Farmall Super A carburetor
/ Farmall Super A carburetor #1
shajoe44
North Augusta, SC
Kubota MX5000
I just inherited a 4 cylinder Super A tractor. I can get it to run by spraying starter fluid in the air intake side of the carburetor. I am not getting a good flow out the bottom of the carburetor so I am sure it is stopped up inside. I was wondering where is the best place to purchase a carburetor for this tractor. I have seen them listed online from $50 all the way up to $300. Thanks
/ Farmall Super A carburetor #2
Before buying another carb., remove the elbow where the fuel line attaches to the carb. There should be a strainer on the other end. Sounds like it'splugged. Remove, and backflush with spray carb.cleaner. Re-install,and check for fuel flow.
/ Farmall Super A carburetor #3
That and a rebuild kit should be enough if just that doesn't work... It's a simple carb, some carb cleaner, a tooth brush (probably not necessary) and a piece of wire along with the rebuild kit (likely just the gasket and a float needle) and you should be good to go. I've made a gasket out of a cereal box for similar and that worked fine...
Thanks, I will look at that
2022 SANY SY26U EXCAVATOR (A63276)
2022 SANY SY26U...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
NEW Wolverine 72" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 72"...
2018 Kubota SVL 75-2 Skidsteer (A65579)
2018 Kubota SVL...
New Electric Scooter (A65579)
New Electric...
