fences for horses, and have done a lot of construction. It has been able to handle everything so far but the steep ditch mowing and being able to lift really heavy stuff with the loader (turned up the PSI but it still struggles at times) So as others have said you might make a list of tasks and try to imagine over time how that list might evolve. If I had to choose tractor vs tracked skidsteer all over again now I believe I would have gone with the skidsteer. Look up all of the attachments you might need too because you can get a used pto post hole auger for $300 for a tractor but the skidsteer hydraulic version will be triple that price plus. (rentals are available though) A rear blade is light years ahead of a front loader bucket for snow removal. A quick attach front end along with a set of forks and some spare pallets are required. You will also need fuel storage. Lugging 5 gallon cans from the station is horrible. 200 gallons is minimum for my diesel delivery. I have a raised 300 gallon tank I got used for $300. Rest of my gear includes: box blade, disc harrow, 2” receiver 3 point adapter, 6 bale square bale grapple, backhoe attachment with subframe (thumb for it but not welded on yet) cheap front grapple that I have nearly destroyed (buy HD!), fence post hydraulic driver, 3pt finish mower (gets used as a brush hog sometimes). I also have a steel barrel concrete filled 3pt counter weight that is under construction. Hope some of this helps you out.
I bought the HF diesel fuel pump on a special deal for ~ $80 and my wired together shoulder thanks me when i pump in diesel fuel from 5 gal. jugs to the top tank. Get one-they are actually very well made. Put some thought into the suction set-up, I use a right angle plastic pipe and an SAE plug off the battery, same as my Battery Tender uses. Keep the wire gauge heavy enough for that pump. It takes about 60 seconds to suck out 5 gallons! I've read reviews on HF of pro users who sucked a 55 gallon drum in 6-7 minutes.
/ Prospective purchase for the mountains. #97
I'm jealous! I'm also looking for something with mowing a 15-25 degree hill being a primary task. The pressure is off since I got the Ford 8N running again - I have the wheels set at 70" while the tractor center of gravity is around 30". I feel safe at 25 degrees as long as I hold on tight enough not to get bounced off the springy seat when I hit a woodchuck hole. However, something newer would be nice since the 8N takes some maintenance and showing it's age.
BTW, Ventrac sells a light weight bucket. See Tractor Time with Tim Youtube videos!
Most people with large properties seem to end up with multiple machines - utility vehicle, a couple different tractors... When you start contemplating a utility vehicle and a bigger tractor consider the Bobcat Toolcat instead of 2 vehicles. It's on my list when I hit the lottary.
/ Prospective purchase for the mountains. #98
Boozie-what IS that?
The last thing I need is something else to "clean up"...
/ Prospective purchase for the mountains. #99
Picked her up today. Not the best condition, but it'll do the job.
I eagerly anticipate your impressions after two or three days experience operating the Ventrac:
1) How well does the Ventrac perform relative to your requirements in Post #1.
2) How well does the Ventrac perform relative to all the recommendations here.
3) After factoring in your early Ventrac experience any change to your plan for a heavier machine in the future?
Where did you buy the Ventrac? Dealer? Golf Course? Private owner?
Great picture. I am jealous too.
/ Prospective purchase for the mountains. #100
I bought a pt1430.
Sounds like the right machine for your situation. Would be great to hear more about it when you've had a chance to use it.
