Older tractor with rotary mower gouges dirt
/ Older tractor with rotary mower gouges dirt #1
Wordspeak
Massey-Ferguson 135
Got a mid-1960's M-F 135 which shows lots of wear and tear. Perkins diesel runs well and mechanicals seem sound except for lift arm adjustments, which may be my problem. My older JD rotary 5' mower either does not cut close enough or gouges the dirt on both sides when I mow. The rear support wheel is adjusted as low as it can go. I have tried the chains with clips but not successfully. Is there a simple remedy or do I need to have the lifts repaired?
/ Older tractor with rotary mower gouges dirt #2
The inboard end of your TPH Top Link pins through operator choice of three or four paired, vertically stacked holes (clevis mounts) on the tractor.
I speculate Top Link is pinned into the highest or next-to-highest paired holes.
Try installing the inboard Top Link pin through a lower pair of holes. Experiment.
CREDIT: - pmbutter - March 18, 2019
"There is a lot of contradictory information about which paired holes to use for the tractor/inboard pin of the top link.
The top holes give the least elevation change of the tail wheel, but better maintains parallelism with the ground.
Operating an earth turning plow the inboard Top Link pin ought to be pinned through the upper holes, so it remains at a proper working angle, regardless of its depth.
The bottom holes provide the greatest elevation change of the "tail wheel" of my "implement", but it also the greatest angular change relative to the plane of the ground.
The bottom holes are best for something like a landscape rake where you might want to lift it up and out of the way, perhaps with a little more angle so trash drops off the tines."
RELEVENT VIDEO:
/ Older tractor with rotary mower gouges dirt #3
Extending your Top Link by screwing it out will lower the rear support wheel.
A properly adjusted Rotary Cutter will have the rear of the mower ~~ 2" ~~ or so higher than the front end of the cutter. The longer the grass being cut, the higher the rear gap should be to allow higher volume grass clippings to exhaust freely.
The tail wheel should contact the ground 99% of the time, to absorb transient shocks.
/ Older tractor with rotary mower gouges dirt #4
Expand on your perceived problem with the TPH Lower Links.
There are additional pin adjustments on the TPH that influence implement operating height.
/ Older tractor with rotary mower gouges dirt #5
Raise it up! What's gouging the dirt? The blades or the front corners of the mower?.
These are typically NOT finish mowers and not made for close cutting. If you want a better "lawn" look, use a flail mower.
/ Older tractor with rotary mower gouges dirt #6
The way I read your problem, you need a finish mower designed to cut lawns.
/ Older tractor with rotary mower gouges dirt #7
I would like more information on the lift arm problems. I would think that should be rectified regardless of which mower to use and how to set it up.
The front corners of the rotary box are digging.
The crank adjustment on the right side looking from the rear is frozen and will not turn.
/ Older tractor with rotary mower gouges dirt #10
Put check chains on it so it can't go that low:
/ Older tractor with rotary mower gouges dirt #11
My old MF135 had draft control on the 3 pt lift. Yours? Shouldn’t drag except over rough ground.
If you mean the second lever on the lift, yes it has one but I have seen no results from adjusting it.
I will try the check chains. Thanks to all for the feedback.
/ Older tractor with rotary mower gouges dirt #14
If your Position Control is functioning properly you should have no need for check chains.
WHAT ABOUT THE INBOARD PIN POSITION OF YOUR TOP LINK?
POST #2.
/ Older tractor with rotary mower gouges dirt #15
If you use non-standard words for tractor parts it is very dificult to troubleshoot via the web.
I presume the "crank adjustment" is adjustment of the right Lifting Rod for leveling implements. Lifting Rod adjustment will have no effect if BOTH front corners of the Rotary Mower drag. If just one side is dragging, yes, Lifting Rod adjustment is in order. (The frozen part is called a Leveling Box. Generic Leveling Boxes are $100 - $150 from on-line venders.)
Do you have an Operator's Manual for your tractor? Should be pretty easy to find on-line, probably free. Here is a LINK:
MF 135 Operator's Manual site:tractorbynet.com
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
2012 JLG G9-43A TELESCOPIC FORKLIFT (A64279)
2012 JLG G9-43A...
2023 Stearling Trailer (A60352)
2023 Stearling...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
