Battery based electric vehicles of today and tomorrow.
Status
Not open for further replies.
/ Battery based electric vehicles of today and tomorrow.
After watching this 13 minutes of EV battery paradigm shift starting in Germany I am less sure China has the potential of owning the EV market in the rest of the world. The pandemic related computer chip shortages is shifting attention to the First Principal way of thinking.
Don't buy solar panels: 7 reasons why you should hold off
While I think solar is cool I found this article to be a good reality check in our case.
In talking with our son I think for $1K we can build a EV only solar charging station.
In the meantime we have an old never opened HF 45 watt solar setup and have batteries and inverter options already to hack together a proof of concept 120v EV charging solution at no additional cost today.
/ Battery based electric vehicles of today and tomorrow. #2,823
Now your thinking... (y)
/ Battery based electric vehicles of today and tomorrow. #2,824
I have a nice south facing rock 100% slope that would host a nice solar installation. There's room for a couple acres of solar panels. At the most the panels would need to be 4' off the ground. It would be a PITA to drill all those rock anchors, and I don't know if Pacificorp would want to buy the power.
/ Battery based electric vehicles of today and tomorrow. #2,825
Hey, I resemble that comment! Any time I plan to be over 100 miles from the closest gas station, I load extra gas in the pickup. The onboard tank is only good for about 300 miles, so 150 miles there and 150 miles back leaves me running on fumes.
Wow 300 miles isn't much. My F150 will go 660 miles on a tank. It would go about 750 when new and the O2 sensors were working. What are the particulars? 10 mpg on a 30 gallon tank?
Going solar can be a knee jerk reaction.
One plus coming out of the "Going Green" movement around the world is first to cut out wasting energy before computing energy requirements.
/ Battery based electric vehicles of today and tomorrow. #2,827
We do our fair share of commercial building in California; you want to see a knee jerk reaction to energy consumption ?, read their Title 24 building code... You need 3 Philadelphia lawyers in the room to read it to you. On some projects we literally have to decipher how much daylight comes in through the windows and then throttle back the lighting to compensate so as not to waste the available daylight. ...
Oh yeah...
/ Battery based electric vehicles of today and tomorrow. #2,829
Compact truck. 16 gallon tank x 20 mpg = 320 miles.
/ Battery based electric vehicles of today and tomorrow. #2,830
You missed the point...I thought it was funny the EV owners had to go the gas station to buy gas for a generator to charge an EV...too funny...live with it...!
I drove my Tesla to the gas station and nobody noticed.
Bought gas for the lawnmower. But haters probably thought I was buying gasoline for a generator to charge my car. If they even noticed the car was electric.
/ Battery based electric vehicles of today and tomorrow. #2,831
I have no faith in electric tractors, but electric implements with a high starting torque motor could be handy. You might even ditch the battery pack and power them off the tractor PTO.
Mason Dixon Farms in PA used to have some electric powered implements with a big generator on the crank of the tractor. Not sure if they still do though.
You are a prime candidate for a Tesla Powerwall. Solar is not required. Am told the first Powerwall costs $10,000 installed. Subsequent Powerwalls are $7,000 each. 13 kWh each. They are smart enough to charge during cheap periods and assist during high cost TOU. Meanwhile the Powerwall doubles as backup power during outages.
Very funny. This is at work, we run multiple hundreds of horsepower worth of compressors and our amp draw (at 480VAC) is in the mid hundreds to thousands of amps range.
We would several semi trailer sized powerwalls to even think about putting a dent in our power usage (it has been discussed along with solar, but our offpeak rates are so low that its not worth it).
Aaron Z
/ Battery based electric vehicles of today and tomorrow. #2,832
Aaron Z
We had a massive power outage in our town about 10 years ago when I was working at the newspaper. We brought in a 750,000W generator to run the printing press. We couldn't get our speed up past 20,000 copies per hour (normal is 70,000) without blowing the breakers on the generator. So they brought in a 1,000,000W generator and tied it in parallel with the 750,000W generator. That got us up to around 50,000 copies per hour before it would blow the breakers. So we settled on 45,000 copies per hour. 1.75megawatts wouldn't power the printing press for the 3rd largest newspaper in Indiana.
Something interesting about those generators. They were in long semi trailers. Not knowing better, most of us thought the generators would be huge. They were not. They were only about 10-12' long. The rest of the trailer was diesel fuel tanks.
And they had to stop the generators twice a day for maintenance. Yikes.
/ Battery based electric vehicles of today and tomorrow. #2,833
We had a massive power outage in our town about 10 years ago when I was working at the newspaper. ...
Something interesting about those generators. They were only about 10-12' long. The rest of the trailer was diesel fuel tanks.
It just occurred to me after thinking about Prius as an inverter source then reading this: I wonder if one or more diesel locomotives could power a factory. 5,000 hp x several locomotives would be a lot of current, but the hard part would be converting their output to high voltage AC.
Anybody know what sort of electricity a locomotive generates? Variable-voltage DC?
/ Battery based electric vehicles of today and tomorrow. #2,834
I believe most older diesel locomotives are DC. More modern ones are AC and use frequency drives to drive AC traction motors.
I know that the University of Notre Dame power plant has two diesel electric generators taken from the USS Haddock SS-231 after it was sold for scrap in the early 60s. They're used as backup power.
/ Battery based electric vehicles of today and tomorrow. #2,836
You're pro nuclear (as am I). What do you think that would do to American energy jobs if they went with 250-300 nuclear plants VS the 20,000+ power plants now in the U.S.?
It all depends on whose ox is getting gored, and apparently, in what year it's getting gored, as per our discussions on past fuel prices.
Sorry I couldn’t discuss with you, but I’m back from your 1 week
”vacation”, now so I can. :) Bottom line is, I’d rather see the nuclear plants than the wind turbines and solar panels. They are too dependent upon ideal weather for a reliable grid. Nuclear chugs along through all weather anomalies.
I also don’t believe 250-300 nuke plants would be nearly enough to cover the country. There would still be a need for smaller power plants, which could be easily powered by cleaner burning NG. The remaining bountiful NG we produce could have been sold off shore to other countries, like ohhhhh, maybe Germany???:unsure: but not anymore! Lol
I don’t think converting to them to nuke would do much to the “liquid” fuel supply jobs and infrastructure as very few power plants run on diesel fuel of gasoline. EVs will have a much more detrimental affect on “liquid” or petrochemical American energy jobs than nuke plants.
So, yeah, I would be good with nuclear replacing coal, but much less satisfied with solar or wind replacing coal as they are far too unreliable and there’s not enough battery storage for cloudy or low-wind days.
So go ahead and cut/paste an article to show how solar is a better choice than nuclear, but it won’t change my mind.
/ Battery based electric vehicles of today and tomorrow. #2,837
An EMD locomotive engine produces 1.75 MW of AC power.
/ Battery based electric vehicles of today and tomorrow. #2,840
I'm in agreement with you on this. I don't think solar or wind is the way to go, as I don't think batteries are a good thing in general. The environmental impact of battery production/recycling/disposal is rearing it's ugly head. I wonder how much environmental damage uranium mining would do to the world VS all of the other mining for all of the other fuel sources and storage batteries combined?
Status
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2006 TerraGator 8104 (A63118)
2006 TerraGator...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
